ENGAGE offroad lower arm broke i need your guys opinion on this
Discussion in 'Long Travel Suspension' started by tacoman68, Nov 29, 2011.
  1. Dec 1, 2011 at 10:58 AM
    #181
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Yeah, then that's most likely what happened, just can't find the seam etc.
    As far as it occurring twice in the same spot, goes along with what I posted above.:cool: But I would still put a small patch/gusset over the seam.
  2. Dec 1, 2011 at 10:58 AM
    #182
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    ^^^ If it were material thickness, the metal would have torn or ripped.....No?
    VS. what looks like the obvious of the seam straight separating.....
  3. Dec 1, 2011 at 11:05 AM
    #183
    theduck911
    Max
    Locked and Geared!
    That's what I was thinking because the weak point of the material is the seam, the thickness is a contributing factor most likely tho. The loads on the LCA are large, especially after big hits, so failure usually occurs at the weak link (the seam).
  4. Dec 1, 2011 at 11:05 AM
    #184
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Exactly what I was thinking. Its got to be a seam to be that clean of a cut. You dont need to be a fabricator to figure that out.
  5. Dec 1, 2011 at 11:17 AM
    #185
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    Maybe I'm missing something here, but how is it "obvious" that the seam failed? Can you tell just by looking at these photos that the tubes failed at the seams? It sounds like you're basing your assumption on the appearance of a clean split in both cases. Am I right?
    I based my assumption on the likelihood of the seams being in the same place both times - whether intentional or coincidental.
    Intentionally, I doubt Engage would have seam facing that way, exposed and not braced/boxed in.
    Coincidentally, well... that's quite a coincidence.
    The likelihood of material failure, specifically thickness/quality related seems greater to me. Especially when you consider the directions/loads/forces being applied to the LCA pivot.
    Also, failed welds don't necessarily have clean breaks like that.
  6. Dec 1, 2011 at 11:24 AM
    #186
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
  7. Dec 1, 2011 at 11:55 AM
    #187
    theduck911
    Max
    Locked and Geared!
  8. Dec 1, 2011 at 12:51 PM
    #188
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
  9. Dec 1, 2011 at 12:54 PM
    #189
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    He's saying that .250 wall 4130 bushing sleeves don't tend to tear open
  10. Dec 1, 2011 at 12:54 PM
    #190
    jtlachac08
    Jeremy
    Phoenix, Az
    Correct, failed man made, wire/stick welds dont break clean. Laser heated machine seamed tubed metal will likely "split" from stress, as seen in the above pictures.
    Metal tube, regardless of thickness, that has failed due to stress with tear the physical properties and characteristics of its compounds. Creating an unevean break.....
  11. Dec 1, 2011 at 12:55 PM
    #191
    dirty dangler
    adam
    simi valley,ca
    ^^^ this
  12. Dec 1, 2011 at 2:25 PM
    #192
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    :drool:
  13. Dec 1, 2011 at 2:26 PM
    #193
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    So based on the pictures from both failures these arms don't get lubed by any sort of grease :confused:
    I guess Ill look at their website and see what type of material bushings are used.
  14. Dec 1, 2011 at 2:35 PM
    #194
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Good luck on your search.
  15. Dec 1, 2011 at 2:41 PM
    #195
    jtlachac08
    Jeremy
    Phoenix, Az
    What are you talking about they have a very informative website :D
  16. Dec 1, 2011 at 2:44 PM
    #196
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I found one but from a different manufacture "The Boxed lower Arms pivot on massive 1″ uni-balls instead of cheap bushings" FTW!!! :D
  17. Dec 1, 2011 at 4:52 PM
    #197
    aznpg
    aznpg Well-Known Member
    crappy state of California with a ban on anything
    long traveled dcab taco
    front suspension: camburg gen 2 kit with custom donahoe resivoir coilovers and radflo bump stops rear suspension: deaver 8 with fox 2.5x14 remote resi
    wouldn't happen to be the kit that we are both running from camburg right hahaha.
  18. Dec 1, 2011 at 4:53 PM
    #198
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    This.
    This dude has done some sshhieeettt with that kit.
  19. Dec 1, 2011 at 4:56 PM
    #199
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    is it possible that an un-greased pivot will cause extra stress on the sleeve and lead to failure?
  20. Dec 1, 2011 at 4:57 PM
    #200
    blackhawke88
    SGV, CA
    07 TRD Offroad
    if you use uniballs for lowers, then you use bushings for the uppers, or other way around, IIRC, or theres too much play in the whole system :notsure:
