Engine air filters.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jun 19, 2023.
  1. Jun 19, 2023 at 4:20 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    How often are you guys checking your engine air filter/replacing them?
  2. Jun 19, 2023 at 4:26 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    I ran my oem for about 80'000kms... probably too long but it was still okay when I changed it. The new filter I installed has a foam pre-cleaner.. acdelco I believe. I just set the truck minder to 50'000kms which based on appearance is prolly all i'd want to push if not around 40'000kms next time depending on when I happen to order from Rockauto
    Gfenza89[OP] likes this.
  3. Jun 19, 2023 at 4:26 PM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    I'm using an AFE dry pro, washable, and do it twice a year.
    SR-71A and Gfenza89[OP] like this.
  4. Jun 19, 2023 at 4:33 PM
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    replace mine every 15000. If I have a good hunting tag and spending a lot of time offroad on dusty two tracks I'll inspect it earlier right after the trip and then possibly replace it.. It will depend on your usage. 15000 is a good place to start if your just on pavement. Az has a lot of dust here in general. The earliest I have ever replaced one is 5000. Some who do a lot of group trips in a dry environment will change them earlier and possibly after each trip. Ive seen some, Death Valley, that probably should have replaced a filter mid trip. That type of driving, on a regular basis, would be a good time to consider a snorkel. Long answer lol
    Gfenza89[OP] and RustyGreen like this.
  5. Jun 19, 2023 at 4:36 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Check it every oil change. Replace it when it's dirty.
  6. Jun 19, 2023 at 10:02 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Every 30K or so which, for me, is 2-3 years. I am sure I could go longer as the factory filter is really good. Lots of filter area.
    RIX TUX, Junkhead and Gfenza89[OP] like this.
  7. Jun 19, 2023 at 10:53 PM
    bullpen58
    bullpen58 Well-Known Member
    Peoria, AZ
    2021 Tacoma PRO 4x4
    Lift, wheels, tires, sliders, and skidplates...so far.
    I have a Pro model, which came with some type of K&N filter. I clean and lube it back up at every oil change (every 5000). I know the maintenance schedule says it only needs the oil changed once every 185,000 miles or whatever but I still do it every 5000. My filter doesn't usually look super dirty unless I do a lot of off roading in dusty conditions.
    With previous trucks, I always replace the air filter at every oil change, no matter what it looks like. It's cheap insurance for a very crucial part of your truck.
  8. Jun 19, 2023 at 11:38 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I just go by the owner's manual, slightly earlier if I am already in the shop.
  9. Jun 20, 2023 at 4:35 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I decided to check mine not long ago....had 22k miles, and it still looked good.
  10. Jun 20, 2023 at 5:16 AM
    jeezumcrow
    jeezumcrow Well-Known Member
    Charlotte, NC
    Cabin, engine filters last 6 months in my car. I am a 4K mile oil change dude, too.
    faawrenchbndr likes this.
  11. Jun 20, 2023 at 5:18 AM
    zoo truck
    None
    I checked my cabin air filter also, it was fine. Its never been replaced yet.
  12. Jun 20, 2023 at 3:08 PM
    Markmmg
    Markmmg Well-Known Member
    Mark
    Baton Rouge, LA
    Prerunner double cab
    I have gotten in the habit of changing the air filters (engine and cabin) and the wiper blades on my vehicles on January 1 every year. That way I can keep track of when they were changed. I find mine usually are dirty and need to be changed after 1 year.
    2022mgmtrdsport and 10thMTNgrunt like this.
  13. Jun 20, 2023 at 3:27 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    For those who feel their filter is good after 20,000 mi. you should compare it to a new one by holding both to light while side by side.
    zoo truck likes this.
  14. Jun 20, 2023 at 8:08 PM
    marc1
    marc1 Well-Known Member
    Marc
    West Coast Canada
    2017 Tacoma SR5
    Tonneau Pro Soft Fold
    I changed my OE one out at 42,000kms (30,000 miles) it looked like new. Unless I hit a dust storm I won't change again until I rack up 60,000kms (36,000 miles) on the new one.
    joba27n likes this.
  15. Jun 20, 2023 at 8:27 PM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I fail to understand the benefit of changing air filters so often, I typically go eighty- to one-hundred-thousand miles on a filter.
    Tacoma1845 and wrightme43 like this.
  16. Jun 20, 2023 at 9:53 PM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    I check it every five thousand miles, which is while I'm doing tire rotation. Replace as needed during inspection, but absolutely replacement at twenty thousand miles. Same goes with my cabin air filter.
  17. Jun 20, 2023 at 10:05 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    I change mine every 10K miles or so, and it gives a nice performance boost. I am off road a lot in very dusty conditions so it clogs up fast.
    I mentioned in a similar thread that I tried 3 different brands of engine filter, and all of them sucked. Power loss.
    I put the OEM back in, and all was good.
    I regularly do a trip that has a 5,000 foot elevation gain, that at 70mph takes 24 minutes to climb. Often with 1,000 pounds in the truck bed. I have the same load in my truck each time on those trips.
    That is where the performance loss from the after market filters was really brutal. The truck was just gasping, as the airflow was restricted by the after market filters. I was doing 60mph at 4500rpm with the aftermarket filters. With the OEM I was doing 70mph on the same stretches of road at 3000rpm.
    When driving on the flats it was not really that noticeable.
    This is my 4th 4x4, and is the only truck where I experienced this from after market filters.
    So, I will never go after market filter again in the Taco for the type of conditions I drive.
  18. Jun 21, 2023 at 6:31 AM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    On the anniversary of my purchase date every year. Made this a practice on all my vehicles. Usually after 10k to 12k miles if use.
  19. Jun 21, 2023 at 6:44 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Just an FYI, but the dirtier the oiled K&N filters get, the better they work! I have a drop in K&N filter in my FJ and go 50K miles between cleanings.
    Carry on!
    D.A.S. Taco and AmateurTaco1313 like this.
  20. Jun 21, 2023 at 7:11 AM
    JTB Tacoma
    JTB Tacoma Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    I use an AFE Dry Pro; I generally pull and clean it once a year. I have an OEM that I'll drop in for a couple days as I like to make absolutely sure the Dry Pro is completely dried out from the cleaning. I'm planning on pulling it this weekend for an extra cleaning after the couple of days of horrid air quality we had from the Canada wildfire smoke that blanketed the area recently.
    10thMTNgrunt likes this.
