Engage LT with full ALLPRO Trail Armor ?
Discussion in 'Long Travel Suspension' started by tostidos, Jan 28, 2011.
  1. Jan 28, 2011 at 3:17 AM
    tostidos
    tostidos [OP] Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Ok guys wonder if any of you are running the Engage or simliar LT Kit with ALLPRO Bumpers/Skids/Rockguards. Been mulling it over and am wondering if the ALLPRO setup all around is too heavy for LT. Im not going to race my truck but i want it to perform and be adequately protected in all environment including wooded areas as well as the open desert. If I decide to go with it I will post pics and let you guys know how it works out. Post your ideas even if you arent running this setup and input would be appreciated. not an easy decission considering all the goodies from allpro including a winch is ~$5K installed.
  2. Jan 28, 2011 at 6:42 AM
    06HAOLE
    06HAOLE Well-Known Member
    Sherman Oaks, CA
    2014 Ford Raptor
    I think for your intended use thats a great set-up. You may want to talk to All-Pro about different spring rates and valving on your new coil overs to compensate for the extra weight of the armor and winch.
  3. Jan 28, 2011 at 7:00 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Keep in mind the engage and TC Long travel kits make your truck quite a bit wider in the front, so if trails is your main thing you may want to look at the AP long travel kit as well. Its not as wide from what i understand and you can still get decent articulation. Someone correct me if im wrong.
  4. Jan 28, 2011 at 7:11 AM
    06HAOLE
    Sherman Oaks, CA
    2014 Ford Raptor
    No man your right. I thought he had picked the All-Pro kit.
  5. Jan 28, 2011 at 7:16 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Wouldn't you need big glass fenders too, which wouldn't line up with the AP bumper? (well I don't think it would) and I don't believe the AP glass fenders would have a large enough opening for running the Engage kit
  6. Jan 28, 2011 at 3:19 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Ill have to check but ALLPRO has glass fenders and I assume they match up to their bumper. also it may not be enough for the engage kit. Ill have to ask but when i was talking to Engage they told me there shouldnt be any issues with the allpro bumper as far as clearances. I understand that it'll be a little wider but the majority of my wheeling will be in open desert i just want the option to go into some trails if it comes up. thanks for the input I will definitely ask about valving now!
  7. Jan 28, 2011 at 3:22 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Desert Runner no doubt! Thanks for the pic! Looks great!
  8. Jan 28, 2011 at 3:22 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Allpro is 2+ wider then stock
  9. Jan 28, 2011 at 3:23 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
  10. Feb 1, 2011 at 1:03 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    You usually would not want a front heavy truck if you are interested in playing in the desert. Most prerunners do not mount heavy plate bumpers or winches in the front. Just skidplates for lawn dart protection. Example:
    Now if you are using LT to crawl, then you should be okay...but out in the desert you stuff tires all day through the jumps and whoops and you don't want coil bind.
    P.S. Mike is a Crazy driverrrrr hahaha :p
  11. Feb 1, 2011 at 1:09 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    A nice tubed front bumper with a skidplate will protect you just fine. You can also do a tube/plate hybrid rear bumper if you want. KR Fab is in Lancaster and he can make you whatever you want at a fair price. Perhaps you want a hyrid front bumper as well?
  12. Feb 1, 2011 at 1:21 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    You need to set up bumps correctly and you wont be coil binding reguardless of what bumper you have. Coil bind is bad news and will ruin your shocks
  13. Feb 1, 2011 at 8:41 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Hmm good info. I was told by engage that there isnt any clearance issues with the bumper but i can see being heavy in the front would bring the front end down more. maybe I should reconsider. The ALLPROs look sweet but maybe that is going overboard. probably cheaper for tube bumpers?!
  14. Feb 1, 2011 at 8:44 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    But also I dont plan on jumping this fucker like mike till the warranty is gone and i replace it as my daily driver. that white taco looks sick.
  15. Feb 1, 2011 at 9:26 PM
    theduck911
    Max
    Locked and Geared!
    Not bad, yea that's Freeze's truck it's sweet, uhm well if you go with the APbumper, I'm sure with a new/stiffer spring and some revalving you should be able to ride fine without any sag!
  16. Feb 1, 2011 at 9:28 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    another question for engage when I get the LT. Ill be posting a build thread eventually and Ill let everyone know what was recommended and what I did.
  17. Feb 1, 2011 at 10:03 PM
    theduck911
    Max
    Locked and Geared!
    Yea, make sure you keep us up to date on what's going on!
  18. Feb 2, 2011 at 12:02 AM
    Trifenix
    so cal
    99 LT 5 lug Taco
    Engage can fab you a tube bumper for a good price. Trust me, once you go LT, your foot stays on the skinny pedal. You should be good with a 600 lb. spring rate. Save money and then you can do the rear!
  19. Feb 2, 2011 at 12:33 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I like the way you think. how much you think the bumpers and skids would run from them? maybe they can hook me up for full front and rear with bumpers and skids for around 10k? that would be a sick deal!
  20. Feb 2, 2011 at 3:30 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    mccneil off road did this kids truck with trailing arms kings, 17 inches of travel, front and rear. front and rear bumpers and a bed cage. for 7k! oh and an engine cage!
