Emissions Problem - Failed Smog
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2000 Tacoma Black, May 14, 2018.
  1. May 17, 2018 at 7:50 PM
    #121
    2000 Tacoma Black
    2000 Tacoma Black [OP] Well-Known Member
    2022 Tacoma DC Off Road / 2000 Tacoma Prerunner
    14.7 and not .46? That’s off by a lot thdn?
    What about O2 sensor #1? Dead?
  2. May 17, 2018 at 7:51 PM
    #122
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I would change both i them, if ones bad your afr will read wrong
  3. May 17, 2018 at 7:54 PM
    #123
    2000 Tacoma Black
    They are probably original. OEM denso? And why replace both ay the same time?
  4. May 17, 2018 at 8:03 PM
    #124
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I mean replace the first one first and see what happens
    2000 Tacoma Black[OP] likes this.
  5. May 17, 2018 at 8:07 PM
    #125
    2000 Tacoma Black
    That’s what I was thinking.
    1. Replace O2 sensor, see if it changes air flow and therefore reading / no code.
    2. Take through drive cycle. If no code, no cat needed.
    Not looking forward to the drive cycle tho
  6. May 17, 2018 at 8:47 PM
    #126
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Where are you seeing his air/fuel ratio readings? The .46 is his MAF (mass air flow) sensor reading
  7. May 17, 2018 at 8:50 PM
    #127
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    He posted like 10 photos the 2nd one he posted with the engine at idle read .31
  8. May 17, 2018 at 8:52 PM
    #128
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Actually my read thats fuel rate... all i read was fuel and thought afr.. im at work so I didn’t pay as much attention as I should
    eon_blue likes this.
  9. May 17, 2018 at 8:52 PM
    #129
    eon_blue
    Azusa, CA
    I'm still only seeing the MAF mass airflow reading unless I'm totally blind (which is possible)
  10. May 17, 2018 at 8:54 PM
    #130
    eon_blue
    Azusa, CA
    No worries I thought I was going crazy lol. He should be able to see his AFR though with that app, and yeah it should hover right around 14.7. It'll change based on open/closed loop but it should stay close to that number unless there's a rich/lean issue which could indicate trouble with the cats
  11. May 17, 2018 at 8:58 PM
    #131
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Or exhust leak will throw the afr off
    eon_blue[QUOTED] likes this.
  12. May 17, 2018 at 9:13 PM
    #132
    2000 Tacoma Black
    Well, my exhaust has been smelling rich for awhile, and I do have a gasket lead, can't remember where, but it a common issue for those aging 3.4L engines.
  13. May 17, 2018 at 9:15 PM
    #133
    2000 Tacoma Black
    Yeah, I didn't scroll to that screen while driving. I'll do another run tomorrow and screenshot.
    I'm looking at O2 sensors now.
  14. May 17, 2018 at 9:17 PM
    #134
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The afr will be the same at idle and any speed
  15. May 18, 2018 at 10:10 AM
    #135
    2000 Tacoma Black
    Just took it out again for MAF readings:
    Warming up:
    40 MPH foot on the gas:
    40 MPH foot not on the gas:
  16. May 18, 2018 at 10:15 AM
    #136
    2000 Tacoma Black
    Or were you talking about Fuel rate? It was fluctuating from .8 to 3.3 from warm up to 40mph...
    EDIT: Ah, air fuel rate, not fuel rate. I'm looking for afr on this app now...
  17. May 18, 2018 at 10:16 AM
    #137
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    still not AFR. that just shows what the MAF is seeing come through.
    I never added mine in Torque but it's a separate display for the fuel/air mixture
  18. May 18, 2018 at 10:33 AM
    #138
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    On another note i dont think my battery ever drops down to 13.2 while driving, mine varrys between 13.8-14.3. But that doesn’t really matter lol
  19. May 18, 2018 at 10:35 AM
    #139
    eon_blue
    Azusa, CA
    It might be worth noting that the AFR readings you get through the Torque app are not the most accurate way to read your AFR...best way to is run an AFR gauge with an O2 sensor welded in before the cats like we do on supercharged/turbocharged engines (I just had one put in a couple weeks ago). I'm not sure if this applies to an N/A motor or not but I was told not to base any hard conclusions off the Torque AFR reading because it wasn't the most accurate way to tell if you were running too lean or too rich. Maybe someone else can shine some light on that though. Still be curious to see what kind of AFR reading your getting even with the app.
  20. May 18, 2018 at 10:42 AM
    #140
    2000 Tacoma Black
    I spoke again today with the shop that installed the cat previously. They quoted me $252 out the door to replace the upstream or bank one O2 sensor, but wanted me to come in for diagnostics to make sure that it was that sensor and not the cat converter. He said that only 10 to 15% of the time is it the sensor that is bad, it is usually the cat converter. I didn’t mention that the cat is only four years old, while the O2 sensor is 18 years old!
