EMT national registry test
Discussion in 'Jobs & Careers' started by dylandercole, Jan 24, 2010.
  1. Jan 24, 2010 at 9:37 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    I take my national registry test to get my EMT cert on wendsday. Anyone taken it? if so do you have any advice? I finished all the requirments last june but havnt gotten around to taken the test. thanks in advance!
  2. Jan 24, 2010 at 9:41 PM
    Bombero
    Bombero New Member
    Seatown
    06 Quad cab Sport
    None
    I've taken the emt and paramedic National Registries. I always did pretty good on class exams and used one of the study guides for each test. I passed them both no problem. I wouldn't stress too much if you passed your EMT class without any problems and study a little bit.
  3. Jan 24, 2010 at 9:42 PM
    yzrider
    yzrider Member
    LJ
    SO CAL
    04 pre runner
    just a leveler for now but KR fabrication has plans for me
    study your ass off for it know airway patient assesment and OB think bout your answer before you hit next goodluck!
  4. Jan 25, 2010 at 12:05 PM
    dylandercole
    Dylan
    Allright. Ill look over patient assesment again. any other suggestions?
  5. Jan 25, 2010 at 1:40 PM
    Bombero
    Bombero New Member
    Seatown
    06 Quad cab Sport
    None
    Remember that each section is scored individually. That means you have to get a minimum score for each section. I remember hearing that OB\GYN is a section where people have problems because there are only a few question for that section.
  6. Jan 25, 2010 at 6:20 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    If you have studied enough, you may have a shot. Personally, I would have taken a refresher course. Good luck.
  7. Jan 26, 2010 at 11:01 AM
    dylandercole
    Dylan
    that would have been ideal but i feel confident enough in my studying abilities to get it done, even though im on TW at the moment.......crap.
  8. Jan 26, 2010 at 11:06 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    If you know it you know it. Its easy now computer based I was out in under 30mins. Only had like 70 or 71 questions. The new one is easier to me because you don't have to sit down and answer every question that was in the old test bookelt. I challenge my National every 2 years and even with the changing national standard I pass it just fine.
  9. Jan 26, 2010 at 11:24 AM
    dylandercole
    Dylan
    ok. I THINK I know it. or I think I will after todays massive study session. but since youv taken it a few times maybe you could throw some ideas of which topics come up the most or which ones were the most challenging?
  10. Jan 26, 2010 at 11:28 AM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    what level is the test? Just remember that it's only a test. So long as you've done well in class, you should be fine. Stay relaxed, read the question, narrow down to the possible rear answers, and then have some confidence. Always consider safety and the best interest of the patient. OB usually isn't that must of an issue, they'll ask you obvious ones, (previa vs abruptio, etc). Remember how things work -- ABC's, safety of medication administration, blah blah blah. You'll do fine.
  11. Jan 26, 2010 at 11:31 AM
    dylandercole
    Dylan
    thats good advice. thanks. and since in california as an EMT-B we dont really administer medication except for assisting with an epi-pen or glucose or that sort of thing I dont really have to worry to much about it too much
  12. Jan 26, 2010 at 11:32 AM
    blendedfamily
    'Burque(sucks)
    cali sux i've heard. Just take it easy. review your chapters, understand the terminology and have fun.
    let us know how you do.
  13. Jan 26, 2010 at 11:33 AM
    FFRNDAN
    FFRNDAN Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    I always thought OB was fairly simple. Just catch! Like everyone else told you, if you didn't have any trouble in class, a little refresher session at the kitchen table and you should be good to go. BTW, what level EMT are you going for? Good luck!
  14. Jan 26, 2010 at 11:53 AM
    dylandercole
    Dylan
    Im going for EMT-B. first step on a long road. and ill definantly let everyone know how it goes tomarow.
  15. Jan 26, 2010 at 11:59 AM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    Good gravy, if you're in CA, just take a county test. You don't need NREMT. The only kicker is most counties want you to pay money to get to work in their area.
    LA County and OC both have easy tests. So does Kern Co.
    I've never taken NREMT and I was an EMT for 13 years...
  16. Jan 26, 2010 at 12:02 PM
    dylandercole
    Dylan
    Im just doing what my teachers and other firefighters/medics said to do. and the way I figure it I should take the hardest test possible to be best prepared.
  17. Jan 26, 2010 at 12:09 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I took my NR-EMTB test a while ago and it wasnt to bad. There were a lot of scenario based questions. Just follow your patient assessment sheets cause that will help a lot. REMEMBER??? Always your ABC's before you do anything else!!:eek: I got a number of questions like that. I think I got to question like 104 before it kicked me off. Others I took it with got booted at 70-112 and still passed. One guy didnt pass and he went to question 72 I believe. I also took and passed my Utah EMT-B test and that was a lot different. Not as many scenario based questions. Seemed a little easier too.:cool:
  18. Jan 26, 2010 at 12:20 PM
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    Always look for the least wrong answer! Sad, but not even kidding...
    sometimes there is a sequence of things and if in your head you're thinking "i would do A,B AND C, you have to decide which comes first and go with that.
    for instance
    manual C cspine held
    C collar applied
    Pt immobilized to LSB w/ straps etc....
    the end result is full spinal motion restriction, but you cant skip ahead of your steps.
    and always re-check distal CSM after applying a splint!, (or MSC or PMS or whatever you were taught) thats an autofail...
    When in doubt.... the answer is always C!... youve got a 25% chance of being right...! (JK, sort of.)
  19. Jan 26, 2010 at 12:25 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    I teach emt, and in CA, YES you do have to have the NREMT. That was changed a few years ago. No longer are the days when you could just take a county test or drive up to sacramento to pick up your emt card. From my understanding almost everywhere cross the country now has to have the NREMT.
    I also read that CA ems sucks. Well at the basic level we dont get to push drugs or advanced airway. But think about this. Statistically CA has the best EMS/Fire than anywhere else. Especially down here in the LA area. This is why everyone is playing catch up to LA standards. LA wrote the book on EMS, swiftwater, USAR and all that stuff. So i think we win.
  20. Jan 26, 2010 at 12:37 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    I have never read about CA ems sucking and I disagree with that. But I also don't agree on CA having the best EMS service around. I honestly think it depends on the EMS provider himself. Yeah I have heard of certain crews and depts that rock at EMS but not just CA. I live in a rural part of NV/UT and a lot of our basics and intermediates here do lots more than Paramedics in bigger cities!!:eek: Our closest hospital is 120 miles away, one-way, so our EMTs actually have time to use there skills unlike bigger cities like LA or Salt Lake where their hospitals are 2 or 3 miles away. Not even enough time to push any drugs in. I know it depends on the situation but you get the point.:cool:
