Eliminate the spacer on ProComp Stage 1
Discussion in 'Suspension' started by 705 Taco, Jan 18, 2012.
  1. Jan 18, 2012 at 4:59 PM
    705 Taco
    705 Taco [OP] Zombie Killer!
    Dean
    Barrie ON / St. Petersburg FL
    2016 TRD OR AC
    --Stock 2016. --------------------------------------------------------------------------------------------- 2011 had 6 inch ProComp lift, Eibach coils on 5100 Bilsteins at zero, 1/4 inch Toytec spacer on drivers side, rear TSB, 1.5 inch Deaver AAL, ProComp blocks and rear shocks, 8000 lb Warn winch on a Trans4mer grill guard, 33 inch BFG AT's, 18x9 XD Monsters, PIAA headlights, PIAA driving lights, Pyro's blue LED gauges, LED strip below tailgate, Armor Lid hard tonno, Hidden Hitch, Dee Zee bed mat, Tint, XM, Garmin GPS, Ultra Gauge
    Hey guys. I'm getting my ProComp installed soon and I have a question. Is it possible to get rid of the huge spacer and use the 5100's from the RCD kit along with Eibach springs instead? The shocks from the RCD kit are the right length for 4.5 inches of lift with factory springs and the Eibachs give 1.6 inches so I thought that together they would work with the ProComp 6 inch kit. I know I can get longer coilovers but that's overkill for a street truck. All comments welcome.
  2. Jan 19, 2012 at 3:07 PM
    705 Taco
    Dean
    2016 TRD OR AC
    Thanks Jay. I already have 5100's on my truck. I was planning on setting them at zero and reusing my Eibachs to help support the winch. Getting rid of the spacer just popped into my head so I posted the idea here. I don't need high end coilovers for my use and they also don't do well on Canadian salt sprayed winter roads. Can you give me thoughts as to why you don't think my idea will work?
  3. Jan 19, 2012 at 3:12 PM
    Motoxerc0
    Motoxerc0 Well-Known Member
    Colin
    New Jersey
    06 4x4 DC LB Lifted
    I don't see why you couldn't just keep your current setup. It would ride alright and if it's just being used on the street why change anything.
  4. Jan 19, 2012 at 3:16 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    :spy:
  5. Jan 19, 2012 at 4:52 PM
    705 Taco
    Dean
    2016 TRD OR AC
    I agree but it's just the spacer thing. Nobody likes them.
  6. Jan 19, 2012 at 4:59 PM
    705 Taco
    Dean
    2016 TRD OR AC
    What are you doing snooping around my thread nofords? :p
  7. Jan 19, 2012 at 5:00 PM
    Motoxerc0
    Colin
    New Jersey
    06 4x4 DC LB Lifted
    That is true. I would like to get a set of coilovers for my 6 in lift but i just can't afford it at the moment. If your truck is going to be used mainly for the street there is nothing wrong with the spacer and 5100. The only reason I will be upgrading is to give me better performance offroad and to compensate for the weight of my bumper.
  8. Jan 19, 2012 at 5:07 PM
    705 Taco
    Dean
    2016 TRD OR AC
    The Eibachs help support my winch/mount without sagging too much.
  9. Jan 19, 2012 at 5:12 PM
    Motoxerc0
    Colin
    New Jersey
    06 4x4 DC LB Lifted
    Well I would certainly stick with your current set up. It seems that you've got everything you need already. Why spend the extra money? My truck rides fine the way it is but like I previously stated I would like the coilover for my needs.
  10. Jan 19, 2012 at 6:01 PM
    PLC721
    Patrick
    Chandler, Az
    Oh I'm just creeping!
  11. Jan 20, 2012 at 4:21 PM
    705 Taco
    Dean
    2016 TRD OR AC
    It's good that your setup works well. I'm gonna run the Eibachs, the 5100's at zero, and the spacers that come with the 6 inch. Once I put a few miles on it and realize I like it I'll move on to something else. :D
  12. Jan 20, 2012 at 4:29 PM
    705 Taco
    Dean
    2016 TRD OR AC
    :cool:
