Elevation and MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, May 4, 2012.
  1. May 4, 2012 at 6:07 AM
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    so i have been tracking my MPG on fuelly.com since i purchased my truck in southern california. in so cal, i was getting about 18-19 MPG with the best being over 20 MPG. within 8 months of owning the truck, i moved to colorado and, shortly after that, i put the lift and tires on it. when i did that, thats when i noticed the drop in MPG to 15-16 MPG (and sometimes 13 MPG). the elevation in colorado (at a minimum) is 5000 feet and when we went off roading, we got up to 12000 feet. i never considered the elevation change to be the cause of the lower MPG; i thought that it was due to the tires. so when i moved out to massachusetts, thats when it dawned on me that the elevation must have an effect on MPG. i am sure some of you are saying, "well, duh", but its just that i have the data now to back that up. 6 out of the last 7 fill ups in MA have been at 17-18 MPG. so it seems that i really only lost about 1 MPG due to the larger tires.
    just thought that i would share :)
  2. May 4, 2012 at 6:26 AM
    Me Likey TRD
    Me Likey TRD Well-Known Member
    Stan
    Eastern Oregon
    2012 TRD Sport DCSB
    Toytec Ultimate w/Dakar leaf packs, Michilin 265/75/16 LTX AT2, FJ Trail Team replica wheels, Access Ltd bed cover, Katzkin leather, Brute Force rear bumper, Relentless Fab front bumper, Beefed sliders
    Interesting.
    I'm at around 4000 elevation and used to live near sea level with no change when I moved.
    But did notice a big drop in mpg a few years ago when ethanol was added to most of the gasoline. Probably 2-3 mpg drop.
  3. May 4, 2012 at 7:22 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    When I go to Colorado my mpg goes up. All my best tanks were while visting the fam in Ft Collins and Denver.
    Did you use 90 or better octane while in the mountains?
  4. May 4, 2012 at 7:37 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    This is interesting, because when flying as you go up, air thins out, so you have to lean the fuel mixture and fuel economy gets better, to a point at least, then you just start losing power and fuel economy once you get too high, but at sea level it's noticeably worse with denser air, and more fuel to keep a good fuel/air mixture. I would imagine the same would apply to vehicles? or even in the summer?
  5. May 4, 2012 at 7:38 AM
    Cowboyz
    Cowboyz Membor
    Luke
    Southern Utah/Las Vegas
    07 DC LB TRD Sport
    6in Pro Comp stage 2 lift, 2.75in ProComp Coilovers, Rear MX6 adjustable shocks, 35in Nittro Trail Grapplers, 17 in XD Spys, URD intake, URD MAF Calibrator, Flowmaster 40 Series, AMP Power steps, debadged, blacked out tail lights, Blacked out headlights w/ Mini H1 Retros and halos, JVC KW-AVX840 7" Double-Din, Viper 5704 2way alarm/remote start, LEDs in Dome, Maps, and license plate lights, short black antenna, 5% Tint, removed sway bar
    Im at 5650 feet in Southern Utah and I have 35in BFG KM2 Mud terrains with stock gears getting 15.5-16 consistently. and i always put 87 not the 85 that they offer in the higher elevations.
  6. May 4, 2012 at 8:17 AM
    NetMonkey
    Geogetown, TX
    no, i always used 85/87.
  7. May 4, 2012 at 8:37 AM
    Uplander
    Uplander Active Member
    Idaho
    2012 Barcelona Red DCLB Sport
    TRD Supercharger, URD 2.825" Pulley, TRD Exhaust, Moroso Catch Can, MB Chaos Wheels, 265/65/17 Hankook Dynapro's, 5100's @ .85", ARE MX Topper W/BedRug
    Could it be that Colorado is mountainous, requiring the engine to work harder going up and down all the terrain? MA and So. Cal are going to be relatively flat compared to driving I-70 in the mountains of Colorado.
  8. May 4, 2012 at 9:50 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Its the lift and big tires.Almost everyone who complains about MPGs has a lift and bigger tires than stock.If you want to play you have to pay!
  9. May 4, 2012 at 10:44 AM
    Bajones
    Bajones Well-Known Member
    I am no scientist but live up in Vail, thus driving in the mountains all the time. I have no idea how elevation effects mpg but grinding up and over mtn passes and what not has to have an effect. The engine definitely works harder in under these conditions.
  10. May 4, 2012 at 10:46 AM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    You obviously didnt read his entire post. You need to read to succeed!
  11. May 4, 2012 at 10:51 AM
    NetMonkey
    Geogetown, TX
    yes, good point. however, when i was in colorado, my daily commute (westminster to louisville) was through the same type of rolling hills as there are here in MA.
    when i went off roading, i went through the passes and, yes, that would drop the MPG.
  12. May 4, 2012 at 10:58 AM
    Twiostaco
    Austin
    Utah
    What about winter gas? The last feel ups for me have yielded much better mpg. Winter gas gas come to an end!!!
  13. May 4, 2012 at 11:13 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Yeah... My pickup is a dog up here at high elevation. My 33" tires definitely didn't help either. When I took my truck to our cabin in Minnesota it absolutely ripped. Definitely feel a difference. There's gotta be another pound or two of manifold pressure at the lower elevations than I am used to. I am planning a S/C for my truck soon to compensate for my lack of power.
  14. Jun 15, 2012 at 1:04 PM
    NetMonkey
    Geogetown, TX
  15. Jun 15, 2012 at 1:14 PM
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    2012 V6 DC auto: I live and work between 5,400'-9,000', 87 or 91 OCT, getting 19-21 mpg with stock set up. The lower values for me are typically when I use the truck in 4WD.
  16. Jun 15, 2012 at 3:53 PM
    kogary
    kogary Well-Known Member
    Denver
    2005 Indigo Ink AC, V6, auto, 4x4
    Heated drivers seat, JVC HU, Sound Ordinance compact 8" sub under passenger seat, Morimoto projectors/D25 HIDs, LED lit cupholder mod
    ^^^This
    Winter gas really demolishes your mpg.
    I've filled up 50 something times here in Denver and can say with confidence, winter gas is awful. Look at my fuelly link below. I go from 21-25mpg in the summer to 19 if I'm lucky, in the winter.
    And as others have mentioned, higher elevation = less dense air, thus less fuel is required to hit a stoichiometric a/f ratio (or close to it). Whenever I've traveled out of state, I've always noticed a slight decrease in gas mileage the closer to sea level I get.
  17. Jun 15, 2012 at 3:59 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I get better mpg in the Colorado front range and in the mountains than lower altitudes.
    Thinner air is good for lower wind resistance and less power which means less gas. I get 35mpg driving 60 around Denver.
    Driving in Mississippi at 60 I was lucky to get 28 mpg.
  18. Jun 15, 2012 at 4:32 PM
    memario1214
    Colton
    Missoula, MT
    Your logic sounds good but its flawed... you may have a tiny amount less wind resistance, but that is easily negated by the lack of oxygen available in the thinner air at high altitudes.
  19. Jun 15, 2012 at 4:56 PM
    worthywads
    How does that negate? Less oxygen means less power and less gas.
  20. Jun 15, 2012 at 6:10 PM
    memario1214
    Colton
    Missoula, MT
    Yes. You have less power which you need in the mountains. Dropping gears is not good for mileage at all. You may get or at least think you get better mileage in the mountains, but im pretty sure you're in the minority.
