ENGAGE offroad lower arm broke i need your guys opinion on this
Discussion in 'Long Travel Suspension' started by tacoman68, Nov 29, 2011.
  1. Dec 1, 2011 at 5:06 PM
    #201
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If it's over torqued down, never saw a drop of grease, and utilizing crap material for the bushings anything is possible. Those bolts shouldn't be over 100#.
    I would be very hesitant to buy any aftermarket kit that didn't have zerks on moving parts. I would also wonder why no grease is shown in the pics of the bushings. If the kits don't have zerks they most certainly should of been greased during installation IMHO.
    Shit I mall crawl and greased the piss out of my OE bushings when I installed them, but I'm no mechanic or fabricator.
    Common sense says moving parts need lube.
  2. Dec 1, 2011 at 5:18 PM
    #202
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I grease mine too, all the time, i was just wondering
  3. Dec 1, 2011 at 5:22 PM
    #203
    XXXX
    sKiP
    05 Prius
    I would think it contributed to the problem but is not the main factor for failure.
    I have a feeling many circumstances are to blame for OP's issue's.
  4. Dec 1, 2011 at 5:29 PM
    #204
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    Such as?
  5. Dec 1, 2011 at 5:30 PM
    #205
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I believe you can get poly urethane bushings or Delrin like I run on my kit
  6. Dec 1, 2011 at 5:30 PM
    #206
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    When moving parts like that aren't lubed properly, they will chafe and bind. Especially under really dusty conditions like desert driving. Excess friction, blah blah. I'd say that could well be a contributing factor.
    When bushings wear they cause excess movement/play. Super high performance and race car suspensions do without bushings, favoring tie rods and uni-balls. Bushings are used for comfort and vibration isolation in certain cases
  7. Dec 1, 2011 at 5:31 PM
    #207
    blackhawke88
    SGV, CA
    07 TRD Offroad
    True, I think the biggest take away is for current Engage customers to reinforce that portion of their control arms. It's fortunate that in the past four years Engage has been distributing these 2nd Gen kits, this is the first failure of that part.
  8. Dec 1, 2011 at 6:44 PM
    #208
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    And watch for cracks on a regular basis. A small nick can lead to a large crack. I am convinced that mine started as scrapes over rocks. ...and lube is always good. TC recommends a graphite synth grease. I make home brew with Mobil One and dry graphite.
  9. Dec 2, 2011 at 5:39 PM
    #209
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Good thing they used the same bushing kits you can buy at Kartek.
    Or was it just ironic?
  10. Dec 2, 2011 at 5:57 PM
    #210
    Defined
    Defined Well-Known Member
    mike
    southern california
    dude , i hope you realize that what you greased dosent pivot in the arm . your grease didnt do anything except to help press in the new bushings. oem bushings dont really pivot , they act more like a torsion bar than anything else
    no lube on the bushings wont create what happened to the OP. its very apparent seamed tubing was used and wasent assembled correctly before welding.
    also, dom and chromoly tube starts life as welded tube but is twisted while put through the mandrel so what happened to the OP wouldent have happened if dom or chromoly was used.
    lastly , superlube is hands down the best lubricant for bushings, i wouldent use anything else , especially for acetal bushings
  11. Dec 2, 2011 at 9:21 PM
    #211
    Bobber Bill
    Los Angeles, CA
  12. Dec 2, 2011 at 11:54 PM
    #212
    noSKills858
    Alex
    Poway, CA
    It looks like the lower sheared on the seam. 1/8 Mild or cold rolled isn't enough for the amount of force it would endure.
  13. Dec 3, 2011 at 9:04 AM
    #213
    HBMurphy
    Paul
    So California Coast
    None
    And all that grease on the cams will only allow it to bump out of alignment quicker - those parts IMO should be clean and dry! :)
  14. Dec 3, 2011 at 9:50 AM
    #214
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    All that excess grease enables ATRAC allowing it to perform better
    :cookiemonster:
  15. Dec 3, 2011 at 11:37 AM
    #215
    HBMurphy
    Paul
    So California Coast
    None
    Only if it is BACON grease. :)
  16. Dec 3, 2011 at 12:06 PM
    #216
    Nicks4x4LT
    Nicks4x4LT Official Villain
    Nick
    714 Orange county
    2010 4x4 V6
    Custom front bumper, Icon 2.5 ext. travel coilovers, Defined rear long travel King smooties w/ resi. Avid Offroad sliders, Fiberwerx front fenders, Glassworks Shorty TT style rear glass, URD MAF calibrator, DT shorty headers, URD TCAI, Magnaflow catback
    :dancingbacon: :dancingbacon: :dancingbacon: :dancingbacon: :dancingbacon: :dancingbacon:
  17. Dec 3, 2011 at 12:14 PM
    #217
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    This truck doesn't have atrac
  18. Dec 3, 2011 at 12:59 PM
    #218
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
  19. Dec 3, 2011 at 1:17 PM
    #219
    MonkeyProof
    SoCal- SGV
    That explains the failure :cookiemonster:
  20. Dec 3, 2011 at 1:29 PM
    #220
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
