Emissions quick question
Discussion in 'Ontario, Canada' started by Cheap Taco, May 11, 2024.
  1. May 11, 2024 at 11:01 AM
    Cheap Taco
    Cheap Taco [OP] Well-Known Member
    2001 Tacoma Limited Double Cab
    I have a 2001 Tacoma and purchasing a 22 TRD pro sequoia this or next week. Will I have emissions issues if I throw a supercharger on the sequoia before moving to Ontario. I don’t care about warranty just if I will have issues crossing the border? Any tips would be helpful. Moving in 3-4 months.
  2. May 11, 2024 at 11:04 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Do we even check for emissions any more? I don't think so
  3. May 11, 2024 at 11:22 AM
    Bishop84
    Bishop84 Well-Known Member
    Not from Ontario but I'll rattle off anyway.
    It looks like it meets California CARB compliancy. It's 100% legal to import into Canada.
    Because its based on the TRD layout it should pass the out of province/out of country. Some out of province shops are insane strict and can deny any modifications.
    The 5.7 will pass a smog test with the supercharger, especially on a young 5.7 engine/cats.
    You might get taxed on it if you drive back with the packaging for it. So maybe mail your intake back. We've seen it in Alberta with wheels, tires, suspension, they aren't dumb. But because its being imported and you're moving its less likely?
    The supercharged 5.7 is a beast, the current calibrations are a lot more tame and protect the engine, the original calibrations always seemed more violent and we saw engine failures. (2-3 on TRD S/Cs alone)
    Stick to 8000km/5000mi oil changes with better than bulk 0w20 oil.
  4. May 11, 2024 at 11:29 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Read up on importing a vehicle into Canada. For example, you will need proof there are no open recalls on the vehicle: http://www.riv.ca/RecallClearance.aspx
    There's a requirement to get a RIV inspection within 45 days of import: http://www.riv.ca/RIVInspection.aspx Most of the RIV inspection centers are Canadian Tire stores. The RIV inspection is fairly quick according to a couple of sources:
    https://www.canadavisa.com/canada-i.../riv-inspection-canadian-tire-ontario.278773/
    https://www.reddit.com/r/Immigratio...porting_a_us_car_i_brought_with_me_im_at_the/
    Apparently lift kits are no bueno and the vehicle must have DRLs to pass the RIV inspection. Make sure the supercharger and tune don't trigger a check engine light.
    There's a separate safety inspection to get the vehicle plated in Ontario. Again, make sure the supercharger and tune don't trigger a check engine light. Emissions testing in Ontario ended in 2019.
    theOnlyElChapo, Shveet and TeecoTaco like this.
  5. May 11, 2024 at 12:46 PM
    Cheap Taco
    Thank you all for the quick responses, I figure I would ask here as I have never been steered wrong. I figure if I am going to do this once I want to do it right.
    TeecoTaco likes this.
  6. May 11, 2024 at 5:59 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Ah c'mon man...how are we going to learn from your mistakes if you do it right?
