Emissions Problem - Failed Smog
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000 Tacoma Black, May 14, 2018.
  1. May 15, 2018 at 9:46 AM
    #41
    ArtP
    ArtP Well-Known Member
    Art
    Lake County, CA
    2003 Tacoma 4x4 Manual TRD
    You have Android or Apple? I have android and bought this one. https://smile.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
    It requires a $5 app from the playstore. I bought one called "Torque". It's the most popular and you won't have any trouble finding it.
    I think you're going to need one, vs borrow. I've probably checked mine ten times and I can't imagine trying to borrow or rent one.
  2. May 15, 2018 at 9:48 AM
    #42
    2000 Tacoma Black
    2000 Tacoma Black [OP] Well-Known Member
    2022 Tacoma DC Off Road / 2000 Tacoma Prerunner
    Thanks for sharing your story, it is helpful. That is the situation I thought I was in before I started thinking about my past inspections and googling around. If that is the end situation, I'll think about the magnaflows. I just don't want to replace them just yet, and still don't pass because it's not the true issue. Or unnecessarily replace them for $600 if not needed.
    Are you a Tool fan, eon blue?
    eon_blue[QUOTED] likes this.
  3. May 15, 2018 at 9:49 AM
    #43
    2000 Tacoma Black
    Apple 5s
  4. May 15, 2018 at 9:50 AM
    #44
    ArtP
    Art
    Lake County, CA
    I edited the post above with more details. You'll have to find something similar that works with Apple. The one I bought only works on Android.
  5. May 15, 2018 at 9:55 AM
    #45
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    haha yeah, that's where my username comes from. I saw them about a year ago in San Bernardino at the outdoor festival (forget what it was called). Been a fan for many years now.
    I'm at work so I kind of skimmed the original post but is there any particular reason you don't know for sure it's the cats? I do know that P0420 can be tricky because it can also mean other issues with the exhaust or sensors, which is why when I saw that code I immediately just took it into Toyota to have them diagnose because I wanted to be sure what the cause of it was. I also wasn't too surprised to hear that it was my cats, my truck had a pretty bad lean condition for awhile with the supercharger not being properly set up so I think that burned out my cats prematurely (they only had about 55k miles on them). Assuming everything else is in good shape, the cats should last a long time...esp OEM ones.
  6. May 15, 2018 at 9:56 AM
    #46
    ArtP
    Art
    Lake County, CA
  7. May 15, 2018 at 9:56 AM
    #47
    eon_blue
    Azusa, CA
    +1 on the Torque app, it's a great way to monitor readings from your ECU.
  8. May 15, 2018 at 9:59 AM
    #48
    2000 Tacoma Black
    Well, I'm thinking it could be the sensors, I need to complete a drive cycle, or even my K&N throwing something off, or maybe the tech didn't apply the CARB code for the K&N into the computer.
    Also, my exhaust smells a bit rich, maybe that could be it too.
    Bottom line, I don't trust the shop to just pull a P0420 code and immediately tell me I should replace both cats through them...
    THanks for asking...
  9. May 15, 2018 at 10:01 AM
    #49
    2000 Tacoma Black
  10. May 15, 2018 at 10:04 AM
    #50
    ArtP
    Art
    Lake County, CA
    Mine does all that plus some other entertaining things, like 0-60 times, true coolant temp, etc. I looked briefly at that one, it appears to be everything you need, but I noticed they are offering two models, one for $18 the other $30. Not sure of the difference and I don't have any experience with it.
  11. May 15, 2018 at 10:04 AM
    #51
    2000 Tacoma Black
    So now I'm thinking, how would replacing the cats pass you immediately....you would still have to complete the drive cycle, yes?
  12. May 15, 2018 at 10:05 AM
    #52
    eon_blue
    Azusa, CA
    Torque app will show you any CEL codes you have, pending or full blown codes, and you can clear them with the App. It'll also give you information on what the code is and how to troubleshoot it if you want. You can also monitor things like engine temp, trans temp, exhaust and catalyst readings, sensor readings, fuel trims, etc. It's a great app.
    My only issue with it is that it drains my phone's battery something fierce, but just keep it plugged in and it should be fine.
  13. May 15, 2018 at 10:06 AM
    #53
    ArtP
    Art
    Lake County, CA
    You're exactly right! I'm not throwing any codes and my CEL does indeed work. I'm stuck trying to get cycles to complete. My very first post to you mentioned I believe you have two separate issues.
  14. May 15, 2018 at 10:09 AM
    #54
    eon_blue
    Azusa, CA
    interesting, I hadn't thought of that when I had this issue...but I got my cats replaced about a month before I went in to get smog tested so maybe that time frame helped. All I know is that after replacing the cats, the P0420 went away and has been gone ever since (about 8 months now). I had the code for awhile before I did anything about it, at first I had no symptoms other than the code but after a few months my truck starting having symptoms of a bad cat as well (lack of performance mostly...poor acceleration and struggle to maintain power).
  15. May 15, 2018 at 10:12 AM
    #55
    ArtP
    Art
    Lake County, CA
    Though I'm not throwing codes, I'm beginning to believe I have bad CAT(s) too as my exhaust note doesn't sound right, neither is my performance what I think it should be. But I have a problem, I bought this truck five months ago and have no experience to compare it to. Owned several Toyota trucks, but this is my first 3.4.
    2000 Tacoma Black[OP] likes this.
  16. May 15, 2018 at 10:15 AM
    #56
    eon_blue
    Azusa, CA
    Typically if a cat is bad enough to affect your truck's performance, I imagine it would throw the code...I mean mine threw the code well before I could actually notice anything was wrong, which is the case for most people that get a P0420 code. That's why you always hear of people saying 'just ignore that code' when they live in a non-emissions state; because you can typically go so long with it before it starts to actually affect your truck's performance.
    Do you have any aftermarket components to your exhaust that might be giving it a different sound? Maybe a crack or leak in the exhaust somewhere after the cats...if it was before the cats it would likely trigger a code.
    ArtP[QUOTED] likes this.
  17. May 15, 2018 at 10:15 AM
    #57
    2000 Tacoma Black
    Seems like the tail pipe test is actually more accurate than this lateral code sequence drive cycle thing.
  18. May 15, 2018 at 10:16 AM
    #58
    ArtP
    Art
    Lake County, CA
    My powertrain is stock. I think I hear hissing, like a clogged cat, but I can't be sure because of my lack of experience with this motor.
  19. May 15, 2018 at 10:19 AM
    #59
    eon_blue
    Azusa, CA
    This article has some good tips on how to check your cats without a shop's help...
    https://shop.advanceautoparts.com/r/diagnose-a-broken-catalytic-converter
    They mention smelling sulfur...a few months before mine threw the code, I would occasionally smell something awful in my truck for a minute or two that smelled like bad eggs or sometimes like a skunk. Makes sense now in hindsight.
  20. May 15, 2018 at 10:22 AM
    #60
    2000 Tacoma Black
    That's the thing for me.....no performance issues at all, truck runs great. And I've owned this truck for 15 years, and taken good care of it since.
    I am curious tho if I replaced the K&N with OEM, if I would have more power...but that's a separate issue.
