Emergency Brake issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by germantaco82, Mar 19, 2021.
  1. Mar 19, 2021 at 6:12 AM
    germantaco82
    germantaco82 [OP] New Member
    El Paso, TX
    2011 DCSB OR
    I have a 2011 4dr TRD offroad Taco. I live in Germany currently and am going through the process to register my vehicle, which requires an inspection. During the brake inspection, my truck failed due to the e-brake grabbing significantly harder on the right side. There is no issue with the brakes using the pedal though.
    I had a local shop open it up and check it out, finding no issues. They attempted the normal adjustment under the center console and that didn't work either. On visual inspection I don't see anything wrong with the e-brake cable for either side and when looking at the mechanism under the center console, it appears to pull evenly on both sides.
    Is there any way to adjust just one side of the e-brake only, or do I just need to replace the cables and try again?
    Again, the extreme imbalance only occurs when using the e-brake, perfectly balanced when using the pedal brake.
  2. Mar 19, 2021 at 6:16 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    My right cable was broken. Use a Toyota cable as apparently aftermarket cables length may not be quite correct and it needs to be. Good luck!
  3. Mar 19, 2021 at 7:35 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are the shoes contaminated with gear oil on one side? That'll make them sticky
    6 gearT444E likes this.
  4. Mar 19, 2021 at 8:00 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I don't see any mention of adjusting the star adjusters on each side.
    SR-71A likes this.
  5. Mar 19, 2021 at 8:03 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yeah, between that and the in cab you should be able to get it dialed in.
  6. Mar 19, 2021 at 8:22 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Crawl under grab that side cable by the backing plate. Can you pull it away from the backing plate.
    our inspection here only requires parking brake to hold vehicle even if only one is working
    SR-71A likes this.
  7. Mar 21, 2021 at 8:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would adjust both sides rear brake IAW Toyota Specs and then see where it is. It seems one side is adjusted correctly and the loose side is not.
