Electronic throttle control system
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Sep 6, 2010.
  1. Sep 6, 2010 at 5:26 PM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Anyone know of any mods or anything available to kill the RPM hangs and delayed and semi-unpredictable throttle response yet?
    I'm sure this thing works fine with an automatic, but it can be maddening with a manual transmission. When I remove my foot from the accelerator, I want the RPMs to drop, not hang or even increase for a moment and then slowly come back down. And when I'm stopped and about to start out in first, when I tap the accelerator, I want the RPMs to instantly increase like a normal vehicle, not react with a delay or in some cases do nothing if the throttle pedal application is too fast.
    This thing can be maddening sometimes.
  2. Sep 6, 2010 at 5:35 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Unfortunately it's just how it is. The RPM hang when you let off is for some sort of attempt to assist in 'rev match' down shifting... ok for newbs, horrible for experienced drivers. As for throttle response I can't say it seems that much more lagged than fly by wire imo, though I do have an auto. There was some little modification that came out awhile to replace or enhance the signal from the throttle ped for the 6spds, whether it works or not I can't say.
    The way the manual was setup on these trucks, plus the throwout bearing issue... is the only reason I went with the auto over the 6spd.
  3. Sep 6, 2010 at 5:43 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
  4. Sep 6, 2010 at 5:48 PM
    spenny
    spenny Mmm... Beer
    BC, Canada
    '06 TRD Acc. Cab
    Stock
    that thing is horribly overpriced...
  5. Sep 6, 2010 at 6:07 PM
    PA452
    Western PA
    Yeah, I looked into that a while ago. There already is one available for the 2009 and 2010 year MTs. Unfortunately they do not have them available for the 2005-2008 model years. Thing is, the only thing keeping them from doing it is that apparently the parking brake operating rod is in the way. That's what they told me anyway when I asked them about it some time ago.
    It is horribly overpriced, but they have a money back guarantee I believe. If they had one that fit my truck, I'd buy one to at least try it out. If I didn't notice enough of a difference (and I can't help but think I wouldn't), I'd send it back.
  6. Sep 6, 2010 at 7:14 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    true, but when you are the only option, people will pay for it
    Justin
  7. Sep 6, 2010 at 7:58 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    Is this just a problem for some vehicles? I am on my 2nd 2010, 5 speed, have never noticed any rpm hang or increase, it (both trucks) behaves just like it should when letting off the throttle, and when shifting. No lag, no delays, no rpm increase or hang whatsoever.
  8. Sep 6, 2010 at 8:09 PM
    PA452
    Western PA
    Can't say for sure. I've only driven mine and I test drove one other. Both did it, but I didn't realize just how bad it was on the test drive.
    I've posted about it before though and lots of others have chimed in, agreeing and saying that their truck does the same.
    It can be maddening. When it's time to buy a new truck, I'm going to go test drive the new Tacomas. If the latest trucks out still do the same, I'll look at something else. I won't buy an automatic, but there's no point in knowingly buying a truck that acts like this.
  9. Sep 6, 2010 at 11:01 PM
    spenny
    spenny Mmm... Beer
    BC, Canada
    '06 TRD Acc. Cab
    Stock
    Basically all new vehicles are DBW, it's pretty hard to avoid...
  10. Nov 21, 2014 at 6:05 AM
    Rotary12
    Rotary12 Member
    Minnesota
    Topper and bed rug
    I'm looking for a conversion kit to a manual throttle control. I really hate the electronic throttle for all of the above stated reasons. I basically had to change my driving style to adapt to this truck. The other irritating "feature", it the computer likes to "hunt" when you feather the clutch. My wife thinks that I'm causing it, but never had the issue in a manual throttled vehicle.
  11. Nov 21, 2014 at 6:32 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    teach yourself how to drive it
    you may need to do things differently and switch up your fine foot control and
    timing. but there is no design flaw with the truck, you have to adapt to it, like
    anything else.
    Lester Lugnut likes this.
  12. Nov 21, 2014 at 6:41 AM
    Rotary12
    Rotary12 Member
    Minnesota
    Topper and bed rug
    I have, but I still think that my physical throttle control is much better than some computer with a limited sample rate.
  13. Nov 21, 2014 at 6:59 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Mine does the same thing you get used to it I no longer even notice it. It is emission related device controlled by the ECU if you defeat it you will end up with engine codes it may even drive it into limp mode.
  14. Nov 21, 2014 at 7:11 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    I do agree. my cable operated 4runner has one electronic part... the TPS sensor. with a fresh TPS sensor I have ultra-fine throttle control on that thing. Tacoma is not bad, but the 4runner is better
  15. Nov 21, 2014 at 10:30 AM
    Rotary12
    Rotary12 Member
    Minnesota
    Topper and bed rug
    The Tacoma is better than my wifes '05 Corrola xrs, and yes, I'm used to it, but I would still like to change iot now that it's paid for and the warranty is up.
  16. Feb 16, 2017 at 2:25 PM
    CudaRavage
    CudaRavage Well-Known Member
    Parma, Ohio
    2017 SR 4x4
    After decades of being able to control my throttle within 100 RPM it's a bit annoying to have my pedal divided into 4 levels of input. It doesn't affect my personal driving style that much but this seems a terrible thing to do to serious off-roaders whom need absolute control when crawling. I know this is a zombie thread but this is the only thing that bothers me about my truck so far. Anyone find this makes delicate crawling more difficult?
  17. Feb 16, 2017 at 3:47 PM
    Rotary12
    Rotary12 Member
    Minnesota
    Topper and bed rug
    I don't like that the Ron's are kept up for emissions. That make precision shifting all but impossible. I used to road race and am very adapt at shifting and I hate throttle by wire.
  18. Feb 16, 2017 at 4:50 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
  19. Feb 16, 2017 at 5:32 PM
    badger
    badger Well-Known Member
    07 SR5
    True,
    Precision shifting is impossible. You either learn to slow down your shifts to a plodding pace, or live with disappointment.
  20. Feb 16, 2017 at 5:44 PM
    81shark
    81shark Well-Known Member
    2006 Base Access CP1
    You get used to it
