Energy rear shackle bushing *solved*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sandman614, Jul 10, 2016.
  1. Jul 12, 2016 at 4:28 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Exactly. So that's the Old Man Emu bushing on the left and factory on right? For the shackle and not spring eye?
  2. Jul 12, 2016 at 4:30 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    That's exactly right. It's the metal shell on the factory bushing that seems to be causing the problem.
    Thank you for your pics!
    :proposetoast:
  3. Jul 12, 2016 at 4:32 PM
    Pigpen
    Dan
    Northwest Montana
    The reading comprehension problem was mine. I have nothing to contribute to the conversation. :notsure:
  4. Jul 12, 2016 at 4:34 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    The metal/rubber bushing is a factory bushing and I'm about 95% sure the poly ones are what OME sent with my springs. They are both for the shackle side of the springs. My OME set had a set of bushing already install in front, which appear to me to be factory style.
    I have a set of red Energy Suspension bushing marked 2176 as well but I think they were for 89-95 and 1st gen springs. But FWIW they measure 0.565" ID of the sleeve and 1.625" OD on the bushing.
  5. Jul 12, 2016 at 4:36 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    That would do it, the ID of that sleeve is about 1.365" (very roughly, it's kind of an eyeball with the caliper) and I suspect would be a very tough fit.
    Sandman614[OP] likes this.
  6. Jul 12, 2016 at 6:30 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Now do I still get that extra set or take mine out and cut the sleeves out?
  7. Jul 12, 2016 at 8:00 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Extra set of which?
    I'd cut or press out any sleeve, which is probably supposed to still be attached to the rubber of the original bushing but has torn off.
  8. Jul 12, 2016 at 8:03 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Extra set of shackles I found that a friend has.
  9. Jul 12, 2016 at 8:07 PM
    DaveInDenver
    David
    Grand Junction
    Unexceptional
    Copy that. If it was me I'd start with fresh shackles - get out the old stuff, coat of paint, fit in new bushings.
    Crom likes this.
  10. Jul 16, 2016 at 6:53 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    Tackled this today. I used a redneck press to press out the rubber and inner sleeve, then cut slits in the flange with my Dremel then made a cut down through the sleeve with a metal cutting blade on my jigsaw, and finally hammered it out. The Energy bushings slide in by hand and the inner sleeve is a little tight so I put it back on the press with minimal pressure.
    IMG_20160716_174435.jpg IMG_20160716_180710.jpg IMG_20160716_180842.jpg IMG_20160716_181112.jpg IMG_20160716_182834.jpg
  11. Jul 16, 2016 at 7:06 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Hell yeah! Handled like a boss. ;) :cheers:
    DaveInDenver likes this.
  12. Jul 19, 2016 at 8:12 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    That's a 1.5" pvc coupler, I did end up squashing it because the 2nd bushing was a little more "at home" than the first.
  13. Aug 6, 2016 at 6:56 PM
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    Thanks for the pics! Ill see if mine have that, now that I assembled it all back together!
  14. Sep 13, 2016 at 3:38 PM
    Crom
    Nick
    San Diego, CA
    Millions
    @Sandman614
    I picked up a set of spare stock shackles a while back to work on.
    I cut / drilled the rubber on the flange outta the way, then used some fire.
    Here is a nice shot of the two shells, if you look inside you can see they don't quite touch in the middle.
    Gonna make some cuts like you I think.
  15. Sep 13, 2016 at 6:12 PM
    #35
    Sandman614
    Tim
    '06 SR5 Off Road
    Sweet, cutting is the ticket.
  16. Jan 5, 2017 at 6:01 AM
    #36
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    The TLDR makes it sound like these tests were failures, but the last two posts in this thread look like you guys made some progress? Maybe I'm mistaken.
    So no replacement bushings successfully fit in the shackles yet? Thanks for the R&D work regardless.
  17. Jan 5, 2017 at 6:03 AM
    #37
    Sandman614
    Tim
    '06 SR5 Off Road
    The energy bushings fit.
  18. Jan 5, 2017 at 6:04 AM
    #38
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    The ones out of the 8.2116 kit? (with sleeve removal)
    EDIT: PM'd him to clarify and yes, they fit.
  19. Jan 16, 2017 at 12:57 AM
    #39
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
  20. Jan 16, 2017 at 4:17 AM
    #40
    Sandman614
    Tim
    '06 SR5 Off Road
    No
