Engaging 4x4 once a month
Discussion in '3rd Gen. Tacomas (2016-2023)' started by knuckles67, Mar 19, 2021.
  1. Mar 20, 2021 at 8:41 AM
    #81
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    Use the force
  2. Mar 20, 2021 at 9:06 AM
    #82
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    What if i don't want to get dirt on my tires. Because i read the it will speed up the dry rot on the rubber?
    can i just drive back and forth on my driveway for 10 miles instead of putting it up on jack stands?
    :spy:
  3. Mar 20, 2021 at 9:20 AM
    #83
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    I worry more about the cracks that may develop from deflating on the trail and reflating back for the road lmao!
    Waynebarkr and ToyoTaco25 like this.
  4. Mar 28, 2021 at 4:27 AM
    #84
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    This, truly WTF.
  5. Apr 6, 2021 at 6:22 AM
    #85
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I would like to open this thread back up with a different thought. It seems that the general consensus is that running 4WD high on concrete would cause damage due to lack of slippage while turning. On the 2021 there is the ability to lock the rear and with after market the front too. So my question is, if the front and rear are not locked how would one cause damage in 4WD High? Without the lockers the dif is in LSD mode correct?
    4×4×4 likes this.
  6. Apr 6, 2021 at 6:27 AM
    #86
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    4hi on concrete is fine as long as you don't turn
    Diff lockers do not change the behavior of the transfer case, it is still locked. Its the distance difference front to back that causes binding when turning in 4wd.
    SilverBulletII and Kev250R like this.
  7. Apr 6, 2021 at 6:30 AM
    #87
    Chaosh1
    2021 Tacoma TRD Pro
    I thought the transfer case only truly locks in 4W Low?
  8. Apr 6, 2021 at 6:31 AM
    #88
    0xDEADBEEF
    Nope. If its in 4wd, its locked. To get one that unlocks you'd need somethng like the AWD cases found in the 4runners that have a locking option.
    Kev250R likes this.
  9. Apr 6, 2021 at 6:38 AM
    #89
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    I do it one wheel at a time.
  10. Apr 6, 2021 at 6:49 AM
    #90
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Cudgel[QUOTED] likes this.
  11. Apr 6, 2021 at 7:05 AM
    #91
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Not that bridge, unless you're really old now and still on your feet doing great. That bridge has been underwater for close to 71 years.
  12. Apr 6, 2021 at 9:18 AM
    #92
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    The consensus is NOT that driving on concrete in 4hi causing damage. That is grossly overstated and truly stupid. It only causes damage if you TURN in 4hi and causing driveline binding. You can drive on dry straight roads with ZERO issues, even slight curves are still fine.
  13. Apr 6, 2021 at 9:25 AM
    #93
    Chaosh1
    2021 Tacoma TRD Pro
    Read what I wrote again and don't skip any words this time. I'll point out what you missed which resulted in your statement of 'That is grossly overstated and truly stupid"
    "It seems that the general consensus is that running 4WD high on concrete would cause damage due to lack of slippage while turning"
    Tacowin1013[QUOTED] likes this.
  14. Apr 6, 2021 at 9:26 AM
    #94
    Tacowin1013
    I stand corrected, missed that part! Guess i read too many posts claiming straight line driving causes damage that I just assumed! My bad...
    Chaosh1[QUOTED] likes this.
  15. Apr 6, 2021 at 12:27 PM
    #95
    longhairedhippy
    longhairedhippy I never go full redneck
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Bunch of stuff bolted on, some cool, some not
    I like to echo things back to make sure I understand them correctly, please be patient, I'm a total noob at all of this stuff.
    If I understand correctly after reading through this whole thread, when in 4HI/LO, the transfer case is locked so the front and rear driveshafts have to rotate at the same speeds. Since we're actually only 2wd, one front wheel and one rear wheel, the ones getting power from their respective driveshafts, have to rotate at the same speed, given they are the same size. When turning, depending on road conditions, the front/rear wheel combination that gets power may end up being the on different sides of the truck, which would mean they need to rotate at different speeds (inside versus outside of the curve). Since this can't happen, because the drive shafts are locked together, physics means more stress on the drive components until either the tires slip enough to relieve some of the pressure or the drive components fail.
    Is this an accurate description?
  16. Apr 6, 2021 at 12:46 PM
    #96
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    Five pages, WOW!
    a2lowvw likes this.
  17. Apr 6, 2021 at 12:58 PM
    #97
    0xDEADBEEF
    You're overthinking it. It doesn't matter which wheel would get power because that is entirely dependent on slippage which we're assuming is not happening on conrete.
    The short of it is that the front and rear axles travel slightly different distances in a turn due to the geometry of the vehicle. So if they're locked together via the transfer case, you get binding, which we don't want.
  18. Apr 6, 2021 at 1:07 PM
    #98
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Think we can hit 8?
  19. Apr 6, 2021 at 1:22 PM
    #99
    RIDER34
    RIDER34 Well-Known Member
    16 Inferno SR5, 18 magnectic gray SR5 4x4
    Not using the 4X4 at least once a month will be sad...... so far that's my case ....:rofl:
  20. Apr 6, 2021 at 1:28 PM
    #100
    kaotic
    kaotic Active Member
    kyle
    Salem,OR
    2020 super white DCSB TRD sport 6MT
    This post should sum it for OP. if the thread continues he’s going to move to a place where it snows so he can workout the 4WD without being nervous. Lol I love TW and threads like these. For me it’s fun to hear all the back n forth. Just find some dirt, engage.
    longhairedhippy likes this.
