Electrician
Discussion in 'Southern California' started by 87Tcyota, Aug 16, 2015.
  1. Aug 17, 2015 at 3:24 PM
    ElderP
    ElderP Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    I figure where you are at, snow/ice is a non issue. Around here, garage floors become covered with "road salt dripings". When it comes to humans, salty water is just as conductive as bare wire.
  2. Aug 17, 2015 at 3:35 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    NEC for Garage:
    210.70(a)(2) Wall switch controlled lighting outlet is required.
    210.70(a)(2) Switched lighting outlet required on exterior to illuminate all personnel entrances (not required for vehicle doors, such as overhead garage doors)
    210.52(g) At least 1 receptacle outlet (in addition to those for specific equipment such as garage door openers or washing machines) is required in all attached garages.
    210.8(a)(2) GCFI protection is required for all 15 and 20 amp 120 volt receptacles include outlets for refrigerators, garage door openers, and washing machines.
    406.12 All 15 and 20 amp, 120 volt receptacle outlet must be listed tamper resistant type unless located higher than 5' 6" above the floor.
    2014 NEC
    210.52g One receptacle outlet must be installed for each car space and shall not supply outlets outside of the garage.
  3. Aug 17, 2015 at 3:42 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Well there you have it
    Lame to the O
    edit : thinking about it now , the last 2 houses I built didn't have garages and we had a big electrical code upgrade in 2012 so that actually apply here now too , I'm going to have to ask my electrical contractor
  4. Aug 17, 2015 at 4:02 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    Wow someone gives some information and as always the aholes on Tacoma World have to chime in. For me if you don't know what your doing, call someone that does. There are codes there for a reason. I hate when cheap DIYers bring there cars in my shop after screwing them up thinking I'm going to fix there screw up for nothing. Do you research before attempting something you know nothing about. rant over
  5. Aug 17, 2015 at 4:03 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Is there a sub panel in the garage? If not it could be behind a GFI in the house poor way to wire a garage but if it's just lights and a socket or two no big deal but a garage should be on it's own home run to the breaker panel at 20 amps. If the breaker is 15 amps until you confirm it's #12 wire leave it at 15 amps.
  6. Aug 17, 2015 at 4:04 PM
    OZ-T
    Peter North
    British Columbia
    Are you referring to me ?
  7. Aug 17, 2015 at 4:07 PM
    Brianz1001
    Brian
    too much to type
    If the shoe fits sir, if not then it's a No.
  8. Aug 17, 2015 at 4:08 PM
    OZ-T
    Peter North
    British Columbia
    No it is :thumbsup:
  9. Aug 17, 2015 at 4:16 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    It's all good Brianz, I could care less what they say on TW. I only was giving info. on the current NEC Codes for a garage because there was a lot of talk about GCFI's. Homes built years ago will not comply to current codes. I have 20 years exp. in this field and don't need anybody to help me out on this one.
  10. Aug 17, 2015 at 4:21 PM
    OZ-T
    Peter North
    British Columbia
    Pretty sure nobody disputed your code info
    Maybe there is some misinterpretation going on here
  11. Aug 17, 2015 at 4:28 PM
    03coma
    New Jersey
    2015 DCSB TRD, SR5
    I'm good OZ-T, Just like upgrades we do to our trucks you never know what or how people wire things up until you dig in.
  12. Aug 17, 2015 at 4:30 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    f
    This has to do with garages usually having a concrete floor which provides a very good path to ground. If you were to walk into your garage on the concrete floor with bare feet and happened to come into contact with an ungrounded piece of metal that had a line voltage potential on it such as a poorly grounded refrigerator or washing machine, you would probably get zapped. :eek:
    The house I grew up in was built in the late 1960's when the grounding requirements of the NEC were different. We had an old ungrounded Army surplus shortwave radio receiver that would give you a little jolt if you touched it while standing on the garage floor with bare feet. ;)
  13. Aug 17, 2015 at 4:31 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    So I took electrical in hs and ac DC in college. How would one go about wiring a single 220 Volt breaker to a full panel besides tandom breakers making room.
  14. Aug 17, 2015 at 4:38 PM
    OZ-T
    Peter North
    British Columbia
    Good , no ill will intended
    Like I said , the last 2 houses I built don't have garages so it may be a requirement here now too and I've already texted my electrical contractor to find out .
  15. Aug 17, 2015 at 4:39 PM
    #35
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I would install a smaller sub-panel off of the main to make room.
  16. Aug 17, 2015 at 4:41 PM
    #36
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    You could take out two 120v breakers on one side and replace them with a 220 volt (two pole) breaker. Then to replace two circuits lost by the addition of the 220v breaker, you could remove two additional single 120 volt breakers and replace them with two "mini" breakers that each have two positions.
  17. Aug 17, 2015 at 4:45 PM
    #37
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    The only problem with this solution is the fact that you are adding an additional electrical panel that can only legally be done by a licensed electrician and would then also require a subsequent inspection which could open up a whole can of worms if there is older wiring that may not be up to the current code requirements....Just sayin. :)
  18. Aug 17, 2015 at 4:50 PM
    #38
    Large
    Large Red
    A local engineer can supersede the NEC so you might have different applications for the same room.
  19. Aug 17, 2015 at 4:51 PM
    #39
    deeezy
    Dana
    Hawaii
    Still, that's what I would do.
    And, the guy was asking what to do instead of using tandem/half size breakers to make room.;)
  20. Aug 17, 2015 at 4:55 PM
    #40
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Yep, Would probably be easier and just as safe if done correctly. :thumbsup:
    Yep, I missed "tandem", saw that after I reread it.
    jmaack likes this.
