emission testing
Discussion in 'Performance and Tuning' started by claymore, Oct 14, 2012.
  1. Oct 14, 2012 at 12:26 PM
    claymore
    claymore [OP] Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    Has anybody passed emission testing with the URD TCAI and MAF calibrator?
  2. Oct 15, 2012 at 5:30 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You're going to need to let us know what NM has for testing? Visual, sniffer, OBDII check, etc.
  3. Oct 15, 2012 at 5:58 AM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    What is Tested
    The actual test assesses three elements on the vehicle:
    • Smoke puffing from the tailpipe or other areas of the auto.
    • The effectiveness of the catalytic converter, which is the essential module in controlling pollution.
    • A computerized gas analysis measured via the exhaust pipe while the vehicle is idling and at high speed.
    Copied this off the DMV website. They hook up something to the OBDII and stick sometging in your exhaust. They also check your gas cap.
  4. Oct 15, 2012 at 6:28 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My opinion is that you shouldn't have a problem then. The CAI/MAF Cali should not affect the tailpipe emissions nor should it set a code. The CAI could fail a visual if there needs to be a CARB-like sticker proving certification, but I think that is only for CA. Do keep in mind though that if you disconnected the battery to install the CAI/MAF Cali that the ECU needs some miles and driving cycles to get itself out of the freshly-powered-on setting (I've forgotten the actual term for this) such that an emissions OBDII scan will be successful.
