Elite Bumper
Discussion in '1st Gen. Tacomas (1995-2004)' started by lennys, Aug 10, 2011.
  1. Aug 10, 2011 at 2:47 PM
    lennys
    lennys [OP] Well-Known Member
    Buena Park Hills Ca.
    02 Tacoma 4x4
    Looks like about 20 of you guy have this bumper now,what did you see for FT end sag with bumper and winch:confused:
  2. Aug 10, 2011 at 3:18 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ...wow..okay...well i guess ill save this ones soul..
    You will lots of sag on stock springs. Most ppl runnin bumpers and winches don't have stock spring and have upgraded so as to get a good lift and also not get any sagging.
  3. Aug 10, 2011 at 3:48 PM
    lennys
    02 Tacoma 4x4
    Its not stock,im running OME 882 but they saged alittle when I put then in.
  4. Aug 10, 2011 at 4:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    well ya every coil sags. It has too. otherwise the wheel wouldn't beable to travel down farther.
    882s according to wheelersoffroad are 500lbs springs. So i dont think they will sag a lot with a plate bumper but they will sag. They arent the highest rated spring like the 883s(590lbs) or Eibachs(620lbs). So basicly you traded a smoother ride for less spring weight preassure. Not a bad thing. But dont expect your truck to stay that height when you get one. A good option would be a tube bumper.
    Also...you leafs look like they are taking a beating with that arb tent..
  5. Aug 10, 2011 at 4:46 PM
    lennys
    02 Tacoma 4x4
    The way I took it from OME and Box Rocket that 880 were soft 881 med and 882 heavy
  6. Aug 10, 2011 at 4:57 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    882s are heavier duty but the 883s are the best OME offers. Then Eibachs are 620lbs. Then you get into coilovers.
  7. Aug 10, 2011 at 5:07 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I wouldn't run the bumper and winch without 600+ springs my eibachs were just right not bumpy and not all soft the rebound was nice. I haven't drove enough with the new setup to be able to tell you if the 600lb eibachs I have on now are just as good. Matched with the FOX shocks the ride is nice but I haven't really drove it on the freeway yet.
    I'm going to the 880 in Oakland this weekend to give them a test all of you bay guys know the 880 in Oakland :eek:
  8. Aug 10, 2011 at 5:25 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    I have a 102# bumper with an 80# winch. I have the OME 882 coils on my truck. They settled about an inch or so after I out it on. Yes you will want to upgrade your springs if you are going to add extra weight. Especially if you have a TRD. They are progressive springs so they are effected more so. As for the OME coils being progressive, no I don't believe that they are.
  9. Aug 10, 2011 at 6:20 PM
    MTNative
    MTNative Well-Known Member
    What and where did you get the tent from? I'm in the mood to get one.:D
  10. Aug 10, 2011 at 6:26 PM
    lennys
    02 Tacoma 4x4
    ARB tent and I ordered it from 4wheelparts just under $900
  11. Aug 10, 2011 at 10:14 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I replied to your question in my build thread since you asked it there. Just so you know.
    You can do a few things to reduce the weight of your winch setup when you get to that point. For instance, I've been looking at a XRC8. By moving the solenoid into the engine compartment, running a synthetic line and I also found a slick nylon fairlead that is super durable and weighs almost nothing, I can get the winch setup up under 50lbs. That is pretty darn good if you ask me.
    Plate bumpers are just heavy, no two ways about it. That's part of the reason I went with a tube bumper on my truck. For me, between the tube bumper and a "lightweight" winch setup I can keep the sagging to a minimum.
    But I will go on the record that I think the Elite bumpers are pretty sick.
  12. Aug 11, 2011 at 9:01 AM
    lennys
    02 Tacoma 4x4
    Thats the stock ft bumper wt
  13. Aug 11, 2011 at 9:08 AM
    TacoMatt02
    TacoMatt02 Well-Known Member
    South Carolina
    02 sr5 double cab
    if your really worried about sag you can always get an aluminum bumper from Elite which will be much lighter than the steel. It will still give you some clearance and be much stronger than a stock bumper. Plus you'll have the badass look of one of his bumpers.
  14. Aug 11, 2011 at 9:13 AM
    JLee
    Jerry
    Benicia, CA
    Yeah I don't recommend winching from a aluminum bumper if your going to add a winch go with steel. A long hard pull may bend an aluminum bumper.
  15. Aug 11, 2011 at 9:17 AM
    TacoMatt02
    South Carolina
    02 sr5 double cab
    agreed
  16. Aug 11, 2011 at 9:33 AM
    lennys
    02 Tacoma 4x4
    I want the bumper I may not put a winch in it
  17. Aug 11, 2011 at 9:35 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    better hurry and get in on the group buy then!
  18. Aug 11, 2011 at 9:37 AM
    JLee
    Jerry
    Benicia, CA
    Well if you want it for looks only go aluminum just don't plan on it protecting the truck like steel would (IE slamming it on rocks)
  19. Aug 11, 2011 at 9:46 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    does tim do aluminum?? i know eric does..
  20. Aug 11, 2011 at 9:49 AM
    JLee
    Jerry
    Benicia, CA
    Yeah he did one for a 2nd Gen so I'm sure he will for a 1st Gen.
