Emissions Drive Cycle Too Long To Complete
Discussion in '1st Gen. Tacomas (1995-2004)' started by STOCKTRD, Jul 16, 2021.
  1. Jul 16, 2021 at 6:41 PM
    STOCKTRD
    STOCKTRD [OP] Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
    2001 v6 5-speed. I got a check engine light about two days ago for code p0440. I replaced the gas cap with a Stant from oreilys and used my obd scanner to clear the code. So far I have driven it about 170 miles or so over a period of two days and I still have not got the check engine light to come back. But when I check for codes the evap system still hasn’t did a full drive cycle. It still comes up as the evap test has not been completed yet. I’ve done all the drive cycles and only with the tank 3/4 to 1/4 full. Does it usually take this long to reset? Am I missing something? Thanks in advance.
  2. Jul 16, 2021 at 9:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It can be tricky to get monitors to run sometimes, here's the OE drive pattern for all the monitors if that helps.
    Area51Runner and crazytacoman like this.
  3. Jul 16, 2021 at 11:37 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    @Dm93, thanks. I will see if this works.
  4. Jul 17, 2021 at 2:00 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    They can sometime be a royal pain sometimes some of my tests take over a 1000 miles after numerous drive cycle attempts.
    Good luck
  5. Jul 17, 2021 at 2:49 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Out of curiosity, did you get an actual EVAP test prior to replacing the cap?
  6. Jul 17, 2021 at 3:51 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Myself go with the cheap fix first why spend more money if you don`t need to.
    If that fails to fix things then trouble shoot as needed.
  7. Jul 17, 2021 at 4:15 AM
    RedWings44
    Michigan
    I guess it just depends on the cheapest fix. In some cases though I definitely agree. You can justify it by saying "a new one isn't going to hurt and I'll probably need it eventually anyway." But it's easy to fall down the rabbit hole and keep doing that and eventually all you've done is throw parts at it. Sometimes it works out though.
  8. Jul 17, 2021 at 4:20 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Granted it only works on a few things like fuel caps and radiator caps
    RedWings44[QUOTED] likes this.
  9. Jul 17, 2021 at 4:51 AM
    RedWings44
    Michigan
    I did it on my last truck as well with an EVAP purge solenoid. Neither that or the gas cap solved the problem.
  10. Jul 17, 2021 at 11:45 AM
    Glamisman
    Glamisman Well-Known Member
    you did see where they tell you there must be a "cold soak" and that this has to happen 2 times?
  11. Jul 17, 2021 at 6:45 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    Update: I spent all day yesterday just driving the truck and I couldnt get the EVAP system to test. Everytime after I drove the truck I checked the codes with my OBD scanner and it wouldnt test. So thanks to the info that @Dm93 sent I got it to actually test a cycle and the code came right back, P0440. So if anyone wants to know the "DRIVE PATTERN NO. 5: EVAP Monitor" worked for me. So now that I know the cap didnt fix it I have to start figuring it out.
  12. Jul 17, 2021 at 8:05 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    P0440 is a Large Leak, I'd start by checking all EVAP hoses, canister, and filler neck for cracks or visible leaks.
    If you cant find anything you will probably need someone with a smoke machine and scanner to find it.
  13. Jul 19, 2021 at 3:19 PM
    STOCKTRD
    In Traffic
    CustomTacos Mafia!
    Well guess what? The code went away. Not sure how or why but its no longer coming up on the OBD scan tool. Ill update if it comes back.
