Eliminate water bypass hose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taccat, Feb 5, 2020.
  1. Feb 5, 2020 at 9:07 AM
    Taccat
    Taccat [OP] 2009 Base
    Caribbean
    2009 Base
    Hello Tacoma folks, I have a 2009 base Tacoma with a 2.7l 4cyl and a plastic bypass hose. I’m wondering if anyone has just removed the hose and had a cover made to seal off the opening? I live in an area where I NEVER use the heater. There’s a small hose that I believe connects to the throttle body, maybe I can connect that another way? Please let me know what you all think..
  2. Feb 5, 2020 at 11:01 AM
    81shark
    81shark Well-Known Member
    *plastic
    i forget what year they switched, but that part is now metal. if you want to do anything, just replace it with the new metal part.
  3. Feb 5, 2020 at 11:14 AM
    Taccat
    Caribbean
    2009 Base
    I know I can replace it with a metal one, trying to avoid all the work. Thanks
  4. Feb 14, 2020 at 5:12 AM
    Taccat
    Caribbean
    2009 Base
    Does anyone have an old plastic pipe that can send me a photo with dimensions so I can have a cover made? I’m also going to look into feeding the TB from the coolant pipe that connects to the output of the heater core, any thoughts? Thanks
  5. Feb 14, 2020 at 5:39 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    I'm thinking, and I could be wrong, but this project you have in mind might end up being more work and time spent overall than just replacing that plastic pipe.
    I've got the V6 so I don't know exactly what's involved in replacing your pipe. I know my bypass pipes will be a fun job though. Not!
  6. Feb 14, 2020 at 6:03 AM
    Taccat
    Caribbean
    2009 Base
    I think there would much less work involved with just capping it off than replacing it, you have to remove the intake manifold. I can install a cap very easily.
  7. Feb 14, 2020 at 6:12 AM
    Muddinfun
    Muddinfun Well-Known Member
    I wonder if coolant flow through the bypass pipe is a critical function of the cooling system when the thermostat is closed.
    b_r_o likes this.
  8. Feb 14, 2020 at 6:28 AM
    Taccat
    Caribbean
    2009 Base
    Yeah, good point, that’s why I posted the question, hoping someone with more knowledge chimes in. Thanks for you comment
    Muddinfun[QUOTED] likes this.
  9. Feb 14, 2020 at 7:34 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The intake manifold comes off pretty easily
    If deleting the bypass results in a overheat situation you'll spend more time screwing around with it than just fixing it correctly
    Muddinfun likes this.
  10. Feb 14, 2020 at 7:43 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Yes, this is why a coolant bypass exists, and has since at least the 1960s on many engines- it lets a small amount of coolant flow when the thermostat is closed. This helps the engine warm up evenly and is beneficial for the water pump as it's always turning.
  11. Feb 14, 2020 at 8:12 AM
    Taccat
    Caribbean
    2009 Base
    good to know, thanks
  12. Feb 14, 2020 at 8:28 AM
    Taccat
    Caribbean
    2009 Base
    thank you!
  13. Feb 14, 2020 at 8:43 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Steve is on the right track. There has to be some kind of flow through the cylinder head so the wax/spring side of the thermostat will get some hot coolant flowing over it. If you eliminate the bypass then you risk having the stat never open
  14. Feb 14, 2020 at 10:04 AM
    Larzzzz
    Larry
    MA
    Cool. Didn't realize the end you're concerned with had easy access. Good luck with your endeavor.
  15. Feb 17, 2020 at 6:16 AM
    Steve_P
    TN
    The water pump is turning if the engine is running. Without the bypass, if the heater core is valved off (heat is off) and the thermostat is closed (cold engine), the water pump is trying to pump coolant through a closed system. It can't- the coolant has no where to go. This should lead to cavitation in the pump - which is not a good thing. In addition, the bypass helps ensure the engine warms up evenly by allowing a small amount of coolant to circulate. The bypass is there for a reason.
  16. Feb 18, 2020 at 12:40 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no valve in the heater core piping.
    TnShooter likes this.
