Emergency lift help
Discussion in '1st Gen. Tacomas (1995-2004)' started by bighungitacoma, May 31, 2010.
  1. May 31, 2010 at 3:33 PM
    bighungitacoma
    bighungitacoma [OP] Well-Known Member
    ok, so im stumped...im installing a toytec ultimate lift on my truck right now...but cannt get the coilovers to fit. i did not raise them anymore from how toytec sent them to me. i already have the diff drop installed, and have the top 3 strut bolts loosely screwed on to hold up the co, but the lca will not go down low enough to allow me to put the bolt through the lower shock mount. i have already disconnected the sway bar. any ideas?
  2. May 31, 2010 at 3:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Loosen the lower control arm from the bottom of the spindle. There is 2 bolts. That will allow it to drop and give the required clearance.
  3. May 31, 2010 at 5:40 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Make sure you have the sway bar removed. I had it on, and was trying to get mine in. And it was a bitch. But if it is or ready, chris's idea is a good one! :)
  4. May 31, 2010 at 5:45 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Waco, TX
    05 TRD offroad SR5
    Legs- --Helo rims --Duratrac 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
  5. May 31, 2010 at 5:50 PM
    Cyrusjj
    Cyrusjj Member
    Los Angeles
    04 Tacoma Prerunner
    All Pro Bumpers front and rear Allpro skidplate 3" coilovers Snugtop Toytec 1.5 inch rear lift
    Get a friend to stand on it and push down with his legs.
    I did mine without disconnecting the sway bar.
  6. May 31, 2010 at 5:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    use the old "stock truck jack" trick..........flip it upside down on top of the uca....then run it out.
  7. May 31, 2010 at 6:01 PM
    bighungitacoma
    thanks guys...except for the "man up" kid...that didnt really help me out...but had someone come stand on it and it worked out
  8. May 31, 2010 at 6:04 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I did this today for my 881's. Not as much lift as the toytec kit is giving but this trick works very well.
  9. May 31, 2010 at 6:25 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Ya when I put OME in I disconnected the sway bar and fit it in there with a little brute force.
  10. May 31, 2010 at 8:37 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
  11. May 31, 2010 at 8:39 PM
    ubnpast
    ubnpast Well-Known Member
    Central Jersey
    a tip for you guys when reinstalling the stut/spring assy, it may be tough to get the lower bolt in, but what made it EASY was when I took my 1/2 breakerbar and layed it on top of the upper control arm, the handle of the breakerbar was under the upper control arm mount (in the 1/2"-3/4" space between the UCA and the part where it mounts to the truck), once the breaker bar is in there put a big 3' pipe on the socket end and push down, within a few seconds you can slip that bolt right in (easier if you have 2 people), this is the safest and quickest way I have done. You dont have to remove or disconnect the sway bar, SAVE TIME TRY IT, IT WORKS!
  12. May 31, 2010 at 8:55 PM
    bighungitacoma
    haha, thnks for all the advice guys...i got the front all set up, and to my dismay, when i was torquing down the top strut mounts on the passenger side to factory specs (like the instructions said), one bolt just broke right off, like really easily...so right now i have two, and have to call toytec tomorrow about the manufacturer defects warranty...so i gave up after the front because of how pissed i was at that...ill throw the AALs on there tomorrow and throw up some pics...id put pics up now but its got a gnarly so cal lean to it right now..haha
  13. Jun 2, 2010 at 8:06 AM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    PM sent.
  14. Jun 2, 2010 at 9:52 AM
    bighungitacoma
    ok, so update time...i called toytec and explained the situation, and after being on hold for all of MAYBE 30 seconds, they let me know that some new studs were on their way for that top bolt and they would be shipped out that day. i think i can honestly say toytec customer service is the best ive ever had to deal with. and now...
  15. Jun 2, 2010 at 9:57 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Nice!
    I used a pipe to pry down the LCA in order to get the strut in the housing after bolting the top. From there I used big screwdrivers on both sides to work the strut until it lined up so I could slip the bolt in. First one took forever to figure out, after that the next was easy.
  16. Jun 2, 2010 at 5:18 PM
    thekidcatcher
    Waco, TX
    05 TRD offroad SR5
    Lol I am just kidding man. I have installed a few of them and found that if ya push them down hard enough you can get it by yourself. Works a lot easier with two though :D
  17. Jun 2, 2010 at 5:30 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Toytec to the rescue. I enjoyed my ULK when I had it on and would reccomend them to anybody. Just don't turn them up too high or you'll start blowing CV boots like I did. I just swapped mine out for an RCD and love it.
  18. Jun 2, 2010 at 5:37 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    03 DCSB
    magnaflow cat back exhaust, K&N filter, gray wire, deck plate, ome 883's, ome dakar leafs, bilstien 5100's, blacked out grille, AVS bug shield & window vents, arb bull bar, hella 5in lights, mile marker 8k winch, debadged tailgate, energy steering rack bushings, custom rear bumper w/ hidden receiver, custom headache rack, ome greasable shackles, 4.88's w/solid spacer, SS extended brake line
    get a big pry bar
