Engine accelerates at 1500 RPM preventing engine braking when going downhill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrt-mt, Oct 18, 2020.
  1. Oct 18, 2020 at 3:44 PM
    mrt-mt
    mrt-mt [OP] Member
    I have a 2017 TRD OffRoad with a 6-speed manual transmission.
    When I go down my driveway with my foot off the gas as soon as the RPMs reach 1500 the truck accelerates then lets off at approx 2500 rpm then decelerates to 1500 and the cycle starts all over again unless I use the brake forcing the truck to slow below the 1500rpm range. I know I cannot be the only one that has this problem but it drives me insane when I have to ride the brake all the way down my driveway. Any way to fix this, possibly with a DIY tune?
    Any help would be appreciated.
    MOC221_ likes this.
  2. Oct 18, 2020 at 3:47 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe try going down the driveway in neutral?
    pinochle, robssol, TRD-ED and 3 others like this.
  3. Oct 18, 2020 at 3:49 PM
    Wynne55
    Wynne55 New Member
    I had a 2016 that I took hunting when I got it. I was able to drive around in 4 low and second gear and it would hold the truck back and not let it accelerate. Now I have a 2019 and it dose what you described. It’s the one thing I hate about this truck. I run 4 low quite a bit in second gear especially going slow down hill and it drives me nuts when it runs away like that.
  4. Oct 18, 2020 at 4:11 PM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
  5. Oct 18, 2020 at 4:16 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Mat from OVtune has been looking into this for us for quite a while now. No solution yet. It is absolutely the stock calibration causing it.
    Junkhead likes this.
  6. Oct 18, 2020 at 4:53 PM
    mrt-mt
    mrt-mt [OP] Member
    What a bummer. I was hoping there was a resolution out there. It is at least encouraging that this is an acknowledged problem even if its only by the customers.
    I watched the video and while he did mention drivability changes, no mention of manual transmissions was made.
    Hopefully this can be fixed some time in the future.
    Thanks for chiming in.
  7. Oct 18, 2020 at 4:57 PM
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    2020 AT does the same: hope Mat can fix it.
  8. Oct 18, 2020 at 4:59 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    DFCO? @tonered didju ever figure anything out in VF with this?
    Junkhead and tonered like this.
  9. Oct 18, 2020 at 5:06 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    That's exactly what it is. Above 1450rpm or so, gravity is pushing everything and no fuel is being used. Below that, fuel kicks in and the engine is pushing everything again and you feel the transition.
  10. Oct 18, 2020 at 5:21 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    For whatever reason these trucks don't compression brake below 1500 rpm. Don't believe this has anything to do with fuel and is done and made possible by the wide range variable valve timing.
  11. Oct 18, 2020 at 11:19 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yep. OVT 2.0 has been tuned with big changes there.
    Junkhead and shakerhood like this.
  12. Oct 18, 2020 at 11:29 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    2.7L MT doesn't do this, FWIW.
  13. Oct 19, 2020 at 9:10 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    I have the OV 2.0 and it still does it.
  14. Oct 19, 2020 at 9:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I don't know what, if anything, was done on the AT tunes, but the MT side is lovely. If you're AT, you might asked OVT about what can be done in vF.
  15. Oct 19, 2020 at 9:16 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Below 1500 rpm the computer is worried about stalling so it starts to inject fuel, even with no throttle.
    Above 1500, let’s say you are engine braking down a steep hill at 2800 rpm with no throttle, the injectors are t spraying, it’s just compressing and dumping air.
    Edit: that’s how it works on my truck, yours will be different.
    tonered likes this.
  16. Oct 19, 2020 at 9:18 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Sounds like the correct diagnosis, just wish it would hold the compression better; even in 1st Low it dumps much more than my 09' 4.0 did
  17. Oct 19, 2020 at 9:25 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    About all that I can say is that the MT tunes are set to near idle and there is zero stalling risk. On the various test tunes that I tried, only one produced a stumble. We've been this way, going on 2/3s of a year.
    The other thing was that on Stock, 1.05b, and 2.0 Betas, we would get a solid lurch forward when the injectors cut back in and was very inconsistent. Now, it is quite smooth and a dramatic improvement when wheeling and in traffic.
  18. Oct 19, 2020 at 9:34 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yep, none of that happening on my premium SFOB tune. I can coast below 1000 in gear with DFCO engaged. Pretty sure i could do that on the stock tune too though. Like lets say coasting in 6th to a red light.
    tonered[QUOTED] likes this.
  19. Oct 19, 2020 at 9:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sorry, but no. It was just more subtle in the higher gears. Toss Stock back on there and monitor the Fuel Status. The injector cut in was right around 1,400 in all gears.
    Skydvrr likes this.
  20. Oct 19, 2020 at 9:46 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Weird that the MTs having issues.
    Do the MTs have any kind of drive modes that could be causing the lurching?
    I find my stock 17 AT a bit frustrating besides the classic AT issues at highway speeds, slowly going up my driveway it surges a bit.
    Not sure if it’s poor drive by wire feedback or hill assist that lets me roll back in the driveway then trac wigs out.
    It’s a lot less precise than my 93 pathfinder that had a cable.
    MasTacosMa likes this.
