engine accelerates on its own
Discussion in '4 Cylinder' started by drifterss454, Feb 13, 2015.
  1. Nov 6, 2015 at 7:53 AM
    BamaToy1997
    Bill
    Navarre, FL
    To be fair, if you are starting from a stop and the accelerator for whatever reason actually DID go full throttle to spin the tires, the ABS system will not engage. Also, if memory serves correctly, if you have a foot on the brake, and one on the gas then the ABS system also will not engage. Just a little FYI.
  2. Nov 6, 2015 at 7:58 AM
    BamaToy1997
    Bill
    Navarre, FL
    Regardless, when accelerating from a STOPPED position, ABS will not engage. Period. Even the old school systems. ABS will only engage if all 4 wheels are showing movement BEFORE the brake pedal is pressed, i.e. the vehicle must be already moving.
  3. Nov 6, 2015 at 11:20 AM
    jlmjl
    jlmjl Member
