Emissions question - evap pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ihatetacomas, Jul 28, 2020.
  1. Jul 28, 2020 at 5:25 AM
    Ihatetacomas
    Ihatetacomas [OP] Because tacomas hate me
    Dylan
    Elko NV
    '12 White LB TRD Sport
    Used @ 23,283 Volant Intake (w/ scoop)(removed August 2016), BAKFlip G2 Tonneau Cover, (drain tube mod), Pop & Lock Tailgate Lock, Stampede Vigilante Premium VP Series Hood Protector, 5lb Extinguisher, Shovel & Axe mounted in bed, Shok Industries Sound Deadener, Mercury: (K62, MGR-1200, MGR-495) Triton 8" Subs, Custom-Made: Sub Box, Speaker Templates, Vapor Barrier, All-Pro Bumper w/Kickouts, hidden trailer hitch, wooden cup-holder Misc: Knukonceptz RCA, speaker, and power wires, Big 3 Upgrade, a very full Husky technician tool box
    My truck started throwing up codes, (like rough idle and some other engine codes) so I took it in and I was told its more than likely my emissions - either my evap pump or the solenoid, its name escapes me but it basically auto-scavenges excess exhaust fumes and purges them. I was quoted $580 out the door for a ‘charcoal canister’. that price good or should I look elsewhere?
    I know the truck has been overfilled once like 10,000 miles ago, so I'm thinking that maybe the solenoid got a bit of gas in it, and maybe I can just clean the valve and put it back in??? I’m off tomorrow so ill look at it better after work tonight
    Anyways what do you guys think?
    EDIT:
    P2401 - Evaporative Emission System Leak Detection Pump Control Circuit Low
    P2402 - Evaporative Emission System Leak Detection Pump Control Circuit High
    P2419 - Evaporative Emission System Switching Valve Control Circuit Low
    P043E - Evap Leak Detection Reference Orifice Low
    EDIT:
    Turned out to be the charcoal canister, it was ‘very full’ and it'll be around $480 to be put in, + labor.
    Also the fuel injection pump is getting replaced, but thats because of a recall that I missed.
  2. Jul 28, 2020 at 10:06 AM
    Ihatetacomas
    Dylan
    Elko NV
  3. Jul 28, 2020 at 10:23 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its possible you have fallen to failed SAIS valves due to the lack of a shutdown purge on your 2012's ecu.
    That system injects fresh air into the exhaust on startup to help the cats to their job with the extremely rich exhaust mixture. During running moisture gets built up in the valves by nature of combustion, and unfortunately on the 2012's toyota forgot to put a shutdown purge (where the valves open and the pump runs) to push the moisture out of the valves.
    The real question is what were/are the codes being thrown? Let us know that and we will go from there.
    Muddinfun likes this.
  4. Jul 28, 2020 at 10:35 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Post codes
    DGXR likes this.
  5. Jul 28, 2020 at 8:06 PM
    Ihatetacomas
    Dylan
    Elko NV
    Thank you, very informative.
    So its not the evap pump that kicks in the first 5 seconds of startup,
    (or rather that the evap pump doesn't kick in at shutdown)
    but the sais valve thats covered in moisture thats kicking the sensor on correct? So if thats the case can I just manually open the valve and let it dry itself out?
    They cleared the codes a couple days ago, and it ran fine for 1 full day, then when I went to turn it on the next morning they were back.
    Check engine and TRAC off
    Im going to stop by the dealership tomorrow and ill get you the codes then,
  6. Jul 28, 2020 at 8:09 PM
    Ihatetacomas
    Dylan
    Elko NV
    My friend might have a OBD reader, but I'm not betting on it so ill have the dealership pull them tomorrow
  7. Jul 28, 2020 at 8:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The first thing I’d do is see what the codes are
    If it pertains to the Secondary Air Injection System, I’d take them this document.
    Until you know what the codes are for sure, and what is causing the problem there isn’t too much you can do.
