Emergency Brake Problem
Discussion in 'Technical Chat' started by toyhunta, Oct 17, 2009.
  1. Oct 17, 2009 at 11:01 AM
    toyhunta
    toyhunta [OP] New Member
    tacoma sr5
    tow hitch
    I recently replaced my pads on the rear brake drums. After the replacement I had a lot of slack in my emergency brake. I tightened the cable, which took the slack out of it but my e-brake will not hold my truck even on gentle slopes. Any ideas where I screwed up.
  2. Oct 17, 2009 at 11:21 AM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    check to make sure the brakes are adjusted properly.did you have any problems with the parking brake before?
  3. Oct 17, 2009 at 2:28 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Try pushing the brake pedal down before engaging the emergency brake. If they still fail to engage your brakes need adjustment.
  4. Oct 17, 2009 at 3:43 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you replaced the shoes.... did you 'adjust' the star wheel to adjust the shoes?
    I'm not sure if this will work or not, but worth a try.... Go in reverse and step on the brakes while in reverse. Try that a few times. I'm not exactly sure but some vehicles brakes adjust while in reverse.
    If that doesn't help... take the wheels off again and take the drums off. If the drums are very easy to remove, then the shoes aren't set tight enough. You'll have to adjust the star wheel to tighten things up. They really should be tight enough that you can just slide the drums on with a bit of resistance.
    Then...if you make adjustments to the star wheel - you'll probably have to adjust the emergency brake cable again because it'll probably be too tight.
  5. Oct 18, 2009 at 2:38 AM
    JDCPA
    Jim
    SW FL
    What she said.
    I'd dosconnect the emergency brake cable before adjusting the star.
