Endlink disconnects
Discussion in 'Off-Roading & Trails' started by TheCubicleDaydreamer, Oct 24, 2021.
  1. Oct 24, 2021 at 11:05 AM
    TheCubicleDaydreamer [OP] Well-Known Member
    19 Cement TRD Offroad
    Good afternoon everyone. Surprisingly enough my search for "endlinks" did not bear any fruit. Has anyone put together any disconnecting endlinks? From some recollection I thought I read that there was some issues associated with the endlinks dangling around and interfering with the cv boot etc. Has anyone considered disconnects on the upper and lower connections to remove the piece all together? Is does the issue lie with the sway bar?
    WrecklessAbandon likes this.
  2. Oct 24, 2021 at 11:08 AM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    I had my swaybar removed for quite a while, did some offroading then put it back on and in my experience there is very little difference. I think if the IFS had more articulation a disconnect would be worthwhile but as is I think it's a waste of time/money.
    Of course, as with everything, YMMV
  3. Oct 24, 2021 at 11:42 AM
    I mean opinions are being sought after so I appreciate it. Is there a large advantage over a long travel rear shock setup?
  4. Oct 24, 2021 at 11:53 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
  5. Oct 24, 2021 at 12:04 PM
    WrecklessAbandon
    Travis
    Olympia, WA
    Crocs with socks
    A mid or long travel rear setup will make up for some of the shortcomings of the IFS.
  6. Oct 24, 2021 at 12:58 PM
  7. Oct 24, 2021 at 4:29 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    No idea, I’ve just seen them posted on here. Seems to be the only viable option to keep the bar and run disconnects.
  8. Oct 24, 2021 at 11:42 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Problem is the ends of the swaybar will shred the cv boots.
  9. Oct 25, 2021 at 6:10 AM
    I thought I read that somewhere. Thanks.
