Enable DRL Permanently on 2014 model
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ntricky, May 27, 2014.
  1. May 27, 2014 at 6:45 PM
    Ntricky
    Ntricky [OP] Member
    Alberta, Canada
    2014 Spruce TRDSport 4x4
    Does anyone know how to disable the DRL off switch on the indicator stalk on a 2014 model? I am taking my truck to Canada and they require that if the vehicle has DRL that can be switched off that the switched is permanently disabled - ie the DRL are on when the engine is running. The 2014's have the ability to turn the DRL off on the indicator stalk, thus can any one tell me how to modify the wiring so the DRL are on when the ignition is on regardless of switch position?
    I did search but all the posts seem to be on how to disable DRL - I need the opposite!
    I found a copy of the wiring diagram for a 2013 but still not sure what I need to do? Or if wiring is same as 2014.
    Appreciate if anyone can assist.
  2. May 27, 2014 at 6:53 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    13 has the off switch also (at least mine did) , i would assume you could order a Canadian stalk or a pre 13 us stalk.
  3. May 27, 2014 at 7:07 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    are you moving to Canada ?
  4. May 27, 2014 at 7:36 PM
    Ntricky
    Ntricky [OP] Member
    Alberta, Canada
    Yip, moving back to Canada - Canmore AB. Leaving the Texas heat!
  5. May 27, 2014 at 8:10 PM
    OZ-T
    Peter North
    British Columbia
    Oh , I see
    Can you not just get a Canadian 2014 headlight stem when you get back ?
  6. May 27, 2014 at 8:19 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm jealous. Take me with you.
  7. May 27, 2014 at 8:44 PM
    mdcmn7
    mdcmn7 Well-Known Member
    Chuck
    East Coast
    My 12 did not have the ability to turn it off, would assume it swaps?
  8. May 28, 2014 at 5:08 AM
    Ntricky
    Ntricky [OP] Member
    Alberta, Canada
    I was hoping to do a wiring fix ie install a jumper rather than replace the whole stalk as they can be pricey. I would have thought I could put a jumper between the DRL on and DRL off positions on the switch but not too sure? Any auto electricians out there who could offer advice?
    Otherwise like you guys suggest I'll do a swap of the entire stalk for a pre-2013 or Canadian version.
  9. May 28, 2014 at 7:21 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if I had the ewd I could tell you the colors, but anyhow
    disco battery, pull airbag, tape clockspring so it doesn't unwind,
    take off stalk,
    get a mutimeter and see what wires are involved when you switch on drl's
    then jump them together. bang. done. the only way I could explain this easier
    is if I told you exactly which colors to jump, but I don't have the EWD....
    super-hobo method is superglue a pin or nub, and a stop, on the stalk itself so
    it cannot be turned completely off. that might not pass canada inspection though
  10. May 28, 2014 at 7:46 AM
    Ntricky
    Ntricky [OP] Member
    Alberta, Canada
    Thanks for the info 127.0.0.1. I can figure out the wires as you mention with a multimeter. A couple of questions - when you say pull airbag what do you mean? Also where is the clockspring you mention? - I will search to see if there is a thread on getting access to the stalk as upon quick inspection its not too obvious how all the plastic around/below the steering colum is secured - any advice welcome.
  11. May 28, 2014 at 8:00 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    All of the Canadian Tacoma DRL are just the yellow turn signals that stay on and not the actual head lights.
    There should be a cheap harness that you can buy to tie into. At least that's what I did when I brought up a couple of Subaru STi's from the US and needed to turn on DRL's.
  12. May 28, 2014 at 8:42 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    pull airbag means you are disconnecting battery and opening up steering wheel to get to the stalk. might need to pull clockspring off (that will need to be taped so it doesn't unwind)
  13. May 28, 2014 at 9:03 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    127.0.0.1 AKA 1 , could OP just use a multimeter and see what two wires are used to switch the DTRLs on and off, BUT do it near the bottom of steering column in the harness so he wouldnt have to take all of that other stuff apart...........then just as you said he could connect the two wires together thus eliminating the stalk switch on the steering column. Some testers can as I sure you know ,can just kinda pin prick the wires so your not really damaging the insulation.
  14. May 28, 2014 at 1:38 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    absolutley can be done all underneath where the plugs are, I just cannot point to the exact one or define the colors....or else I'd post the actual plug number to make it easy
  15. May 28, 2014 at 4:00 PM
    Ken b
    Ken b Well-Known Member
    Ken
    Surprise, Az
    14 offroad 4x4
    ARE shell, bedrug, TRD wheels
    Slow down, does canadian Tacomas have a different lighting set up? Just get it.
    Also ask your Canadian or US dealers if they can just program it in. Your truck is only a 2013 Im sure Toyota has provisions to convert it.
  16. May 28, 2014 at 5:02 PM
    Ntricky
    Ntricky [OP] Member
    Alberta, Canada
    Unfortunately, the US model has an off position for the DRL on the indicator stalk, hence a reprogram won't do it. Seems my options are ask the dealer to replace with the Canadian stalk which does not have an off switch (pricey), modify the switch or put a jumper in the connector - just need to figure out how to gets the harness/ plug without removing the steering wheel, I'm not too comfortable removing the airbag.
  17. May 28, 2014 at 6:34 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I pulled the airbag and steering wheel on my Bronco with no problems. Some will tell you to pull fuse first. I did not. My Haynes manual stated that they did not cover steering wheel removal because of airbags. I do not really think it is a problem.
  18. May 28, 2014 at 8:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you mean that you pulled the airbag without disconnecting the power, you are riding on the edge. If that thing goes off while you are pulling it it will kill or cause severe damage to you.
  19. May 29, 2014 at 3:45 AM
    stump jumper
    Bill
    Texas
    I disconnected plug in column and handled very carefully.
  20. May 29, 2014 at 5:57 AM
    Ken b
    Ken
    Surprise, Az
    14 offroad 4x4
    Just disconnect the main battery to disable the airbags. You should always disconnect the battery when ever messing with any wiring anyway.
