Elocker rear end freespin?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cmuelrath, Nov 20, 2023.
  1. Nov 20, 2023 at 7:36 PM
    Cmuelrath
    Cmuelrath [OP] Active Member
    Colton
    2001 Tacoma 2.7
    I have a 2001 Tacoma open diff I bought a elocker complete rear axle for it. (I’m the bed of the truck right now) harness is cut a foot up from plugs. When I spin the yoke (driveline) the hubs don’t spin. It spins smooth with no grinding noise though. My question is is the rear end shot? Or is it not engaged at all because the elocker doesn’t have power. I know nothing about elocker rear ends so I’m going toward being blown but not sure
  2. Nov 20, 2023 at 10:13 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    An e locker rear diff functions like any other open diff when the locker is not engaged. When you turn the pinion it should do something at the hubs.
    Cmuelrath[OP] likes this.
  3. Nov 21, 2023 at 12:02 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I REALLY suggest that you do some more research on what you're getting into, and how differentials and lockers work in general.
    Swapping the whole axle housing in is all good, but have you done the research on what to do with wiring to engage the locker?
    Did you do your homework on the gearing of the new axle vs the existing axle?
    Are you going to rebuild the new axle before the swap? New bearings, seals, etc.. It's pretty un likely at this point that any tacoma axle wouldn't need to be serviced. Hell, even the 3rd member is probably due for a tune up. It's all a lot easier to do before you stuff that thing under the truck.
    Cmuelrath[OP] and 0xDEADBEEF like this.
  4. Nov 21, 2023 at 3:54 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Yeah I have the wiring diagram for the plugs to switch I’m going to splice wires. Just threw me off because the gears all seem fine. No noise or hangup etc. I’m taking the shafts all the way out pretty sure it’s a snapped shaft. And I’m if so going to just swap shafts over from my other axle with new axle bearings and seals
  5. Nov 21, 2023 at 3:59 PM
    02hilux
    Planet: EARTH
    Be hard to comprehend an elocked with a broken shaft still functioning as it should. If the PO managed to snapped the shaft, there's bigger issue.
  6. Nov 21, 2023 at 5:00 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    The truck I got it from was totaled in a head on. Think it may have happened in the wreck.
  7. Nov 21, 2023 at 5:52 PM
    02hilux
    Planet: EARTH
    If the shaft snap during an accident, the third member will be destroyed. The shaft is stronger than the third member.
  8. Nov 21, 2023 at 6:28 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    Thanks for the input. I’m going to tear it apart this weekend and check it out. If it’s screwed I’m gonna see about getting a refund (which I doubt I’ll get)
  9. Nov 21, 2023 at 6:30 PM
    02hilux
    Planet: EARTH
    What about spinning 1 drum, the other side spin? What about the flange?
    Andy01DblCabTacoma likes this.
