electronic cut-out under hard acceleration?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97yota, Oct 14, 2009.
  1. Oct 14, 2009 at 3:57 PM
    97yota
    97yota [OP] Member
    poland maine
    97 4x4 reg cab 4cyl
    flowmaster exhaust, k&n filter
    Under hard acceleration my tacoma's engine cuts out and won't rev up. Any suggestions? I replaced the head gasket a few months ago and since then the rev gauge has cut out intermittently when too much or very little throttle is applied. Has anyone else had these problems?
  2. Oct 14, 2009 at 5:26 PM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    have you checked your codes? It might be something else
  3. Oct 14, 2009 at 5:37 PM
    97yota
    97yota [OP] Member
    poland maine
    97 4x4 reg cab 4cyl
    yea i plugged it in to a diagnostic and it didn't register any issue
  4. Oct 15, 2009 at 12:58 PM
    Andyd103
    Andrew
    New Hampshire
    your best bet if you don't have the time to dig around on other sites or in your engine bay, would to bring it to a mechanic and have them diagnose it for 90$ or so and just fix it from there yourself if you can.
  5. Oct 15, 2009 at 1:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    Does this truck have a distrubutor?
  6. Oct 15, 2009 at 8:08 PM
    97yota
    97yota [OP] Member
    poland maine
    97 4x4 reg cab 4cyl
    no its EFI...i dont know if the rev gauge acting intermittently is connected to the cut out problem.
