Engine Air Filter recommendation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokhan, Sep 28, 2015.
  1. Sep 29, 2015 at 4:53 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    ^^^^^^example of anecdotal information by a "self proclaimed filtration expert" with limited (if any) knowledge of the subject. ^^^^^^^^^^^^^^^^^^
    Apparently at least ONE person's "anecdotal evidence" supports the fact that reducing the life span of a good engine by 50% to 75% is a "catastrophic engine failure" . In that regard, I might agree with him. Beyond that....not so much.
  2. Sep 29, 2015 at 5:06 AM
    Clearwater Bill
    Billy
    Largo Florida
    Here's the key. Nothing you do to the intake to let in 'more air' is going to make the truck gain any power or MPG, so simple filtration is your goal.
    An OE style filter (Wix, Purolator, etc.) changed based on the owner manual recommendations (time or conditions) will be just fine.
    Pick one that's on sale and call it a day.
    ChesterTaco, Arailt, woodygg and 3 others like this.
  3. Sep 29, 2015 at 5:11 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Damn Skippy
  4. Sep 29, 2015 at 5:24 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Yep.....
    You mean to tell me that K&N filter isn't going to replace a supercharger and force more air into my stock engine, creating huge performance gains for under $100? :)
    Apparently many people subscribe to the theory that more noise = more performance.
    A clean "stock" type filter and the air filter housing on any decently engineered vehicle is capable of flowing far more air intake than the engine will use. The engineers don't restrict air intake to the bare minimum required at maximum air flow through a new filter. Even with a stock filter somewhat "dirty", it will pass enough air to maintain adequate performance levels. It's only once that filter is substantially clogged does performance/fuel economy begin to drop off. Allowing air AND dirt to pass through a filter does nothing to increase performance and eventually destroys performance. From my 17 years working in R&D with American Honda, most successful engine manufacturers factor in a 50% to 60% "clogged filter" while still allowing sufficient air flow.
    In just about every instance I'm aware of, the "choke point" of getting more air to freely flow into a naturally aspirated 4 stroke engine is the intake runners/valve openings in the cylinder heads.
  5. Sep 29, 2015 at 5:34 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    aFe Dry Flo drop-in.............washable and no oiling for people to ruin their MAFs............or oem if you like throwin more money at toyota every so often. And as always, do whatever the fuck you want.
    0uTkAsT and thewarriordinghy like this.
  6. Sep 29, 2015 at 6:35 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Capt. Obvious likes this.
  7. Sep 29, 2015 at 6:43 AM
    Kbel
    Kbel Well-Known Member
    Kevin
    Fort Worth
    2018 MGM DCLB
    That is why I did not want to pollute the op's thread and wanted to have a pm based discussion about oiled filters. We all have opinions on this and some are based on logic, here say, or hairy scarey principals.
    I agree on standard paper filters. With that said I have respect for oiled k&n filters. We used them on our helicopters and if oiled correctly they were great. We had a learning curve on using them. If you do not over oil or under oil they work great. The problem is too many people think more oil is better. Apply the required amount on the outside and let it soak in for 24 hours.
    For me I would rather use stock filters in my vehicles than rather go through the whole cleaning, let dry, and then the oiling process. FWIW
  8. Sep 29, 2015 at 6:46 AM
    Clearwater Bill
    Billy
    Largo Florida
    AC Delco makes filters for our trucks. I'll use those now.
    I think I have some of the old blue door jamb stickers from the 60's somewhere. GM. Mark of Excellence. One for the airbox. Just because.
  9. Sep 29, 2015 at 9:22 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Yeah, I like running with the "in the know" crowd. I think that's how lemmings get along. LOL
  10. Sep 29, 2015 at 9:47 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    only OEM spends the millions to test filtration and design them to fit the application, which
    is an engine + filter that meets epa requirements and moves the truck along while blocking silicates effectively
    other other 'amazing filters' are fools errands, OR for racers who are used to doing the engine teardowns
    and rebuilds required to maintain a motor that breathes more freely and ingests more silicates.
  11. Sep 29, 2015 at 10:36 AM
    jbrnigan
    Midwest
    Yep, and Toyota (TRD) offers a cotton/gauze filter for their vehicles, that's warranty friendly, which must be part of the "?millions" they spend to test filtration, "which is an engine + filter that meets epa requirements and moves the truck along while blocking silicates effectively".
    If that's not right, I'm sure they like to hear from you regarding their mistake.
  12. Sep 29, 2015 at 10:42 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    yes and ONLY the TRD filter. don't use just any cotton gauze filter, the Toyota TRD one actually has been properly tested
    it is a lot more 'designed and engineered' than a K&N piece of shit that is for sure
    I am not wrong, I am just an asshole
  13. Sep 29, 2015 at 11:20 AM
    jbrnigan
    Midwest
    LOL - Hmmmmmm
  14. Sep 29, 2015 at 12:04 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I ran TRD oiled filter on TRD cold air intake for about 130,000 miles. Cleaned & oiled at 15-20,000 intervals.
    When I cleaned throttle body after 100,000, it didn't seem any worse than I'd expect normally. Never any MAF issue. Looks fine.
    I swapped to AFE ProDry filter a few months ago. Saw a small bump up in mpg.
  15. Sep 29, 2015 at 12:22 PM
    #35
    jbrnigan
    Midwest
    According to one poster here, you have reduced your engine life by 50-75% - NO WAIT - because it was TRD filter, it was properly tested, your good for another 130 K - NO WAIT - AFE Pro dry - now I'm really confused - any of the experts got an opinion?
  16. Sep 29, 2015 at 12:26 PM
    #36
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    ah....
    depends upon how you define better. i would never let mine got that long.
  17. Sep 29, 2015 at 12:26 PM
    #37
    woodygg
    So Cal
    04 DC Tacoma 4x4
    do enough reading on those and you'll ditch them... i used them for years and years until i saw some of the studies.... ditched it immediately.
    Unchained 5150 likes this.
  18. Sep 29, 2015 at 12:46 PM
    #38
    woodygg
    So Cal
    04 DC Tacoma 4x4
    BAM!
    :boom:
  19. Sep 29, 2015 at 1:24 PM
    #39
    Bluegrass Taco
    Bill
    Mt Washington Ky
    "I think"......
    That's where things go astray for ya pard.....
  20. Sep 29, 2015 at 1:29 PM
    #40
    jbrnigan
    Midwest
    Geeez, I'm glad to know I'm in good company! LOL
