Enclosed cargo trailer question
Discussion in 'Towing' started by BLKTRD6SP, Aug 6, 2011.
  1. Aug 6, 2011 at 11:46 AM
    BLKTRD6SP
    BLKTRD6SP [OP] Well-Known Member
    Tim
    Crane Lake Alberta
    09 Black TRD 6 Speed
    2 way remote start,3M rockguard
    I'm looking at purchasing an enclosed cargo trailer probably 7x14 or 7x16. Does anyone know how much of a difference between a V nose unit and a flat front is? Fuel wise and ease of towing.
    Either one will be an aluminum frame trailer, tandem axle, weighing between 1500-1700 lbs empty. I will most likely only have 1000-1500 lbs cargo at any given time.
    Thanks in advance.
  2. Aug 6, 2011 at 2:14 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    I tow a 6x14 V-nose. It pulls pretty easy. Our last trailer was a 6x10 flat nose but it was smaller, lighter and single axle vs tandem so I can't really compare that way. One thing with the V-nose is a 14' V is the same overall length as a 12' flat front will be. The V nose can be a hassle with loading sometimes, especially boxes, but then the flat nose we had had a curve to the front too so it's not like it was really any better either.
    A couple other things is with the V nose I can open my tailgate and canopy on the Tacoma but with the Navigator hooked up you can only open the glass. To try an open the whole hatch it hits the trailer.
  3. Aug 6, 2011 at 2:37 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    Thanks for the reply.
    I can purchase a used 7x16 flat nose for a bout $1500 less than a new 7x16'+2'V. Pretty much just wondering if I am going to regret not getting a V nose, most of my trips are going to be 800-1000 miles return about 6 times a year. Do the V's get a lot better fuel economy than towing a square block?
    As for loading cargo I am not as concerned about the shape inside as I will build shelving in the V anyways.
  4. Aug 6, 2011 at 8:27 PM
    F-125Racer
    F-125Racer Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    I have a 12' Featherlight V-nose and it does pull easier than the WellsCargo with a NoseCone that I had previously. Mileage is not much different, just easier to pull. Check out the "6 Cylinder Towing Review" thread in Towing for more info.
  5. Sep 22, 2011 at 3:06 PM
    trdtaco1
    trdtaco1 Member
    pa
    2011 trd off road
    cant comment on the difference from a v nose or a flat nose but i have a 6x12 v nose haulmark that is 1500lbs and just did a trip with my cbr1000rr and my wifes triumph daytona 675 in the trailer. total weight was about 2500lbs out back with no brake controller. i did drive some decent hills and highway speeds were 70-75mph. i got 13mpg and stopping was not really any different with the trailer there.
  6. Sep 23, 2011 at 7:04 PM
    BLKTRD6SP
    Tim
    Crane Lake Alberta
    I ended up with the 7X16 flat front all aluminum trailer. It's pretty light and when loaded up for a race with bike, gear and Queen bed probably weighs less than 2500 lbs.
    Pulls nicely, barely notice it around town BUT when you get on the freeway it feels like your towing an anchor! Mileage was worse than I had guessed at 9.08 MPG (not taking into account the 265/70/17 tires) so a little better than that. My truck has never seen 20 mpg by itself even with stock tires so I knew it was really going to suck with the trailer.
    WesternTacoma likes this.
  7. Sep 23, 2011 at 10:04 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Also looking to get an enclosed, but 6'x12' V-Nose with only about 1500 to 2000 in it also tandom axels (will be getting more stuff to throw in it once we get the money) with brakes on both axels.
  8. May 28, 2013 at 12:06 PM
    jhaines
    jhaines Member
    james
    colorado
    02 tacoma reg 4x4 2.7 automatic
    exhaust, air intake, throttle body spacer
    have pulled both v nose and flat front trailers some distance; have noticed if you pull with pickup and no shell the flat front is like a parachute; with a camper shell there is little difference as the wind is extended over the shell
