Elevation and MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NetMonkey, May 4, 2012.
  1. Jun 16, 2012 at 2:58 PM
    #41
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    OP, Get a ScangaugeII. I live in Albuquerque, NM (5500' ASL). I gained 3-4 MPG by seeing realtime gas comsumption and changing my driving style. I have BFG LT265/75/R16.
    I drive into the mountains to Santa Fe daily. Average 20-22 MPG.
    http://www.fuelly.com/driver/wile/tacoma
  2. Jun 16, 2012 at 3:42 PM
    #42
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    You apparently don't understand.
    So what if the percent of oxygen is the same at 100,000 ft as at ground level? There is actually less oxygen available, in fact almost none. That it can be said to be because of lower partial pressure is true but doesn't change the fact that there is less oxygen molecules per volume of atmosphere which is the point.
    You were short of breath because of less oxygen, no matter how you spin it.
    Looking at it in reverse, there is less partial pressure because there is less oxygen and all the other gases at that altitude and above.
    http://www.altitude.org/air_pressure.php
    At 6000ft, the standard barometric pressure is 82kPa (617 mmHg). This means that there is 81% of the oxygen available at sea level.
    That means less oxygen.
  3. Jun 16, 2012 at 4:00 PM
    #43
    worthywads
    Most likely a different in the terrain that is causing the poor mpg at the higher elevation. Manual or stick? Keep it floored on every incline?
    On the front range you have relatively flat travel which is good for mpg. That you say betwen 9-12k on a daily basis means you do lots of climbing which has already been pointed out as bad for mpg.
    The fact is that if you could somehow find a relatively flat travel at 12K you would get better mpg than at 5K.
    I don't doubt you get worse with your commute than in Denver, but it's for other reasons than the altitude factor.
  4. Jun 16, 2012 at 4:39 PM
    #44
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Another reason, since a 2.7L engine would behave like a 2.2L engine a mile up airflow-wise, there will be less manifold vacuum for any given power output and much less pumping losses. Definitely better for mpg, then you get to add lower air resistance to that. Sounds like skierdude's compensating for power loss in the thin air by going open loop a lot more without realizing it and burning all his daylight oil.
  5. Jun 16, 2012 at 4:46 PM
    #45
    worthywads
    Good points iroh. :cheers:
  6. Jun 16, 2012 at 10:29 PM
    #46
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    You're as dense as a fart in Death Valley... the point I was trying to make is about the density of O2 at varying
    elevations, not that there is somehow less O2 for any other reason.
  7. Jun 18, 2012 at 10:15 AM
    #47
    NetMonkey
    NetMonkey [OP] Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i do have a scanguage :)
  8. Jun 18, 2012 at 10:20 AM
    #48
    SummitCo.Skier
    SummitCo.Skier Active Member
    Keystone, CO
    08 Tacoma...3in lift...TRD Off-Road
    It just seems as though my car always tries harder at higher altitude.....when I had a 4cyl up here it sputtered to pass cars......
    I think my point is even if better mileage can be achieve at higher altitude 9k ft+, it always comes withs hills and constant elevation change which more than counteract the mpg savings...make sense???? so the savings is moot?!?!
  9. Jun 18, 2012 at 10:48 AM
    #49
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Then why are we having this discussion:D
