Engine Acting bad HELP!
Discussion in '1st Gen. Tacomas (1995-2004)' started by b_martin, May 8, 2010.
  1. May 8, 2010 at 2:03 PM
    b_martin
    b_martin [OP] New Member
    Brandon
    Phoenix/Prescott
    2001 Prerunner double cab
    01 v6 prerunner tacoma double cab automatic. everytime i pick up speed, the entire engine acts like it about to fall out. i feels like the engine is misfiring. but i know its not. it acts fine if i put the tranny in park. and rev it. i replaced the spark plugs and it ran great for a trip a hour away and on my way back about 20 minutes from my house it started it again, and does it everytime now. the truck its self has 175000 miles. if you have anything i should try let me know! knightriderbrandon-spam@hotmail.com or on here
  2. May 8, 2010 at 2:07 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    First, welcome to TW.
    Second, you have an 01..that's a first gen, need to move your post.
    Third, I'd look at a clogged fuel filter. My antique 84 Toy pickup with the 2.2 did the exact same thing, and that's what the problem was.
  3. May 8, 2010 at 2:09 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Well no check engine light signifies internal mechanical problems or a drastically leaned fuel mixture.
  4. May 8, 2010 at 2:12 PM
    HerNameIsLucy
    RIP Lucy.
    drastically lean fuel mixture would be picked up by the O2 sensor and should throw a code.
  5. May 8, 2010 at 2:25 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Engine or Transmission mount? Fuel filter is not a bad thing to check, but that usually just causes the engine to bog down or die altogether. If it is vibrating a lot, check the mounts.
  6. May 8, 2010 at 2:44 PM
    2.7taco
    Texas
    If the fuel filter stops up the mixture will drastically lean out and cause engine shudder. If the fuel cuts back in at the right time no code will be thrown.
    Have the engine cleaned out. When I worked for NTB we did a 3 step. In fuel system cleaner, engine oil system cleaner and lastly a engine carbon clean out. You may be having detonation.
  7. May 8, 2010 at 3:24 PM
    HerNameIsLucy
    RIP Lucy.
    Think some Seafoam down the brake vac hose would help? With 175K miles he should have enough carbon in there to smoke out his entire county.
  8. May 8, 2010 at 3:30 PM
    dogbite
    dogbite Well-Known Member
    Utah
    '10 double cab TRD OR
    OME lift, Leer shell, Beefed sliders, Extra 12V outlets for rear bench
    Most of the usual suspects will throw a code but sometimes you get an ECU that is finicky about codes. I've got a 96 Kia Sportage that generally runs well but will have issues and not throw a code.
    I suspect a misfire of some sort. This could be many different things. Clogged injectors, bad coils, air flow sensors, plugs and more.
    I don't have very good knowledge of the Taco engine yet, but looking at a recent thread on doing your own plugs leads me to this:
    Where you replaced plugs, I'm thinking a coil or more is bad. You probably made the coil temporarily happy when you handled it during the spark plug changes.
  9. May 8, 2010 at 3:45 PM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    x2
