emergency brake not completely disengaging
Discussion in '1st Gen. Tacomas (1995-2004)' started by devilsalmostfree, Dec 26, 2010.
  1. Dec 26, 2010 at 11:51 AM
    devilsalmostfree
    devilsalmostfree [OP] Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    this morning, got in the taco, released the e-brake lever. started to move, but the e-brake felt like it was still on. this happened a few times last winter, but only when the temp. gets like 30 or lower. any ideas of what i should do, it will eventually completely disengage after i go down the road a bit!
    also, my e-brake light has been staying on even though my e-brake isnt on. this happened a few years ago too, but one of my friend's adjusted something, but im not sure as to what he did! wondering if u all may have had this same thing happen? any words of wisdom for me on this or the above would be greatly appreciated.
  2. Dec 26, 2010 at 6:35 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i have the same problem. the cold freezes mine engaded and i have to get under the truck and bear it with a monkey wrench every morning and jiggle it around a little bit before it breaks free. the brake light is probably because its still not full "off" or your brake fuild level is low check that.
  3. Dec 26, 2010 at 6:55 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    In the winter with wet, slushy roads, it is possible for the E-brake to freeze up. I just use diligence in not setting it if I've been driving in wet conditions and the temp is freezing or below overnight.
  4. Dec 27, 2010 at 6:15 AM
    devilsalmostfree
    Carl
    Loudon, Tn
    ive checked the brake fluid, but i will check it again today, thanks!
    yeah thats what i did last winter, guess ill just have to do it again this winter!
    thanks for ya'lls input!
  5. Dec 27, 2010 at 6:36 AM
    saweetlou
    saweetlou Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    My light was staying also till I figured out that the cable had a kink in it right where it goes through the fire wall, this didnt allow the pb handle to hit the switch for the light to go off, so I got a spring that was about 4in long went underneath the truck (driver-side)where the lever is (connection between the front cable and rear cable) and stretched the spring from the lever to the frame. Now when I disengage my parking brake it practically slams to the stop, Works Great
  6. Dec 27, 2010 at 6:50 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Been the victim of a frozen e-brake before, now it doesn't get set when it really cold out (30° and below). if you live on a hill, get a wheel chock or ?? to put behind the tire, (or to drive over top of and rest/roll it back on), then release the brake. or find a flat and level spot and just leave it off.
    Pop's digs a hole in his gravel driveway to park his tire in.
  7. Dec 27, 2010 at 12:09 PM
    devilsalmostfree
    Carl
    Loudon, Tn
    thanks man, ill check the cable to make sure!
    yeah, last winter i carried a small brick with me, will do that again this year, thanks!
  8. Jul 9, 2011 at 7:04 AM
    beerdrinkr
    beerdrinkr Well-Known Member
    justin
    Florence,Ky
    11 double cab trd offroad
    So has there ever been a fix for this? Just got my truck and my buddy has had 2 of the 2nd gens. both his did it. There is no way for me to avoid water as i have to cross it to get up the hill to my house...
  9. Jul 9, 2011 at 7:08 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    my e brake light was always on, on my 99. i think it was from the lift
