Emergency brake light stuck on
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rngr, Jan 24, 2016.
  1. Jan 24, 2016 at 6:21 AM
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    2013 Tacoma. V6 AT. My emergency brake light on the dash stays illuminated constantly. This started earlier this morning after I applied the brake parking on a steep hill. The operation of the brake itself seems perfect. Set it, the truck won't move. Release it, it moves freely. However, with the brake released the light is still on and I get a beeping alarm when the trucks is in drive. Any ideas?
  2. Jan 24, 2016 at 6:50 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the brake fluid level, it will also illuminate this light.
    Fenwick1993 likes this.
  3. Jan 24, 2016 at 6:55 AM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Maybe switch popped out of its hole
  4. Jan 24, 2016 at 6:59 AM
    addicus24
    addicus24 Well-Known Member
    2015 Super White Tacoma TRD Off Road
    Bone Stock.Why mess with perfection?Except...
    I'm not an expert on these trucks, but I've read on TW that when you have a problem with lights/electrical, check the fuse first.
  5. Jan 24, 2016 at 7:37 AM
    rngr
    01 SR5 4x4 2.7L
    Thanks for the replies. I'll check all of that
  6. Jan 24, 2016 at 7:42 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This. One of the easiest things to check, and can oftentimes be the culprit. It was on mine!
  7. Feb 4, 2016 at 3:18 PM
    ervmcd
    ervmcd Well-Known Member
    Evan
    SLC, UT
    2014 TRD Off-Road DCSB
    Did any of these remedy the issue? My girlfriend is having the same issue on her 2nd gen.
  8. Feb 4, 2016 at 3:48 PM
    rngr
    01 SR5 4x4 2.7L
    Actually no. I zip tie holding some wiring that coming through the firewall has wiggled its way down and was depressing the switch. I guess I failed to notice it during my initial inspection before creating this thread. Fortunately it was a very simple fix. Good luck to you in your troubleshooting.
