Engage 50T pack too stiff?
Discussion in 'Long Travel Suspension' started by joey34mx, Oct 20, 2010.
  1. Oct 20, 2010 at 6:35 PM
    joey34mx
    joey34mx [OP] Well-Known Member
    Joey
    Southern California
    2005 Tacoma V6 prerunner
    hey guys ive got some questions on engages 50T pack
    im having them installed on my 05 access cab....
    the pack looks pretty thick from what i see which means it will be pretty darn stiff=stress on the truck and me:(
    plus these things look like they will lift my truck to the sky? which i really dont want...:confused:
    can anyone give me some feedback on the best way to run this pack?
    thanks
  2. Oct 20, 2010 at 6:46 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    If all you do is drive on the street they will feel firm. If you like to go fast, you will love them. I have had Deaver's and the 50T pack and the capability is night and day. Mine setup with TC 12" shackles pull 19 clean inches. With 3.0x18" Radflo's I can't bottom it out. I have bumps on there, but they only see use if I do something exceptionally stupid. I have over 15,000 miles on the 50T pack and after settling they have not sagged at all. The next best thing to links for sure. As far as setup, you can change ride height with shackle length. I'm not sure if you're running the crappy stock style or traditional over the frame, but it's easy to adjust ride height if you're concern is looks. Can't be cool without bro stance, but you can go fast. Mine is 8" up stroke 10" down at ride height (measured top of axle to frame). In contrast, the Deaver's were shot in 5000 miles and they very nearly killed me once or twice. I forget who was on the run where I wheel barrowed over 30" deep whoops at 70 because the back end bucked so bad, but if you were there chime in. I bent my frame above the axle from bottoming out all the time with deaver's, and i had the super beefy H70 pack.
    50T vs Deaver H70
    50T's flex well too-
  3. Oct 20, 2010 at 7:31 PM
    krumble
    krumble Well-Known Member
    Jon
    Santa Clarita, CA
    (08 TRD Offroad SOLD) Current: 2017 Colorado Diesel
    debadged, tinted windows, magnaflow exhaust, afe CAI, 285x75 Nitto Terra Graplers, Engage LT front and rear
    I love my 50t pack I don't think its too stiff at all. For me it rides pretty similar to the stock pack with an AAL. You could always remove a leaf if you think its too stiff.
  4. Oct 20, 2010 at 7:51 PM
    joey34mx
    Joey
    Southern California
    thanks for the input man. i see your running a pretty good amount of weight in the rear, so im guessing it doesnt buck to much. how long is the process of the 50T pack settling a little lower at ride height? and how far down(about) do you think it sagged?
    thanks
  5. Oct 20, 2010 at 7:52 PM
    joey34mx
    Joey
    Southern California
    hey man do you have a 4 door or the access cab? and what do you have in the bed for extra weight? could you get a pic up please? :D
    thanks
  6. Oct 20, 2010 at 8:22 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2018 4-Runner
    I may go to the 50T if this extra leaf in my DMZ pack settles much. It did raise the rear almost 2 inches but I still have a 2" height difference from front to rear. It was 4" before and thats with the coil overs at zero pre-load. :eek:
  7. Oct 20, 2010 at 9:11 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Even without the spares it doesn't buck, I just turn my compression screws out a few turns and I'm good to go, but the rear axle weight is 1850 lbs fully loaded, about what yours is stock. Front is around 2100 lbs, total around 4K. They settled about an inch or two, you could break them in with one weekend in Barstow or it could take 2500 freeway miles.
  8. Oct 20, 2010 at 9:57 PM
    joey34mx
    Joey
    Southern California
    So your running an 18 inch shock?
    i plan on running a 16 inch because that is all i have seen with this leaf pack setup. how do you make the 18 inch shocks work?
  9. Oct 21, 2010 at 3:15 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Old pic, but you get the idea. 16's are fine too, you just have to angle them a little more to get full travel. You don't really need 18's, I just wanted to run 1:1 ratio. Most guys run them outside the framerail, but I didn't want any rub on articulation because I still like to play in the rocks. DSC04160_83ad4184534ea48c785506112d7e28daf4fffe22.jpg
  10. Oct 21, 2010 at 3:35 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    ^^^ i like what you did w/ the shackles and mounted them on top of the frame and didnt keep them on the side
  11. Oct 21, 2010 at 3:41 PM
    joey34mx
    Joey
    Southern California
    oh i see, i understand now. your setup looks very well done. i like how it is a bit different than most of the other 05+ LT tacos i've seen. who did this work?
  12. Oct 21, 2010 at 3:51 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  13. Oct 21, 2010 at 3:54 PM
    joey34mx
    Joey
    Southern California
    wow im impressed.
  14. Oct 21, 2010 at 4:56 PM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    It's a little unconventional, but works good. It's now all tied into a cab and engine cage.
  15. Oct 22, 2010 at 12:15 AM
    joey34mx
    Joey
    Southern California
    looks great to me man ^^^^^^^:D
