Emergency lighting
Discussion in 'Lighting' started by Tacomamedicman13, Dec 1, 2010.
  1. Apr 17, 2012 at 3:57 PM
    #201
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  2. Apr 17, 2012 at 5:25 PM
    #202
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
  3. Jun 13, 2012 at 7:56 AM
    #203
    BBJ285
    BBJ285 Well-Known Member
    Scurry, TX
    03 Pre-Runner
    SnugTop cap, "SuperSpring" helperspring, flowmaster muff,K&N CAI, CB, small amp & 2 6x9s in the bed on a toggles switch for nights at the drive-in...
    What are some of y'alls opinions on color as far as LED hide-a-way in the front corners? Red, White, or both? I'm leaning toward Red/Red in the rear back up lenes. Just undecided on the front.
  4. Jun 14, 2012 at 9:20 PM
    #204
    taco1234
    taco1234 Well-Known Member
    texas
    09 PreRunner
    amazing setup i love it
  5. Jun 30, 2012 at 11:51 AM
    #205
    kodybradford
    kodybradford Member
    Kody
    Kentucky
    2011 TRD Sport 4dr Long Taco
    Where did you mount the whelen hhs2200 siren and how painless was the install? How do u like the system overall?
  6. Jul 1, 2012 at 5:00 AM
    #206
    kd8bao
    Henry
    Cleveland
    I had a small multi mount that I put in the coin tray to hold the handset
    Here is the brain box mounted behind the passenger back seat.
    I drilled a 1" hole on the lower left corner of the utility box to pull all the wires and run them under the sill plates
    And the siren and light controller is pc programmable.
  7. Jul 1, 2012 at 8:32 AM
    #207
    Volfiretaco
    Volfiretaco Member
    Tuftonboro,NH
    11 Tacoma Doublecab
    3" lift, reinforced front bumper from road armor, plastidiped rims and badges
    I mounted the main unit behind the back drivers side seat in the capartment 2012-07-01 11.23.16.jpg
    i then mounted the controller in the garage door opener compartment i had to do a little trim work to the door to get it to fit but when it is in there the button on the outside can work the air horn or the 3 button function.
  8. Jul 1, 2012 at 11:47 AM
    #208
    kodybradford
    kodybradford Member
    Kody
    Kentucky
    Looks like this is going to be the way to go! Thanks for the help!
  9. Jul 9, 2012 at 8:29 AM
    #209
    kodybradford
    kodybradford Member
    Kody
    Kentucky
    Does anyone have pictures of lights being put into a hood scoop on the Tacoma's? If so what leds did you use and how bad was the install. I know this is a previously discussed topic but my ability to view the videos from Afganistan are limited and I believe that is all that had been posted.
  10. Aug 11, 2012 at 8:17 AM
    #210
    kd8bao
    Henry
    Cleveland
  11. Aug 12, 2012 at 2:13 PM
    #211
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
  12. Mar 3, 2013 at 9:50 PM
    #212
    dylanray
    dylanray Active Member
    dylan
    henderson
    i installed a memphis 10 in a custom sub box and put a kenwood radio in, fire lights
  13. Mar 5, 2013 at 5:42 AM
    #213
    BBJ285
    Scurry, TX
    03 Pre-Runner
  14. Mar 6, 2013 at 4:50 AM
    #214
    kd8bao
    Henry
    Cleveland
    The LP lights are axxitech XL6. I made a bracket for behind the plate to hold lights. Both the front and rear are for sale if interested just send me a PM.
    As far as the high mount. I took out 2 of the 3 lights and replaced with LED HAW from Strobes and more. However I will be replacing and upgrading them to the Feniex Cannon shortly. The Cannon has a dual function so it will function as a brake light and then also as an emergency/warning light. We sell them also through our store front as well.
    The LP Lights are on the store also.
    http://wiredinstallation.com
    Thanks for lookin.
  15. Jun 25, 2013 at 11:05 PM
    #215
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I have a BAMF light bar how or what kind of lights can I use w/ it? I would rather not have to drill or anything into truck...
  16. Jun 25, 2013 at 11:54 PM
    #216
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    I was just in the process of doing this exact setup for my switches, except different labels. My 6 switches will be:
    Front LEDs
    Rear LEDs (up-flash / down-directional)
    Directional control (up-left / down-right)
    Wig-Wags
    Left alley
    Right Alley
    Or I may change the last 2. Instead of separate alleys, I'll combine into 1 switch does both alleys and my last free switch will be strobes if I add them.
    Then my 2 switch blanks on the left of the steering wheel will be rear back up lights and front led bar for off road use.
    Here is my current lighting setup. I will be changing the front LEDs though. Instead of amber/white they will be amber/green.
    FRONT:
    REAR:
    SIREN:
    SWITCHES SOON TO BE ELIMINATED AND REPLACED WITH 6 CUSTOM OTRATTW SWITCH PANEL ON SUNGLASSES HOLDER:
    AND A VIDEO
    https://www.youtube.com/watch?v=Gs5z8NP9W7I&feature=youtube_gdata_player
  17. Jul 20, 2013 at 12:47 PM
    #217
    BBJ285
    Scurry, TX
    03 Pre-Runner
    NICE SET UP /\
  18. Jul 20, 2013 at 12:59 PM
    #218
    ProForce
    Anthony
    Alaska
    Thanks! These are the new switches
    uploadfromtaptalk1374350359230.jpguploadfromtaptalk1374350370952.jpguploadfromtaptalk1374350383553.jpg
  19. Jul 20, 2013 at 1:04 PM
    #219
    Traction120
    Traction120 "Not all those who wander are lost"
    Nathan
    Reno, NV
    2013 DCSB BLK
    SEE BUILD.
    Sub'd for future endeavors
  20. Jul 22, 2013 at 3:34 PM
    #220
    badphish14
    badphish14 Well-Known Member
    Long Island
    '12 TRD OFF ROAD
    I guess my old dash king isn't cutting it these days?!
    Always wanted to do the grill lights just never wired up extras on the truck yet and didn't want to fry anything. I'll add that to ever growing list of extras I need/want!
