Emergency Brake Cable
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaman63, May 19, 2018.
  1. May 19, 2018 at 10:44 AM
    Tacomaman63
    Tacomaman63 [OP] Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
    About 5 years ago I had my emergency brake cable replaced because the light came on, on the dash. The light went away and everything was hunky Dory. Then about 2 years ago the light came back on, so I’m wondering what the hell is going on. It’s like the cable gets stuck or something. It always happened in the winter for some reason. I very rarely use my emergency brake but my wife used it once and the light cam back on. Whenever I push in the handle a little the light goes out but comes back on when I hit a bump.
  2. May 19, 2018 at 10:49 AM
    Sperrunner
    Sperrunner Respect the International Dibs Law
    Miguel
    Berkeley, Ca
    2016 ford transit
    Wd40, zipties, duck tape, and my hopes and dreams
    Maybe there is a short in the wireing or the sensor. Does your e break work just fine?
  3. May 19, 2018 at 11:12 AM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    I would say your linkage is hosed up and not fully releasing. I would check linkage underneath your frame at drivers door. Soak it good with liquid wrench or something like that. And make sure your bell cranks are not hanging up either.
  4. May 19, 2018 at 11:32 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    These trucks have a spring at the intermediate lever !!
    This needs to be lubed now and then I do mine every oil change .
    If you have winter the chemicals tend to make it hang up
    simple any easy before replacing cables
    My Parking Brake is always used
  5. May 19, 2018 at 11:35 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    makes me think you might have a loose e-brake handle. if it is the case, it easy to re-tighten it at the handle (under the dash)
    Then make sure your brake reservoir is topped up full (can make the light come on if it isn't)
    Kiloyard likes this.
  6. May 19, 2018 at 9:43 PM
    Glamisman
    Glamisman Well-Known Member
    ding ding ding ^^^
  7. May 19, 2018 at 9:53 PM
    Indy
    Indy Master of all I survey.
    The slack adjustment for the eb rake is under the cab iirc. Too much and the handle can slide out. It only takes a tiny movement got the switch to throw the light. Adjust the cable and should cease to be an issue.
  8. May 19, 2018 at 10:10 PM
    djohn24
    Dennis
    Pa
    What do we have for him Johnny???
  9. May 19, 2018 at 10:34 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    My money is on this answer!
    djohn24 likes this.
  10. May 20, 2018 at 1:37 PM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    Where are the bell cranks located don’t know much about e brakes
  11. May 20, 2018 at 1:56 PM
    djohn24
    Dennis
    Pa
    Follow your e-brake cable to the rear of truck. the e-brake cable t's off at the rear axle. Follow the cables to each wheel backing plate. You will see the arms the cable connects to. They are your bell cranks. Those arms should be close to touching the backing plates if they are free. Pull your e-brake and go to rear and see position of bell crank arms.They should pull away from backing plate. then release e-brake. They should move toward backing plate, almost touching.
  12. May 20, 2018 at 3:23 PM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    Thank you djohn
  13. May 20, 2018 at 3:27 PM
    djohn24
    Dennis
    Pa
    I hope this helps you. Your welcome
  14. Feb 7, 2019 at 2:04 PM
    tymeson
    tymeson Let's ride
    Steven
    N Phoenix
    03 Gold Prerunner
    Did you ever get this issue fixed ? I'm having the same problem... except I can hear a screeching noise, it sounds like it's coming from the right side. (I'm guessing one of the brakes is stuck) Today was 30° when I got in the truck and the light was on but the e-brake wasnt engaged.
  15. Mar 3, 2019 at 10:58 AM
    djohn24
    Dennis
    Pa
    You get it figured out?
  16. Mar 3, 2019 at 2:06 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    I would like to know the final diagnostic as well. I have the same issue. Thanks all!
  17. Mar 3, 2019 at 2:49 PM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    No I never got it fixed the weather has been crazy lately and I don’t have a garage. I’ve been looking around on here and maybe found a solution to this.
    Currygoat and TheFatWorm like this.
  18. Mar 3, 2019 at 3:58 PM
    djohn24
    Dennis
    Pa
    Ok
    Perfect Tacomaman63! I was going to tell Tymeson to check this area if the brake light is on. Wyoming09 mentions this & is what I was referring to last May in my post to you. That black lever under your drivers door can get hosed up from rust and not release properly. If your brake light is on. Get underneath and pull back on that black lever your brake cable is attached to. Then check your dash light and see if it went off.. I sprayed mine with liquid wrench and haven't had issues since.
    You mentioned weather... you must live in Pa! Its snowing again:rain: Thing is. On Feb 2nd Punxsutawney Phil did not see his shadow. Early spring my ass! lol!!
  19. Mar 3, 2019 at 4:13 PM
    Tacomaman63
    Stan
    2004 tacoma TRD 4x4
    Yes I’m from Pa and am sick of this snow lol As far as Punxsutawney Phil :brianr:
  20. Mar 3, 2019 at 4:15 PM
    djohn24
    Dennis
    Pa
    :brianr:to you Phil!