    Lester Lugnut, Jimmyh and po35042 like this.
  8. Jul 29, 2020 at 7:46 AM
    nd4spdbh
    SoCal
    Yeah definitely get the codes.
    It also could very easily be the gas cap isnt sealing right. Usually evap codes that pop up that dont put the truck into limp mode is a case of a leaky gas cap.
  9. Jul 29, 2020 at 8:05 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cool read. Ive always noticed my 2012 doesnt run the AIS when shut down, but buddy's 2013 does. Just another thing I need to keep an eye out for I suppose haha
  10. Jul 29, 2020 at 8:12 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Secondary Air Injection System injects air into the engine exhaust manifold. Evap valve and purge solenoid are for the fuel tank vapors. Unrelated systems with different fault codes.
    Beware that Secondary Air Injection System failures tend to be 4-figure repairs if they're caused by a faulty air pump or switching valves, so that doesn't make your situation any better. Post the actual codes so you aren't barking up the wrong tree.
    SR-71A likes this.
  11. Jul 29, 2020 at 11:24 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    Been there done that. Prepare for LIMP MODE. My sons 2012 did this and I tried the taking it off and just cleaning it. Worked great for about a week then it went in limp mode and he was stuck on the interstate going 45 mph for 35 min till he made it home. Its not hard to fix yourself but the parts will run ya 500 or so.
  12. Jul 29, 2020 at 11:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I thought they were covering this under a service campaign.
  13. Jul 29, 2020 at 11:38 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Jimmyh likes this.
  14. Jul 30, 2020 at 4:40 AM
    15TACOSPORT4X4
    Stan
    Yea they cover it now but a few years ago when it happened to us it was not. I got a letter saying it was now covered and if I had already done the repair to show the receipts and I would be reimbursed but of course I have no idea where they were. I did it myself anyway and don't know if they would have just reimbursed the parts. Always keep your receipts.
    SR-71A likes this.
  15. Jul 30, 2020 at 5:28 AM
    SR-71A
    Zack
    Southern Maine
    I believe that was amended to:
    The Primary Coverage is applicable until February 28, 2019 with no year/mileage limitation.
    After the Primary Coverage period ends, the Secondary Coverage is applicable for 10 years from the date of first use, regardless of mileage.
    This is per the pdf that @TnShooter uploaded above
    TnShooter likes this.
  16. Jul 30, 2020 at 8:58 AM
    Lester Lugnut
    Good to know - especially if yours is a 2012.
  17. Jul 30, 2020 at 10:01 AM
    SR-71A
    Zack
    Southern Maine
    Yeah. Kind of makes me wonder if an external relay w/ timer could be added to power the pump for a ~10 seconds after shutdown. Its probably more complicated than that..
  18. Aug 6, 2020 at 5:09 PM
    Ihatetacomas
    Dylan
    Elko NV
    So - good news and bad news, bad news is that I somehow lost the card that had all the codes she pulled (14 popped up since I started this thread but it boiled down to 4 ‘unique codes’)
    Good news is that I have an appointment with the master tech 2 weeks from now to get it sorted out and most likely will be covered by TSB, but who knows.
    Sorry I lost those codes guys, but I can say that the reoccurring codes were either the pump being stuck on or off or some other type of emissions problem, like one was the pressure relief valve was stuck open and etc. but it definitely sounds like its a pump issue.
    This makes me think that maybe putting my volant air kit on a while back then taking it off had something to do with this, because I remember messing with the evap pump when I put it on but all I think I did was relocate it.
  19. Aug 6, 2020 at 5:22 PM
    TnShooter
    Deogee
    STOCK
    Hopefully it’s all due to the pump and it’s covered under the extended warranty.
    Please do let us know how it turns.
  20. Aug 8, 2020 at 5:47 AM
    Ihatetacomas
    Dylan
    Elko NV
    @Tcomaboy @nd4spdbh
