Electronic Cigs
Discussion in 'Health' started by WTFaulkner, Mar 5, 2013.
  1. Feb 15, 2017 at 8:20 AM
    #2301
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I have not seen this issue.. i used to mix space jam and humble together.
    How much are those atomizers?
    If under $10 I'd just buy new..
    Silverspool likes this.
  2. Feb 15, 2017 at 8:27 AM
    #2302
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Yeah they are cheap i prolly will just get a new one, just didnt know if somethin was causing this that i should avoid on the new one
  3. Feb 15, 2017 at 9:25 AM
    #2303
    ChemDawg
    Maine
    2005 sr5 4x4
    I have heard....citrus,cinnamon and some other flavors can stain/warp plastic atomizers..? :notsure:
    But I use humble and spacejam in my avocado and my limitless (both glass)
    These other members seem to know alot more than me on vaping though
    yota243 likes this.
  4. Feb 15, 2017 at 4:14 PM
    #2304
    medic2230
    Murph
    Bama! Roll Tide
    The VG is what's thicker. PG is thinner and will flow through those atomizers better. That's why you run the the high VG juices in a dripper because there isn't anything to clog up like the cotton around the coil on yours.
    That's probably the VG in the juice doing that. You're probably not getting enough power to heat it up and vaporize the thicker juice. Plus it doesn't flow through that type of atomizer good at all. When you upgrade to a mod setup you will see the difference instantly on how they can use any juice and you get a much better vape off of them.
    If you vape cinnamon you need to use a glass tank because it will eat plastic tanks.
  5. Feb 15, 2017 at 4:58 PM
    #2305
    yota243
    E.J.
    north Alabama
    Think my tank is being eaten its kinda peeling now. This stuff seems thinner than my 50/50 maybe its an Optical illusion since it was clear but maybe they put a thinner in it or somethin.
  6. Feb 15, 2017 at 5:23 PM
    #2306
    ChemDawg
    Maine
    2005 sr5 4x4
    Good exscuse to grab an avocado =)
    Or an smok alien and avocado.
    Heck it's still cheaper than $ cost smoking.
  7. Feb 16, 2017 at 6:27 PM
    #2307
    yota243
    E.J.
    north Alabama
  8. Feb 16, 2017 at 9:31 PM
    #2308
    Ariyan
    Ariyan Well-Known Member
    NM
    4x4 TRD Sport
    SAS, 40s, and some armor.
    I had the drip box for a little while before I got my smok, it was good for a bit but it was a PITA to fill/clean and it made a mess easily. It was nice when on trips because I could just plug the box in and let it charge while driving which my snowwolf can't do.
  9. Feb 17, 2017 at 4:51 AM
    #2309
    ChemDawg
    Maine
    2005 sr5 4x4
    Kanger makes a solid topbox mini kit. Adjustable up to 75w
    My only complaint was battery life (single 18650)
    It's not as fancy as my wismec or my alien 220 but man is it tough..!
  10. Feb 17, 2017 at 10:09 AM
    #2310
    yota243
    E.J.
    north Alabama
    https://vaporhq.com/kanger-subox-mini-c-starter-kit#product_tabs_description_tabbed I don't wanna spend a ton, is there anything that I can get that is worth having and a novice type level of experience for like less than $50
    I feel like I wouldn't have a problem building coils, ive seen some videos and its just wrapping wire so that doesn't scare me but I don't wanna like put somethin in backwards and it blow up on me or somethin
  11. Feb 17, 2017 at 10:34 AM
    #2311
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    What if your lungs are looking like that....... all vaselinelookinized E-ciggin
  12. Feb 17, 2017 at 10:36 AM
    #2312
    yota243
    E.J.
    north Alabama
    I got two of em
  13. Feb 17, 2017 at 11:59 AM
    #2313
    ChemDawg
    Maine
    2005 sr5 4x4
    Yes don't drink it.o_O
    :burp:
    That's about as cheap as I have seen for variable watt mods.
    These have saftey features to prevent shorts ect....
    This is kinda a buy once cry once senerio..
    The cheaper mods usually have built in batteries...so once they won't charge the whole unit is disposable.
    The kanger...you would just buy new batteries.:notsure:
    medic2230 likes this.
  14. Feb 17, 2017 at 12:08 PM
    #2314
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
  15. Feb 17, 2017 at 12:14 PM
    #2315
    yota243
    E.J.
    north Alabama
    Thanks for the insight. I may put this unit in my shopping cart and order it next week alomg with a battery... Or 2
  16. Feb 17, 2017 at 4:58 PM
    #2316
    ChemDawg
    Maine
    2005 sr5 4x4
    Trolls
    :burp:
    yota243 likes this.
  17. Feb 17, 2017 at 5:26 PM
    #2317
    yota243
    E.J.
    north Alabama
    Screenshot_2017-02-17-19-24-22.jpg Couldnt pass this up. Found it for $23 shipped and i got enough points for signing up to save $1 on my order. Just gotta get batteries now
    ChemDawg likes this.
  18. Feb 17, 2017 at 5:47 PM
    #2318
    Guerrilla
    D. Cooley
    Coast to Coast
    Stuff
    nah dawg:hattip:
  19. Feb 17, 2017 at 6:00 PM
    #2319
    medic2230
    Murph
    Bama! Roll Tide
    Find you a Wismec rx200 and buy it once. Uses swappable 18650 (3) batteries. It will have all the power you will ever need plus some. You can put any tank, dripper or anything you would want on it. It's a regulated mod so it's not going to allow you to run something on it that will blow up on you. That's mainly the unregulated mods running straight off the battery. You can find one online cheaper than in a store. It may be a little harder to find because it's been replaced by a rx200s. There's more to building coils than winding the wire. You need to know by the wire size how many wraps and what resistance you want to build it to. You also need to make the wraps a certain size around to obtain that resistance.
    This is a rx200.
    Back with the battery cover off.
  20. Feb 17, 2017 at 6:02 PM
    #2320
    def67
    def67 Silly Milly
    Alberta
    2012 TRD Offroad
