Emergency Breakin My Balls
Discussion in '1st Gen. Tacomas (1995-2004)' started by sikora8, Jun 5, 2010.
  1. Jun 5, 2010 at 4:03 PM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    Does anyone know how to adjust the emergency break on an 04 Tacoma SR5...it is drivin' me nuts...I turn and release but have to mess with it 4 or 5 times to get the light to go out...Let me know.
  2. Jun 5, 2010 at 4:07 PM
    747 function > form
    1st Gen.
    Subscribed.
  3. Jun 5, 2010 at 5:00 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    If you look under your truck there is a cable coming from both rear brake drums at about a 45 degree angle to the middle. Then a lever assembly and a cable going to the cab. The lever assembly should have a bolt and nut and you can tighten the nut and it will make your handle harder to pull. About 12 clicks is what you should have before you can't pull any more. Page "BR-8" in the fsm.
  4. Jun 5, 2010 at 5:03 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
  5. Jun 5, 2010 at 5:03 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Adjuster is under the driver's seat along the inside of the frame if I remember correctly.
  6. Jun 5, 2010 at 5:13 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    the brake switch might be sticking. check that first id say.
  7. Jun 5, 2010 at 5:44 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    The same thing happened for me, and it pissed me off, then after going through winter, it hasn't stuck yet :D
  8. Jun 5, 2010 at 6:06 PM
    747 function > form
    1st Gen.
  9. Jun 7, 2010 at 6:19 PM
    sikora8
    04' SR5
    Awesome site...thanks for the info...very helpful.
  10. Jun 7, 2010 at 6:25 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Great thread I love learning stuff on here!!
