Engine (3.4 5VZ-FE) won't start after I replaced the starter and its relay
Discussion in '1st Gen. Tacomas (1995-2004)' started by porterbnelson, Sep 20, 2024.
  1. Sep 20, 2024 at 9:42 PM
    porterbnelson
    porterbnelson [OP] New Member
    Porter
    1998 Gold Tacoma SR5
    2.5 inch lift, 33 BFG Ko2s, Apple Carplay, ARB Bumper, KC HiLites Apollo Pro Halogens, Teq Custom Grill, Custom Canopy, 2 Rocket Boxes
    When I tried to start my Tacoma, the engine simply clicked. I could hear the starter engaging and humming, yet no signs from the engine. I made sure it was in park, tried to start it while moving, checked to see if it was grounded, jumped the car, and all the electrics work as the lights, stereo, and dash work just fine. I changed the starter and relay to no avail. I'm completely lost as the car started perfectly the day before. pls help. [​IMG]
  2. Sep 20, 2024 at 9:50 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  3. Sep 21, 2024 at 6:09 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    It's been a long time since I've had to replace my starter, so I may be all wet here...:notsure:
    Does the engaging and humming sound like the starter motor is spinning? Or does it just hum?
    If all you hear is a hum, then something could be preventing the solenoid from moving its gear into the flywheel. If that's the case, no current would be applied to the starter motor windings and the starter will not spin.
    If it sounds like the starter is actually spinning then it could be that something is preventing the solenoid's gear from turning the flywheel. Broken tooth on the flywheel?
    Prolly have to take it out and test it on the bench to make sure that the solenoid is actually moving.
    ControlCar likes this.
  4. Sep 21, 2024 at 1:25 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Where did new starter come from?
    robm7 likes this.
  5. Sep 21, 2024 at 5:39 PM
    porterbnelson
    Porter
    found the problem the battery terminals were corroded and needed a wash thank yall for the help tho
  6. Sep 21, 2024 at 6:06 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Yep, like Dm93 said, check for voltage drop, which is what you had.
  7. Sep 24, 2024 at 3:00 PM
    skeezix
    Colorado
    1998 Limited
    :thumbsup:
    Beats the hell outta starter r/r :thumbsup:
