ELECTRICIANS OUT THERE?
Discussion in 'Garage / Workshop' started by stmpjmpr, Nov 24, 2012.
  1. Nov 24, 2012 at 11:02 AM
    stmpjmpr
    stmpjmpr [OP] Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    We just switched from electric to gas stove/oven. What would it take to convert the 220 VAC on the wall to 110 VAC?
    Thanks in advance
  2. Nov 24, 2012 at 11:13 AM
    Large
    Large Red
    There's 2 hot legs, a neutral and a ground. A licensed electrician will remove the 220 receptacle and put in a standard 110 receptacle.
  3. Nov 24, 2012 at 11:13 AM
    Large
    Large Red
    And run new Romex cable from the breaker panel.
  4. Nov 28, 2012 at 11:30 AM
    nytmarecoma88
    nytmarecoma88 Well-Known Member
    07 tacoma
    Tonnuea Tint euro Tail lights halo head lights billet grille- black debadged black powdercaoted 17's "knight rider" mod aero turbine exhaust black bull bar multicolor halo fogs
    new breaker and new recepticle, u can use some wire...pretty easy actually
  5. Nov 28, 2012 at 2:16 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    you would need to replace your 2 pole breaker (likely 40A or 50A) with a single pole breaker (all gas ranges I've wired require a 20A).
    you will need to marette a piece of #12 on to each of the wire to be able to terminate the wire on the receptacle (5-20R), #8 is too big.
