Emergency need your help!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob1, Aug 19, 2009.
  1. Aug 19, 2009 at 4:38 PM
    rob1
    rob1 [OP] Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Guys I'm changing my oil and just realized that I got the wrong oil,is 5w-20 instead of 5w-30. what do you recommend????
    I already poured in 3 qrts.!!!:eek::confused:
  2. Aug 19, 2009 at 4:41 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    drain em , refill with the right one, whats left shouldnt matter. or call dealer and see if 1/2 n 1/2 is safe per your model year and engine.
  3. Aug 19, 2009 at 4:45 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 You'll be fine, just drain it and refill ;)
  4. Aug 19, 2009 at 4:45 PM
    KodiakVA
    KodiakVA Well-Known Member
    Richmond Virginia
    09 4x4 XCab Sport BarcelRed
    IMO Since the deed is done just use it. It won't hurt anything. Use the right stuff next time.
    Don't say anything to your dealer, because of warrenty issues. Just use the 5W-30 next time. You might even see a slight MPG boost.
  5. Aug 19, 2009 at 4:46 PM
    rob1
    Robert
    South Texas
    what if I buy two 10w-30 and mix it?? Would hate to drain it, it's Royal Purple Synthetic.
    What do you all think??:eek:
  6. Aug 19, 2009 at 4:47 PM
    KodiakVA
    Richmond Virginia
    Skip the mixing and use the same thing this time. Pity to dump Royal Purple anyway.
  7. Aug 19, 2009 at 4:47 PM
    ColtsTRD
    Scott
    AZ
    Drain it man, it might ruin your life if you don't lol
  8. Aug 19, 2009 at 4:50 PM
    2k6750
    2k6750 Well-Known Member
    Naples FL
    2005 SWB Prerunner Double Cab TRD Offroad
    Toytec coilovers set at 3", 5100 shocks all around, rear AAL and 1"block, 18" Moto Metal 951's with 285/60/18 Terra Grapplers, Leer Topper, de-badged, T-rex billet grille, BHLM, K&N intake, Jardine catback, Doug Thorley Long Tube headers, 8" kicker solo barik, Clarion 7" in dash dvd player. 12.1" flip down screen
    Just use what you've got this time, switch to the right weight next time. Won't hurt anything.
  9. Aug 19, 2009 at 4:51 PM
    rob1
    Robert
    South Texas
    my wife just said I'm living up to my picture here!!!!!:rolleyes::eek:
  10. Aug 19, 2009 at 5:06 PM
    rob1
    Robert
    South Texas
    thanks scott:smack:.....:p
  11. Aug 19, 2009 at 5:20 PM
    rob1
    Robert
    South Texas
    o.k guys Thank You for helping me out....laters:)
  12. Sep 1, 2009 at 11:02 AM
    rob1
    Robert
    South Texas
    Just an up-date on what happened. Everything is running good took a trip to Chorpus Christi with no problems and yes I left in the 5-20w Royal Purple in and yes I am getting more mpg's but worryed about protection, well drain at 3000 miles and will be sure to put in 5w-30. Usually leave in 5000 but it's been dam hot over 100 the past 3 weeks so concerned about the protection in the long run, again thanks for those who responded and hope this helps someone else who makes an honest mistake....:rolleyes::p
