ELITE Long Travel!! Thoughts Please
Discussion in 'Elite Off-Road' started by Timicha, Nov 22, 2010.
  1. Jul 14, 2012 at 1:27 AM
    #141
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    I was assuming he had 8s. Which is what mid travel is supposed to have to be true mid travel anyways so i figured he did.
    :pout:
    darn haha
    Don't make me shell out for a Camburg kit! :eek:
  2. Jul 14, 2012 at 8:54 AM
    #142
    rcfreak201
    rcfreak201 Well-Known Member
    No, mid travel is OEM replacements, 8s is long travel. There's no way anyone could fit 8s with the stock coil bucket and LCAs. I mean theoretically you could if you could compress it that much but you would have no up travel and you would have to strap it. 8s would be useless without LT, nobody does that.
  3. Jul 14, 2012 at 9:35 AM
    #143
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pretty sure Jerry is running 2.5x8s on his stock buckest and LCAs..
  4. Jul 14, 2012 at 9:40 AM
    #144
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    There would be virtually no up travel with a setup like that. Most people who have mid-travel have OEM Replacements or a modified generic 6" C/O with a specific top plate for the vehicle.
  5. Jul 14, 2012 at 9:41 AM
    #145
    Blackdawg
    Monte
    Wyoming/St. Louis
    How would there be no up travel? with new UCAs wouldn't you be fine?
  6. Jul 14, 2012 at 9:45 AM
    #146
    Blackdawg
    Monte
    Wyoming/St. Louis
    Seems to have plently of uptravel with extended travel Foxs. and he has TONS of droop.
  7. Jul 14, 2012 at 9:46 AM
    #147
    theduck911
    Max
    Locked and Geared!
    No, because there is very limitied uptravel on a stock setup & with an 8" C/O the compressed length would be 2" longer (approximately) then a reg. replacement C/O limiting the uptravel by 2"
    UCA aren't usually for travel they are typically to correct wheel alignment which is asqued by lifts.
    An Extended travel C/O is not a 8" C/O it's really a 6" Coilover. That falls under the category of OEM replacement C/O's
  8. Jul 14, 2012 at 9:48 AM
    #148
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Not running 8's they are just extended length CO's
  9. Jul 14, 2012 at 9:49 AM
    #149
    rcfreak201
    It's not about the UCAs at all, it's the lack of space with stock LCAs and coil buckets. To fit an 8" coilover into the coil bucket with stock LCAs you would have to compress it so much that there would be very little room left for the shock to work, it would be all down travel that the stock components can't even handle so you would have to strap it.
    The reason people run 8s with LT is because on the new LCAs the lower shock mounts stick out more than stock which gives the whole setup more room to run a bigger shock which is an 8". Does that help? Haha
    Edit: seems like max and jerry explained it a bit better, hope it all makes sense :cool:
  10. Jul 14, 2012 at 9:49 AM
    #150
    Blackdawg
    Monte
    Wyoming/St. Louis
    UCAs i thought added like an inch of down travel ususally(with right shock) and corrected alignment(on 2nd gens, not needed on 1st gens)
  11. Jul 14, 2012 at 9:50 AM
    #151
    Blackdawg
    Monte
    Wyoming/St. Louis
    :confused:
    I though extended was 8"
    Gotcha. Well i new it was a wider stance and mount.
    so an extended CO is just 6''?
  12. Jul 14, 2012 at 10:17 AM
    #152
    rcfreak201
    Yup. IIRC extended vs standard is only 0.25" of a difference, Atleast for icons. I could be wrong but extended is definitely not 8".
  13. Jul 14, 2012 at 10:19 AM
    #153
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wow really? and that nets all that wheel travel? sheesh..
  14. Dec 29, 2012 at 3:53 PM
    #154
    Blackdawg
    Monte
    Wyoming/St. Louis
  15. Dec 29, 2012 at 5:18 PM
    #155
    Anthony250
    Anthony250 E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Yes as said thats not an 8" Coilover. Usually from what Ive measured stock replacements are about 4.75-5" Im guessing a Extended travel is about 5.5 or so.
  16. Aug 5, 2013 at 10:27 AM
    #156
    Hockeyman90
    Hockeyman90 Well-Known Member
    Kaleb
    Craig, Co
    2001 Gold SR5
    Custom front bumper, bed liner, 33" wrangler duratracs on 16" ATX series Mojave rims, OME 3" suspension, 882 coils, custom rear bumper
    Whatever happened to this idea? Did it get trashed or is it still in the works?
  17. Jan 9, 2015 at 6:20 PM
    #157
    Bigheadtinyarms
    Bigheadtinyarms Well-Known Member
    Seth
    Shoreline, WA
    07 blue Taco
    armor, lift, 35's, prinsu,
    Sub'd for updates
  18. Jan 9, 2015 at 6:23 PM
    #158
    Blackdawg
    Monte
    Wyoming/St. Louis
    Dream on. Tim is MIA and no one has heard from him in months and still owes people bumpers.
  19. Jan 14, 2015 at 9:31 AM
    #159
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    doesnt suprise me at all. i had a bumper from tim that bent to hell and back when pulling someone out of a snow drift. needless to say i said to hell with it and bought a relentless when i had my truck. hes not a very good salesmen at all. when there is a problem he trys to find everything that you could have possibly done wrong for something to happen. would not recommend to anyone
  20. Jan 14, 2015 at 9:34 AM
    #160
    Blackdawg
    Monte
    Wyoming/St. Louis
    Relentless isn't a much different design when it comes to the mounting plate/winch plate that bends. Mine bent too. Was stupid easy to fix that. Couple whacks with a hammer then i welded in 1/4'' plate behind the 3/16s to make it much stronger.
    That said. Not sure what happened to Tim really..
