Electronic to manual 4wd swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Emmetjmcc4, Jan 18, 2020.
  1. Jan 18, 2020 at 5:41 PM
    Emmetjmcc4
    Emmetjmcc4 [OP] Well-Known Member
    Emmet
    Michigan
    2002 Tacoma 4x4 270k, 1995 Tacoma 4x4 353k RIP
    American Racing 15x8 -19 off. Cooper Discoverer stt pro 31x10.5r15 Allpro baja tube bumper Fox racing 2.0 all around
    I did a bit of searching and I didn't really find much on the subject, I will be buying a 4wd truck but I prefer the locking hubs with the manual 4wd shifter instead of the 4wd button.
    Does anyone have any insight on what it would take to do that swap?
    Not completely set on what truck I'm buying yet but if that's a possibility to take it out of my 95 to put in a different truck then it won't limit my search as much
    Thank you
  2. Jan 18, 2020 at 6:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Manual diff tube to replace the add tube
    Manual hubs
    Axles
    Wheel hub to fit the accompanying axle
    J shift transfer case to replace the push button transfer case
    Area51Runner likes this.
  3. Jan 18, 2020 at 6:46 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Get ready to do some reading Emmet - most if not all of the info is here...:thumbsup:
    https://www.tacomaworld.com/threads...-tacoma-3rd-gen-4runner.460180/#post-13641747
    Edit:
    Just saw the want for JShift vs your stock. Anyway, some of that info in the thread still helps.
  4. Jan 18, 2020 at 7:01 PM
    Emmetjmcc4
    Emmet
    Michigan
    As far as all of those parts the 95 I have that is totaled in my driveway has all of those things, would it be a bad idea to use all of those instead of buying new? Or is there certain parts I should buy new instead of using the used parts?
  5. Jan 18, 2020 at 7:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not a bad idea at all considering you'll know the condition of said items.
    I'd rebuild the hubs though since they're easy; buy new gaskets and o rings as well.
  6. Jan 18, 2020 at 7:10 PM
    Emmetjmcc4
    Emmet
    Michigan
  7. Jan 18, 2020 at 7:12 PM
    Area51Runner
    actually, what would be easiest is to just find the truck you want. ;)
    Most of what you are trying to figure out now is going to be dependent on what truck you buy and its capabilities.
    Blue92 and Emmetjmcc4[OP] like this.
  8. Jan 18, 2020 at 7:13 PM
    Emmetjmcc4
    Emmet
    Michigan
    Working on it but pickings are getting slim
    Area51Runner[QUOTED] likes this.
  9. Jan 18, 2020 at 7:16 PM
    Area51Runner
    tell me about it... lol
    @Kwikvette and I are both working on 2WD to 4WD conversions. He's further along on the parts front but I'll catch up soon provided I can find what I need. Also helps to have a plan and stick to it. :rofl:
  10. Jan 18, 2020 at 7:42 PM
    Emmetjmcc4
    Emmet
    Michigan
    That sounds like a project! I'm seriously considering a 99 in Florida right now. There sure isn't many 4wd trucks with less than 200k miles on them.
  11. Jan 18, 2020 at 7:46 PM
    Area51Runner
    You can always go with a 2002-04 and just do the manual hub conversion I originally linked to. A thought if you can't find anything else.
  12. Jan 19, 2020 at 3:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Shop for your truck .
    If the 4X4 system it has Works why change things ??
    When it breaks then swap things
    I am sure you want a vehicle to drive not another project
    It never fails always some simple part we all forget that can hold things up for weeks it seems
    Area51Runner and Blue92 like this.
  13. Jan 19, 2020 at 7:05 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    If a manual shifter is all you want, just find a truck with ADD+ J shift t-case.
    But I would find what you want from the get go. Doesnt really seem worth it to rip out a perfectly functioning ADD system. Its not something that really fails often.
