Electronic Cigs
Discussion in 'Health' started by WTFaulkner, Mar 5, 2013.
  1. Apr 18, 2015 at 2:23 PM
    #2121
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    oh, if it doesnt want to go through relatively smoothly, you may have too much cotton. and same if it goes in too smooth, not enough. too much cotton also gives more cotton flavor. it usually goes away after you rejuice 3-4 times.
  2. Apr 18, 2015 at 3:01 PM
    #2122
    13SilverStreakTRD
    13SilverStreakTRD Insane but Functional
    Republic of Texas
    2013 DCSB TRD OR
    tinted windows, window visors, stubby antenna, wethertech floor liners, dented tailgate
    Thanks, Is it the dimension of the coil or the tightness of the coil that determines the ohm? Is it OK to have gaps in the coil or do you want them all presses against each other?
  3. Apr 18, 2015 at 3:02 PM
    #2123
    13SilverStreakTRD
    Republic of Texas
    2013 DCSB TRD OR
    Oh, I have some Japanese cotton but used a piece of braided that came with it for testing
  4. Apr 18, 2015 at 3:24 PM
    #2124
    magikbean562
    greg
    socal
    pinto
    33" mudders
    dont use that braided crap they send you. its more than likely chinese silica. use the cotton. yes all coils need to be touching. the diameter does change the ohms. look up youtube man lol.
  5. Apr 18, 2015 at 3:26 PM
    #2125
    magikbean562
    greg
    socal
    pinto
    33" mudders
  6. Apr 18, 2015 at 4:25 PM
    #2126
    13SilverStreakTRD
    Republic of Texas
    2013 DCSB TRD OR
    Thanks for the links. I just rebuilt (before watching) and got .2 ohm off 2 - 4 wrap and the ipv2 won't fire duu to low resistance lmao :homer:
  7. Apr 18, 2015 at 5:05 PM
    #2127
    magikbean562
    greg
    socal
    pinto
    33" mudders
    Coil builder problems lol
  8. Apr 18, 2015 at 5:19 PM
    #2128
    13SilverStreakTRD
    Republic of Texas
    2013 DCSB TRD OR
    :yay::yay::yes::woot:
    I need a blowtorch
  9. Apr 20, 2015 at 1:00 PM
    #2129
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    All coils do NOT need to be touching to still have a functioning coil that fires properly. I stopped building compressed coils a while back because of how quickly the crust from old juice builds up on them. I run open macro coils and I can get 2 weeks out of them before I have to change cotton and dry fire them clean.
    Resistance is mostly based on the mass of metal between the pos and neg posts. That's why the various gauges of that wire are rated by ohms per inch/cm or ohms per foot/meter. However, bends in the wire create additional resistance just from putting stress on the metal by curving it. Wrap your coils with known-diameter items such as drill bits or those micro screwdrivers that come in a set with the diameter labeled on them, and you'll have good consistency from one build to the next. The length of the posts you leave behind on your coils will also affect your resistance results. I use the micro screwdrivers to wrap mine, since I already have them out to use on the screw posts of my tanks.
    Using organic or Japanese cotton is your best option. Be aware that Japanese cotton will break down a little faster than processed organic cotton will, and it's less "spongy". I find that my wicks will start to degrade around some of my coil ribs after a couple days, allowing the coil wire to be not as tightly fit against the cotton and this causes hot spots. Just keep an eye on your coils if you start tasting odd flavors when your cotton isn't totally dry yet. I just pull my wick a little bit through the coil so the coil ribs are heating up against a new spot of cotton. I stopped using organic cotton because I didn't like the taste of it after using true Japanese cotton pads. Great stuff.
  10. Apr 20, 2015 at 1:38 PM
    #2130
    13SilverStreakTRD
    Republic of Texas
    2013 DCSB TRD OR
    :thumbsup: Thanks. I have a coil jig and I ordered a coil master off Amazon. :notsure: That should help I think. I have it set up now with 2 - 6 wrap coils reading .47 ohm. It works but spits and pops a lot
  11. Apr 20, 2015 at 1:42 PM
    #2131
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Spitting/popping is going to happen especially with a really wet wick.
  12. Apr 20, 2015 at 2:14 PM
    #2132
    13SilverStreakTRD
    Republic of Texas
    2013 DCSB TRD OR
    I thought it was the imperfect coil :homer:
  13. Apr 20, 2015 at 3:54 PM
    #2133
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Nope. You're instantly boiling fluid, so the popping is the instant creation of small steam bubbles that splatter. Unavoidable unless you run your wicks nearly dry all the time.
  14. Apr 21, 2015 at 3:05 PM
    #2134
    DormaTaco
    DormaTaco Well-Known Member
    Shawn
    MN
    '15 TRD Sport DCLB 4X4
    Hey guys....
    Thought I might throw this out there but a buddy of mine is closing his vapor store, and is planning on selling off the inventory for pretty cheap. Let me know if you are in the market for anything and I will see what I can do. PM works best.
    PS - Vaping has literally saved my life and my health, even though I'm not big into the mods and chasing clouds. No smokes for me in over two years now.
  15. Apr 21, 2015 at 3:26 PM
    #2135
    Theloden
    Theloden Well-Known Member
    Joe
    Lakes of the North, Michigan
    '23 TRD Off Road
    I recently switched over to e-cigs. I used to smoke cigarettes and cigars fairly frequently, which was starting to affect my health. I tried to stop flat out, but that didn't work. The gum was gross and I didn't like the patches. I figured e-cigs would be a good way to cut out many of the nasty chemicals I was inhaling and still "trick" my brain into thinking I was still smoking since the sensation is similar.
    I used a the Blu Plus rechargeable pack, mainly because I can get the cartridges at almost any gas station, which makes it convenient. I've been just using the classic tobacco flavor but I'm thinking about maybe trying the vanilla to see how I like it.
    Good news is since switching I haven't touched a regular cigarette or cigar.
  16. Apr 21, 2015 at 5:18 PM
    #2136
    13SilverStreakTRD
    Republic of Texas
    2013 DCSB TRD OR
    ^ congrats man! :thumbsup:
  17. Apr 22, 2015 at 4:34 PM
    #2137
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    good beginers set up.
    go
  18. Apr 22, 2015 at 11:37 PM
    #2138
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Maverick, my roommate bought that same one a month ago, he uses the shit out of it lol it's perfect for going out to a bar and stuff it actually replaced his eRoll lol
  19. Apr 22, 2015 at 11:38 PM
    #2139
    TexasPreRunner
    Anthony
    2011 PreRunner
    Have you done it before? As in tried a buddies or something like that
  20. Apr 22, 2015 at 11:42 PM
    #2140
    JuansTaco
    Juan
    gilbert az
    No I vape. Was for mavericktrd. Been out of the beginning game for a while. Been on mods for about a year and a half
