Energy Suspension bushings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wesdan13, Nov 6, 2024.
  1. Nov 6, 2024 at 4:36 AM
    Wesdan13
    Wesdan13 [OP] Active Member
    Chattanooga TN
    23 Tacoma TRD Pro
    Energy Suspension body mount bushings. Who’s got’em and what’s your long term review? Red or Black?
    Looking to replace my front body mount bushings in hopes to eliminate a noise.
  2. Nov 6, 2024 at 4:50 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    eurowner and hyrule_trd like this.
  3. Nov 6, 2024 at 5:08 AM
    Wesdan13
    Chattanooga TN
    23 Tacoma TRD Pro
    atc250r likes this.
  4. Nov 6, 2024 at 6:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    I noted that they have been great. Been on there for 3yrs now. There is a link to the product. What more are you looking for?
    eurowner and Buggin112 like this.
  5. Nov 6, 2024 at 6:03 AM
    VatoTaco623
    VatoTaco623 Well-Known Member
    Michael
    Arkansas
    2018 Silver Tacoma OR
    265/75/16 Nittos Caliraised amber ditch lights Offroadtown fogs 20% tint Bilstein 5100s
    I went with the red ones about 1.5 years ago and they’ve been great! Installed them at the body mounts near the radiator. Took me about an hour and it eliminated a clunk I had up front
    auskip07 and Wesdan13[OP] like this.
  6. Nov 6, 2024 at 6:50 AM
    kimosabe15
    kimosabe15 Well-Known Member
    2015 DCSB SR5
    Another vote for red mounts
    Wesdan13[OP] likes this.
  7. Nov 6, 2024 at 6:55 AM
    Wesdan13
    Chattanooga TN
    23 Tacoma TRD Pro
    Really hoping this will be the case for me.
    VatoTaco623[QUOTED] likes this.
  8. Nov 6, 2024 at 9:41 AM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I've never had a red urethane bushing last as long as the black (maybe 4-5 years vs. indefinitely). Something about the black pigment I guess somehow protects the urethane from UV. Since color is otherwise simply cosmetic, I always buy the black now.
  9. Nov 6, 2024 at 9:51 AM
    uhchxrlie
    uhchxrlie Well-Known Member
    2020 MGM Tacoma SR SX Package
    Following as I have had a clunk noise when I go over bumps. Let me know how the bushing workout for you.
    kimosabe15 and Wesdan13[OP] like this.
  10. Nov 6, 2024 at 9:53 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That graphite blurb might have something to do with it?
    Please ignore the highlighted text. It is from my search, but I can't find a page link without it.
    https://www.energysuspensionparts.c...ings is,functional difference between the two.
  11. Nov 6, 2024 at 10:04 AM
    eurowner
    eurowner Duke Sky
    Scoty
  12. Nov 6, 2024 at 10:26 AM
    4x4junkie
    So Calif. (SFV)
    Interesting... Seems that would make sense since graphite is capable of blocking light and would keep it from penetrating as deep into the urethane, which I think would otherwise be a neutral yellow-white color if not pigmented.
    tonered[QUOTED] likes this.
  13. Nov 6, 2024 at 10:32 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Agreed. It is similar for tires. The graphite is both a lubricant and UV protectant.
  14. Nov 6, 2024 at 10:44 AM
    Wesdan13
    Chattanooga TN
    23 Tacoma TRD Pro
    I reached out to Energy and they said they don’t even have them for 2018 and up. But Rogue sells the energy full kit. Now I’m confused. Also, they won’t sell ONLY the fronts. Apparently could cause body damage if you only replace the front vs all of them at the same time. I’m going to the dealership in 2 days to see what they say about the fronts. My front drivers side is showing some sort of cracking like they were painted but… it can’t be paint. I can’t get in there without removing the bumper. IMG_9687.jpg
    tonered likes this.
  15. Nov 6, 2024 at 11:09 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Many threads on these. A ton of folks are using the two universal kit ones up front. I started there.
    The issue is internal to the mounts wearing prematurely. You can totally get at them just by pulling two screws between the wheel well liner and bumper lip:
    https://www.tacomaworld.com/threads...our-leaf-springs.464993/page-16#post-25920683
    Note that going to the dealer and having them swapped for OEM is most likely not going to fix it. The noises will come back.
  16. Nov 6, 2024 at 11:59 AM
    Wesdan13
    Chattanooga TN
    23 Tacoma TRD Pro
    I kinda figured it would come back and I’m fine with that. Just simply because it would be a warranty repair and also give me a def answer if it is actually the bushing making the noise or not.
  17. Nov 6, 2024 at 12:12 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I wouldn't ever use poly bushings for body mounts, I tried them on my 4runner and switched back to rubber. They made the 4runner feel so rough like I was driving on overinflated 10-ply tires.
    Maybe they are better for just the front mounts though. But for all of them, Never would I go with that again.
  18. Nov 7, 2024 at 8:52 AM
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
    Running black, just the front core support mounts, no issues. i have about 60k on them since i put them on.
  19. Nov 7, 2024 at 12:08 PM
    Wesdan13
    Chattanooga TN
    23 Tacoma TRD Pro
    I assume your cause to replace them was due to the oem ones failing?
  20. Nov 7, 2024 at 1:54 PM
    3r3Taco
    So.Cal
    17 SR5 DCSB
    Factory Stock
    Yes the OEM ones had tears and it was the core support metal rubbing on the bolt.
