Emptying out the fuel tank
Discussion in '1st Gen. Tacomas (1995-2004)' started by glamis3000, Oct 26, 2011.
  1. Oct 26, 2011 at 12:32 PM
    glamis3000
    glamis3000 [OP] Well-Known Member
    Brant
    Cottage Grove OR
    '96 toyota tacoma 240k miles
    3in lift, 31x10.5x15 toyo mt, tinted windows,
    does anyone know the best way to empty out the fuel tank?? i want to make sure there is no water inside. since our wonderful government has put in the ethanol into our gas, it has made my dads v10 run like shit and break down very often, and all our dirtbikes and quads cant run on this shit. so i just want to empty it out every few months.. and i also will replace the fuel filter at the same time..
  2. Oct 26, 2011 at 5:05 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Never looked at mine before but if you drop the skid from the tank i would think there would be a drain plug for it
  3. Oct 26, 2011 at 5:14 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    since the first gens start the pump on key on, you can pull the pressure line and then they the pump empty the tank
    if you fill it on a regular basis, you wont have any water in there
    Justin
  4. Oct 26, 2011 at 5:15 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    there is no drain plug
  5. Oct 26, 2011 at 5:17 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I don't think you've thought this through? The fuel pickup is always pulling from the bottom, you aren't going to drain a pool of water from the bottom, your fuel pump pulls from the bottom all the time.
    I can only get 10% ethanol here, and I don't see the symptoms you are describing.
  6. Oct 26, 2011 at 6:05 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    run a bottle of stp fuel treatment. It will break down the water in the tank and let it go though the engine will little or no problems.
    I recommend you use a different fuel station. There pick up lines(where you got the fuel from) in the there tanks are too close to the water line in the tanks.
  7. Oct 26, 2011 at 6:18 PM
    glamis3000
    Brant
    Cottage Grove OR
    well isn't just with my truck or our toys, we've talked to a bunch of people all over cali and idaho that have had the same problems, mainly with smaller engines. but my truck i just replaced the fuel injectors and im going to lay the blame on this fuel since its shit.. the ethanol doesn't mix right with gasoline, and it separates which causes condensation in the fuel tanks creating water to sit on the top of the gas. and it does pull from the bottom thus why i don't let my fuel tank get under a quarter so that the water and other floating contaminates stay on top and don't get sucked into my fuel lines and filter.. ive thought it through, which is why I asked my question.
  8. Oct 26, 2011 at 6:25 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    get some STARTRON fuel additive. it has been working for my small engines. also dont let your truck go below 1/4 tank
  9. Oct 26, 2011 at 7:31 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Draining your tank is overkill. I'm from CA and yes the gas is shit, but still overkill. I think if you and previous owners replaced your fuel filter on a regular basis you're injectors would be fine. As long as you're driving your truck and it's not sitting for extended periods of time, the separation is really a mute point.
    That being said, there is no drain plug. You could run the pump with the key on and the pressure line disconnected, but that won't drain it completely. You'll still be left with a few cups of gas in the tank. And since you're so worried about water separation, all the "water" is going to be in those few cups of gas left in the tank, not in anything you pumped out.
    If you're determined to drain it completley, there are 4 bolts that hold the gas tank skid on. Once you get the skid off there is 1 more bolt up front, and an anoying fucking strap on the back (the anoying part is when you put it back together). You've also got the fuel pressure line, fuel return line and two electrical pigtails that are most likely stuck on and require significant amount of swearing to remove. Once all the shit is disconnected and tank is dropped, you can pull the fuel pump, which is like 10 small bolts, which depending on where you're truck has lived its life, can be rusted to shit and seemingly impossible to remove without stripping. Once the pump is out of the way, then you'll have access to drain the tank. Assuming you removed all the fuel pump bolts without issue, you'll have to put it all back together. Carefull not to over tighten those tiny fucking bolts. Torque on them is in INCH-lbs, not foot-lbs. Good luck getting the tank back up by yourself. It's doable, but a pain in the ass and you have to get creative with tools.
    So yeah, have fun draining your gas tank to get the water out. And yes, I have dropped my tank...twice.
    Taco-loco likes this.
  10. Oct 26, 2011 at 7:35 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    X2. This stuff works wonders for all outboard motors I've used them in and other fuel that has been sitting for a long time. Had a half full 6 gallon can that my motor would not run on. Added some startron and it fired up and ran great the rest of that tank.
  11. Oct 26, 2011 at 7:52 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Why don't you buy non ethanol gas for the dirt bikes and quads? I wouldn't use anything else for the outboards for my boat. Try not to let your truck gas tank get below a half and you shouldn't have issues.
    http://pure-gas.org/index.jsp?stateprov=OR
  12. Oct 26, 2011 at 7:53 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    pure-gas.org says there is an ethanol free station out by the Cottage Grove airport if you're concerned.
  13. Oct 26, 2011 at 7:59 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What benefit do you think that emptying out the fuel tank every few months will provide?
  14. Oct 26, 2011 at 8:23 PM
    worthywads
    Obviously you haven't throught this through.
    Water sinks in gas so it is the first thing out whenever it form.
    It does not sit on top as you think.
  15. Oct 26, 2011 at 8:26 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes!!!! Someone else picked up on that.
    Hense the quotes around "water" in my other post.
  16. Oct 26, 2011 at 8:35 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Best way to empty a gas tank:
    Siphon
    They sell em everywhere. It's a long hose with a hand squeeze pump on it. And if ya really wanna dry your tank out afterward, get a 2250-3500 psi nitrogen cylinder and some brass tubing and let it blow down your tank. That will remove all gas and moisture. But that is overkill, overkill is fun.
  17. Sep 4, 2016 at 3:06 PM
    Bkusterer
    Bkusterer Member
    2014 tacoma
    So how do I drain the fuel out of my 2014 taco double cab if the fuel pump is clogged?
  18. Sep 4, 2016 at 3:16 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Pull the rubber coupling that connects the fuel fill line to the tank. Stick in a siphon hose and drain.
    You can't fish a siphon hose thru the fill cap hole. there is a screen to prevent that.
  19. Sep 4, 2016 at 3:17 PM
    koditten
    Kirk
    Central Michigan
    What in the, actual, fuck!?
  20. Sep 4, 2016 at 3:24 PM
    Bkusterer
    Bkusterer Member
    2014 tacoma
    So I have to lower the tank a little ways to take the hose off the tank?
