Emissions Problem - Failed Smog
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000 Tacoma Black, May 14, 2018.
  1. May 14, 2018 at 7:13 PM
    02hilux
    Planet: EARTH
    Your vehicle is a 2003, all module must be complete and ready
    But back on topic, op I believe most auto parts store now can read your code for free. Erase the code with a scanner or unplug your battery cable. If the mil light chieme back on, get it check if it's the same code or not. Best is to buy a scanner and use it every other day to check your truck status.
  2. May 14, 2018 at 7:19 PM
    ArtP
    ArtP Well-Known Member
    Art
    Lake County, CA
    2003 Tacoma 4x4 Manual TRD
    Please re-read what you found and quoted. Post 2000 vehicles.
  3. May 14, 2018 at 7:22 PM
    2000 Tacoma Black
    2000 Tacoma Black [OP] Well-Known Member
    2022 Tacoma DC Off Road / 2000 Tacoma Prerunner
    That’s what I originally thought.
  4. May 14, 2018 at 7:22 PM
    02hilux
    Planet: EARTH
    Correct, they allow 1 module post 00, but all local smog shop here will not allow smog until all are ready. Been like that for 3 or so years now here. Maybe your county is different. Just like some county in California, all smog is exempt on their vehicle.
  5. May 14, 2018 at 7:23 PM
    ArtP
    Art
    Lake County, CA
    OP: Just know every time you disconnect your battery, all those test will have to run all over again.
    Something I learned from the literature from the official CA ref in my area - different vehicles have different issues when it comes to completing the test cycles. It is noted in their literature, late model first gen tacoma's - "completing the test cycle is excessively difficult". Actually it is all Toyota's of that era.
  6. May 14, 2018 at 7:25 PM
    02hilux
    Planet: EARTH
    Same for when you erase the code. It all clear out. But if your mil light is on, what are you suppose to do? Keep driving it until it turns OFF? Won't happen, so you will have to clear the code regardless to turn the light off and drive until cycle is ready or mil turns back on.
    Op mil light is on. Clear it and see if it'll turn back on.
    2000 Tacoma Black[OP] likes this.
  7. May 14, 2018 at 7:28 PM
    ArtP
    Art
    Lake County, CA
    I'm not a mechanic, but as stated, I've researched it to death recently as well as made one of my first posts here, on this subject. The other members basically said the same as what I'm quoting, less CA regulations. I actually wish I had a CEL so I'd know where to go.
    What I've been doing is driving it anyway with expired registration, with all my fees paid up, less the smog cert. If I get pulled over, I simply hope a cop will let it slide, knowing I paid my fees, have done everything I can to get this thing to complete its cycles. Fortunately it's my off-road camping truck and I have a small import for a daily.
  8. May 14, 2018 at 9:54 PM
    2000 Tacoma Black
    Yeah you have to drive at a certain speed for a certain amOunt of time, very specific terms depending on the vehicle right?
  9. May 14, 2018 at 10:17 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    There is no way of getting around this, if the inspector cant read it you will fail, unless you have the paper work to prove it is CA legal. Your options are really just replace it or keep going to smog shops till you get a guy that just doesn’t care. 2000 and up cars do not do the tail pipe test just the scan with obd2 and visual.
    I have a 04 and just passed smog the other week with an after market intake that i had the carb sticker for, without it i would of failed. No clue if my cat number is visible but i did see the guy look down there and i passed so i guess it is.
  10. May 14, 2018 at 10:28 PM
    Juan's Taco
    Juan's Taco Well-Known Member
    Just do the smog under the table if you don’t wanna do repairs or deal with it. My dad smogs he’s 1998 Chevy Tahoe and it passes even with no cat.
  11. May 14, 2018 at 11:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Problem is you need to know a guy to be able to do that
  12. May 15, 2018 at 8:58 AM
    2000 Tacoma Black
    Have you had any issues in the past with the K&N, and do you have the CARB sticker on your K&N filter?
  13. May 15, 2018 at 9:00 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Nope not one issue as I've got the CARB EO # decal on the firewall
  14. May 15, 2018 at 9:35 AM
    2000 Tacoma Black
    I googled...
    So, in looking at this thread, post #8, it looks like I need to take it through the drive cycle, which is pretty complicated and specific.
    https://www.tacomaworld.com/threads/obd2-not-ready.332327/
    And
    Post #4
    http://www.customtacos.com/forum/127-1995-5-2004/65696-won-t-pass-emissions.html
    If I'm remembering correctly, the last time my battery was disconnected was about 9 months ago. Seems strange that I haven't somehow go through the sequence needed to run the test.
  15. May 15, 2018 at 9:38 AM
    #35
    2000 Tacoma Black
    Isn't the evap incomplete the "OBD II?"
  16. May 15, 2018 at 9:39 AM
    #36
    2000 Tacoma Black
    Now I am wondering if they input the CARB code for the K&N intake filter the other day for the 2018 smog check, bc I think in 2016 once I had that, it passed.
  17. May 15, 2018 at 9:40 AM
    #37
    ArtP
    Art
    Lake County, CA
    I've gone five months and almost 2k miles and my catalyst hasn't completed either. I have a challenge where I live. It's hilly country with two-lane highways. From a cold start, unless I park it on flat land overnight, is an hour away. Some of the test cycles use the term "cold soak". After googling I'm led to believe it means starting with internal engine temp the same as ambient.
    I'm considering the underground route. My county only requires smog on ownership change, not at set intervals. Lucky there.
  18. May 15, 2018 at 9:43 AM
    #38
    2000 Tacoma Black
    Maybe I should take it out and drive at the speeds / conditions for the recommended intervals then. I think I'll get a scanner to see if there's any other codes the smog place didn't tell me about first though.
  19. May 15, 2018 at 9:44 AM
    #39
    2000 Tacoma Black
    By the way, can you show me a link to the kind of scanner you are referring to?
    I read that you can borrow one from an auto parts store for free, but I have to call and find out.
  20. May 15, 2018 at 9:45 AM
    #40
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I had a very similar problem when it came time to smog my truck in CA last year, I threw a P0420 code and took it into the shop where they told me that the front cat was bad and that I should replace both (when one goes it usually means the other is not far behind). Toyota wanted over $2k to replace both with OEM cats so I ended up going with Magnaflows instead...not many options available for CARB approved cats but they made some for much cheaper...think I paid $600 to have both replaced with the Magnaflows. Code went away and I passed smog with flying colors.
