Enabling the locked out features while in motion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CFI AandP, Jan 22, 2018.
  1. May 12, 2020 at 11:31 PM
    rtadams89
    rtadams89 Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    Is there a reason to put a switch in at all? Why not just disconnect pin 17 at both ends of the harness? If you are worried about going back to the factory setup after, you can always just put the wire back in...
  2. May 13, 2020 at 4:43 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Factory installed navigation and GPS (if you have them) act very odd with pin 17 disconnected (on my 2017 with Nav). Other trims and years may act differently.
    With it disconnected, GPS initially wont update at all, however it eventually updates on a low refresh rate after 10-30 minutes of driving. Nav doesnt start (at least initially). That is what I remember off the top of my head without going and testing again or finding old notes...
  3. May 13, 2020 at 6:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have my override left 'on' (open circuit) continuously. The only time that I toggle it is when doing head unit firmware updates out of caution. Also, I do not use the Entune nav much at all. That said, the first time that I toggle the override, it does take a long time for the current location to refresh. Once it starts updating though, there is never a problem, even restarting the ignition. It is just that first toggle that is delayed, or at least that has been my experience.
    Skydvrr and BigWhiteTRD[QUOTED] like this.
  4. May 13, 2020 at 7:05 AM
    BigWhiteTRD
    Ted
    Interesting
    On mine, after it finally started working again disconnected, refresh rate seemed to take a definite hit. Like maybe 1hz for connected vs 0.3 hz for disconnected (without trying to pull up my notes or video I shot of it).
    I wonder if the difference I noticed isnt the gps refresh, but the head unit doing dead reckoning between gps updates using the pin 17 speed data and magnetic heading data...
    tonered[QUOTED] likes this.
  5. May 13, 2020 at 7:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I will take a look at that today. I did not notice anything there, but I was not paying attention. The refresh rate would be important for getting timely prompts.
  6. May 13, 2020 at 7:49 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I had the same experience. Initially it was laggy. But just leaving it, it worked like normal.
  7. May 14, 2020 at 6:34 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I confirmed what you are seeing. With the override engaged, the refresh rate is about 1sec, and with the override off, it is probably three times faster. Great job noticing that.
    Now, I just need to learn to unsee it.
    BigWhiteTRD[QUOTED] likes this.
  8. May 14, 2020 at 6:37 AM
    BigWhiteTRD
    Ted
    Sorry.. I will admit it isnt much different, but it is there on my truck. I wasnt 100% sure that it wasnt in my head until I filmed it...
  9. May 14, 2020 at 6:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    No worries! Little quirks like that are interesting.
  10. May 14, 2020 at 6:47 AM
    BigWhiteTRD
    Ted
    I think it's pretty cool that (I THINK) they do stuff like fusion using gps and dead reckoning with speed sensor and magnetic direction...
  11. May 14, 2020 at 6:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I completely agree. Using all that is available to improve resolution.
    The override is insanely useful also. It is a nice combination.
  12. May 16, 2020 at 3:26 PM
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
    I pretty only use the built in nav for seeing where I currently am and what the posted speed limit is. If I actually want to navigate to something, I'm using my iPhone. Sounds like in my use case the location update interval won't matter much so when I'm in there later I'll just remove the wire all together.
