Enclosed Trailer Buy
Discussion in 'Towing' started by Toyko Joe, Jun 7, 2015.
  1. Jun 7, 2015 at 8:39 AM
    Toyko Joe
    Toyko Joe [OP] Here for the pictures
    Hi,
    I am pretty impulsive when it comes to buying large items, usually I don't think twice if I have the cash.
    I am looking to buy a 6x10 or 6x12 enclosed trailer and I am ready to hear some opinions as to why I should go with single over double axle or 70" ceiling height over 76". I will be using this as my mobile garage, and occasionally base camp for hiking and mountain biking.
    Given my Tacoma is a baby, both engine wise and only 6,600 miles I am not trying to break any towing records (although Toyota will tell you that they are 100% service rated trucks [when properly equipped]) my towing capacity is 3500#.
    What are your opinions?
  2. Jun 7, 2015 at 8:53 AM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Subscribed
  3. Jun 7, 2015 at 9:00 AM
    Toyko Joe
  4. Jun 7, 2015 at 9:10 AM
    DoubleRGirl
    DoubleRGirl Hello Kitty Edition
    Rebecca
    Rhode Island
    2015 DCSB TRD Sport 6speed
    Might not matter where you drive, but tolls in some areas become really expensive with more axles
    bawilson21 likes this.
  5. Jun 7, 2015 at 9:13 AM
    Toyko Joe
    I hadn't thought about tolls but that is something I will now consider. Thanks
  6. Jun 7, 2015 at 9:16 AM
    BYBO
    BYBO Well-Known Member
    Byron
    Indiana
    Dual axles usually ride nicer for the contents, and if you're buying, might as well go bigger than you think you need cause they fill up quick. Keep in mind where you're going to store it though too.
  7. Jun 7, 2015 at 9:31 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    Dual axles for the brakes and increased load and stability. Much safer to load when NOT hooked to a hitch and freeestanding on it's front jack. I went w/ 70" over 76" because I didn't need the extra height and I was trying to keep the frontal wind sail size to a minimum. If I was to do it again, I might go w/ the 76" for the extra options it offers in towing. Specifically UTVs. That's why you see so many 76" heights out there. Need the extra height for the UTVs. I wouldn't pay the extra for an aluminum trailer in this size. The weight difference is minimal if not the same or more for the aluminum. In order to make an aluminum trailer as stiff as a steel version, you need to use A LOT more aluminum which ends up weighing about the same for smaller trailers. Not worth eh extra expense to me.
    Stay away from Lark or anything made in Georgia. Stay w/ stuff made in Indiana. I went w/ a 7x12 H&H. Very happy. Ended up paying less than a similar Lark.
    Mine.
  8. Jun 7, 2015 at 2:06 PM
    Nessmuk
    Nessmuk Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
    I tow a 6x10 Pace Cargo Sport with my 2.7L Access Cab. The inside height is 71" and the empty weight is 1140 pounds. When I load it up for camping I figure it runs about 2000 to 2100 pounds. I wish I had more headroom since I am 6'1", but that means more frontal area and more drag.
    Dondai Dave likes this.
  9. Jun 7, 2015 at 2:07 PM
    uscg2008
    uscg2008 Well-Known Member
    coby
    San Diego, CA originally from Huntington Beach, CA
    06 trd sr5 four door 4x4
    CLICK ON SIGNATURE>>>>
  10. Jun 7, 2015 at 2:25 PM
    Toyko Joe
    ^ balloons? What the heck is that?
    How do you like your Pace trailer quality? I just checked out a Haulmark 6' x 12' with barn doors in the rear and V-nose. I'm 5'6" and the roof felt low at 70".
  11. Jun 7, 2015 at 3:51 PM
    Nessmuk
    Bob
    Charlottesville, Va
    It is a 15 reflecting telescope (an Obsession Dobsonian). I use the trailer for camping over in West Virginia. I bought the trailer from a friend who was the original owner. It has torsion bar suspension and rides very nicely. The only issue I have had with it is the top nosepiece at the front. It developed some cracks, but I was able to repair them with fiberglass and that has held up nicely. It has a rear ramp door. This trailer was built before Pace went under and were resurrected by new owners. Not sure what the quality is like now.
  12. Jun 7, 2015 at 9:54 PM
    uscg2008
    coby
  13. Jun 8, 2015 at 6:38 AM
    Nessmuk
    Bob
    Charlottesville, Va
    What type (brand) awning is that? I really need to put one on the trailer.
    AND, when you say you bolted it, did you seal the track with butyl caulk or
    something similar to keep water out of the holes required to mount it to the trailer?
  14. Jun 8, 2015 at 11:15 AM
    uscg2008
    coby
    Is a 99" cascadia vehicle tents (CVT) awning. I bolted it it straight through the awning and trailer to the inside, then I sealed the instead of the the trailer with rtv.
  15. Jun 8, 2015 at 4:00 PM
    MichRocks
    MichRocks Member
    Michigan
    2013 Tacoma
    Ok, apparently nobody cares but me, but the TELESCOPE IS AWESOME!!!!
    drool..!! :thumbsup:
    Nessmuk and Toyko Joe[OP] like this.
  16. Jun 8, 2015 at 4:54 PM
    Toyko Joe
    16' overall. 11'8" straight wall length. Barn doors out back. 1 piece roof. 2980# GVW in Wisconsin that means no registration. New 2015 for only $2780!
  17. Jun 9, 2015 at 8:57 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Nice buy! For anything I'd put in an enclosed trailer, 1 axle would be fine. I'm short enought to stand in a 70", so I'd be fine with that as well. Always wondered how much difference the angled front made in wind resistance. What's the empty weight on that and how did the Taco like it? I have a regular cab 4wd also and have towed a up to 3,000lbs or so with it but nothing that caught a lot of wind.
  18. Jun 11, 2015 at 4:43 AM
    Toyko Joe
    I pick my trailer up tomorrow. 800+ miles to travel this weekend I will let you all know how it hauls unloaded and loaded.
    First leg of my trip will be unloaded 800+ miles from Wisconsin to upstate New York. The following weekend the trip in reverse loaded.
  19. Jun 11, 2015 at 4:47 AM
    Toyko Joe
    You were right about the aluminum being the same weight as the steel. The steel was a steal keeping $900 in my pocket over the aluminum.
  20. Jun 24, 2015 at 6:48 AM
    Toyko Joe
